DMR-Device Master Record vs DHF-Design History File vs DHR-Device History Record
CreMindES
#21
I want to add that IMHO the only way to make it cause as little pain as possible, is to make sure it also helps your development and documentation, ensuring that it only adds minimal extra effort to maintain it.
rdesmond
#23
Hello. We are a contract manufacturer. When we perform Process Validation, should we place the protocol & report in our DMR or DHR? Of course, our customer receives a copy for their DHF, however I wasn't sure for ours. I assume?? the same answer will also hold for Equipment Qualification protocols & reports, yes? Thanks a bunch!!:bigwave:
MIREGMGR
#24
In your part of the device DMR.
As a contract manufacturer, you have primary responsibility for those aspects of your processes that are proprietary to you and therefore not fully controllable by your customer(s). Records related to your responsibilities go into your DMR for the product. Your customer also has a DMR for the product, containing records for those matters that they control and that they source on the outside and can effectively control, such as design and (in some cases) materials qualification.
The DHF is maintained by the party responsible for the device design, and contains information on that design from the beginning and including all iterations, modifications and developments, but usually doesn't include the current product design which is documented instead in the DMR.
The DHR is maintained by the party responsible for manufacturing, or in a contract manufacturing relationship, sometimes jointly and sometimes in duplicate fashion by the customer and the contract manufacturer respectively.
Ronen E
Problem Solver
Moderator
#25
Definitely not in the DHR.
IMO also not in the DMR.
I think you could simply create a file designated "Process Validation & Equipment Qualification", and keep it there, as simple as that. Just make sure all your SOPs are aligned with that arrangement, and that any one with proper clearance (FDA, your staff etc.) is able to gain access to these documents quickly and effortlessly, for as long as required. See also my previous post in this thread.
Contrary to common belief, regulation doesn't have to go against common sense.
Cheers,
Ronen.
H
Huyen
#26
Cheers,
Ronen.
Dear All,
We just produce the sample of medical device for Customer from US (we are from Vietnam). Our company plan to certify FDA in next year. However, when Customer audit us, they ask to have DHR procedure inplace, we are almost unclear about it, Can anyone help to share the format or template of it
Must appreciated ..
L
lfrost
#27
"Dear All,
Must appreciated .. "
The DHR, and all of it's components, tells how the device was made to the specifications of the DMR. The DMR, and all of it's components, tells how the device was manufactured to the specificatons of the DHF. The DHF tells of the steps taken to design the device.
You should be aware that your device needs to be listed and registered with the FDA before you market your device in the USA. You do not need to "certify" your device with the FDA unless it is class III or a required class II device which need a 510(k) PMA approval.
Hope this helps...:2cents:
L
Lulumathew
#30
Could any one help me understand what is Lot History Record? Is that same as Device History Record?
E Procedure ( SOP) for Device Master Record ( DMR ) and for Device History Record (DHR)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Sam Lazzara Medical Device File (MDF per 13485:2016 4.2.3) versus FDA Device Master Record (DMR) ISO 13485:2016 - Medical Device Quality Management Systems 3
R Are DMR (device master record) and DHR (device history record) inspected by FDA or audited by an NB ISO 13485:2016 - Medical Device Quality Management Systems 6
S Foreign Manufacturer and DMR - Who keeps the DMR (Device Master Record)? ISO 13485:2016 - Medical Device Quality Management Systems 2
S DMR (Device Master Record) for Medical Device Software IEC 62304 - Medical Device Software Life Cycle Processes 3
I DMR (Device Master Records) and similar for standalone software device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S DMR (Device Master Record) Management and Index questions Other US Medical Device Regulations 18
P DMR (Device Master Record) for Class I and Class II Dental Product 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
B DMR (Device Master Record) For Contract Manufacturers 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
C When to submit a 510(k)? After the DMR (Device Master Record) is finished? Other US Medical Device Regulations 4
J Contents of DMR (Device Master Record) when manufacturing is by 3rd party 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
A DMR (Device Master Record): What is meant by these words - Software Specifications? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
D DMR (Device Master Record) Index as a Controlled Document 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
E Need help establishing a DMR (Device Master Record) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
B Format of Device Master Record (DMR) for Combination Products 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
J Device Master Record (DMR) that was compiled by another company 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
W Update DHF (Device History Record) when DMR (Device Master Record) changes? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
W DMR (Device Master Record) Revision Requirements? FDA GMP Manual 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
S DMR Index - Can someone share their Device Master Record Index structure or format? ISO 13485:2016 - Medical Device Quality Management Systems 15
M DMR - Device Master Records - What is the best way to structure the DMR 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 55
S DHF/DMR/MDF for a software-only, cloud-based, single-instance device Medical Information Technology, Medical Software and Health Informatics 2
S Quality Plan at a small Medical Device Company - Is the quality plan a DMR document ISO 13485:2016 - Medical Device Quality Management Systems 6
M Merge Technical File, DMR, and Device File into a single document? Other Medical Device and Orthopedic Related Topics 3
M Medical Device DMR's - List of the Marketing or Market Penetration documents ISO 13485:2016 - Medical Device Quality Management Systems 14
D Design controls - Inputs, outputs, V&V, DHF, DMR ISO 13485:2016 - Medical Device Quality Management Systems 10
A FDA and NB audit of Engineering Drawings in DHF and DMR. Medical Device and FDA Regulations and Standards News 1
P DHF, DMR and DHR in MDR? EU Medical Device Regulations 6
R DMR or Manufacturing Documentation - How detailed does the documentation have to be? ISO 13485:2016 - Medical Device Quality Management Systems 1
D Design Outputs vs DMR (Design Master Record) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S Is an index necessary for DMR or DHF? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
V What is required in terms of the DHR, DMR, DHF? Other Medical Device and Orthopedic Related Topics 4
S Difference between DMR procedures vs. QMS procedures? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
Q DMR and DHR - Two requirements, