Distribution of Controlled Copies - Document Control
harry
.................... Document was already signed, ........................
Since it had been approved, you should follow whatever stated in your document control procedure instead of any other person's opinion - unless you want to or are in a position to amend it.
i need to produce about 26400 pages to be distibuted on different departments/personnels
Seriously, this figure raised an alarm in me. But without seeing it (or further info), I am not in a position to comment.
ching10
Hi everybody!
I just want to ask .
Kindly give advise which condition below is acceptable.
Document was already signed, however i need to produce about 26400 pages to be distibuted on different departments/personnels. Probably i will consume more papers. I want to reduce the use of papers.
Conditions:
1. Make copies and then put controlled stamp (manually)
2. Scan copies (in pdf file), put controlled template (controlled stamp) from computer then save on dvd/cd then give to concern department/personnel.
3. Scan copies (in pdf file), put in company intranet (no controlled stamp).
thanks in advance
K
Ka Pilo
Re: Distribution of Controlled Copies
Hi everybody!
Why is it that many?
Conditions:
thanks in advance
What does your control of document procedure says?
ching10
Currently the control of document procedure was not yet approved and under develop, but the conditions i mentioned was not mentioned.
If ever i make a control of document procedure, is the three conditions possible?
K
Ka Pilo
Upoad the QMS documents to the Intranet for users access (read-only). In my opinion it's more practical and cost effective.
Any of the three options are acceptable. Which of the three is best and easiest to control for you and your company.
Personally I'd be looking at option three, regardless of the number of copies we are taling about.
Put them all on an intranet with read only access.
In addition I would either restrict the ability to print documents or, if that is not possible, place a disclaimer in my procedure and on the documents that hard copies are considered "uncontrolled" and valid only on the date they are printed.
This will help prevent people from printing off documents they need and then not checking the system periodically for updates.
Peace
James
P
pldey42
I don't think we know enough to be able to judge ...
Is this one document of 26400 pages, 26400 copies of one document, 264 copies of 100 docs ... ?
Were there several drafts? Which version was approved? How does everyone know they approved the right draft?
Does it display a version or issue number, a date, something that shows the version that was approved?
What's a "controlled" stamp? A stamp that says "Controlled"? A date stamp?
Why not just put a version number on the document itself?
I think it helps to remember the principles that underlie the ISO 9001 requirements. For document control, the relevant principle is to ensure that those who need the document can easily find it when needed, and be confident they have the right version. (That applies through the approval cycle as well, so as to be sure that everyone is reviewing and approving the correct draft - sometimes there are several drafts, all different, seeds of confusion.)
I'd use this principle to evaluate your options ...
... To which you might add, write the version number or date of approval or some kind of identifier in the document itself, and avoid the printing and stamping, or the scanning.
If you use the intranet, can everyone who needs the document access it from their normal place of work?
If you use a DVD/CD, what will they do with it? Do they all have computers (that can read it -- netbooks don't have DVD/CD drives) easily available? How will you locate and withdraw copies of the DVD/CD and of stuff printed from it when the next version is published?
Quality management is supposed to be about making life simple and error-proof for everyone - including the quality manager.
Hope this helps,
Pat
auditrookie
Hi Harry,
I have a question: a few years back I began identifying all released work instructions with a watermark; "Printed copies are considered uncontrolled. Revision can be confirmed by Document control". In our recent registrar audit, the audit asked why we are putting uncontrolled copies on the production floor.
My mgr at the time told me what to put on these and it has not been questioned until now. In previous companies I always used a release stamp. Should I change the watermark to say "controlled copy"? not sure where to go with this.
thanks for your help,
Hi Harry,
I have seen companies use the method similar to yours but instead of sayin "uncontrolled" they say they are valid only on the date of printing" followed by a print date.
In this way, if an auditor finds a copy on the floor with that day's date, it is not "uncontrolled".
Peace
James
A Distribution of Controlled Copy vs. Uncontrolled Copies Document Control Systems, Procedures, Forms and Templates 4
N Does a Document Distribution List need to be a Controlled Document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
N Controlled Documents Distribution Query - Home Care Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
W Electronic Distribution of Controlled Documents: Validation required? Qualification and Validation (including 21 CFR Part 11) 5
S Distribution List of Controlled Documents Document Control Systems, Procedures, Forms and Templates 5
C Ensuring Documents of External Origin are Identified and Distribution Controlled ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Controlled Documentation Distribution Log Document Control Systems, Procedures, Forms and Templates 2
A Can anyone share a Distribution Agreement template under MDR 2017/745? EU Medical Device Regulations 0
P Sample Size for Distribution Simulation Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
D Private Label Distribution - US Other US Medical Device Regulations 1
D Question regarding "storage and distribution" ISO 13485:2016 - Medical Device Quality Management Systems 1
M Proof of distribution - FedEx/UPS tracking numbers Manufacturing and Related Processes 2
O Are power distribution units Multiple Socket Outlets (MSOs)? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
JoCam Medical Device Distribution in the UK EU Medical Device Regulations 6
M Prescription medical device distribution licenses in the U.S US Food and Drug Administration (FDA) 3
M US distribution Medical Device Medical Device and FDA Regulations and Standards News 8
Marco Bernardi Finding a flat or not modeling distribution: how to manage it? Capability, Accuracy and Stability - Processes, Machines, etc. 24
T Was Just told we could ONLY buy material for AS9100 customers if the DISTRIBUTION house is AS9100 / AS9120 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P Medical Device not on commercial distribution but installed in the establishment. 510k? Other US Medical Device Regulations 10
M How do you Audit an Distribution Facility according to MAQMSR IATF 16949 - Automotive Quality Systems Standard 3
K Inspection Certificate EN 10204 2.1 - Distribution company Other ISO and International Standards and European Regulations 4
S Medical Device Software Distribution for a CE-marked medical device via a USB memory stick EU Medical Device Regulations 8
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
K Distribution medical devices to US Embassies 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
P AS9120B Control of External Providers for Franchised Distribution AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
C IATF 16949 - RSL - Distribution Center Clasification IATF 16949 - Automotive Quality Systems Standard 3
S Ways to attract clients - Flyer distribution in Toronto, Canada Service Industry Specific Topics 1
N Apply control limits to a non-normal distribution Statistical Analysis Tools, Techniques and SPC 13
G Plotting capability study data - I have a bimodular data distribution Capability, Accuracy and Stability - Processes, Machines, etc. 4
Sidney Vianna ISO 13485 Certificates Distribution around the World - 2018 ISO 13485:2016 - Medical Device Quality Management Systems 4
F Definition Commercial Distribution - Definition - Scope of Commercial Distribution Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
R Non-normal Distribution Selection where the system is constantly being corrected Capability, Accuracy and Stability - Processes, Machines, etc. 11
J Distribution and PPAPs for products they do not manufacture APQP and PPAP 3
G Uncertainty Experts - ISO 17025 - If the Distribution is Rectangular Measurement Uncertainty (MU) 2
D Distribution of a Class 3 Medical Device EU Medical Device Regulations 4
K Distribution Centers - NSF Audit Qualification and Validation (including 21 CFR Part 11) 1
A Not all characteristics follow a Normal Distribution - How do you do SPC Chart Capability, Accuracy and Stability - Processes, Machines, etc. 5
F Distribution Records required by FDA - 21CFR820.160 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
V Process Capability for parameters with non-normal distribution. Capability, Accuracy and Stability - Processes, Machines, etc. 16
P IVD device distribution, what to do? Japan Medical Device Regulations 1
M Medical Device Distribution in Canada - Do we need both MDEL and MDL? Canada Medical Device Regulations 8
E Medical Device Distribution Quality Management in South Korea Other Medical Device Regulations World-Wide 0
D Calculating Cpk on Non-Normal Data Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 10
L Choosing the correct Distribution for Acceptance Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 19
A Medical Device Distribution in the EU to Patients (End-Users) EU Medical Device Regulations 3
L Intellectual Property Protection - Storage, Access, Distribution, etc ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J Non-Normal Distribution Data - Tolerance Intervals and Minitab Using Minitab Software 7
J Lean Appropriate KPIs for a Distribution Centre Lean in Manufacturing and Service Industries 1
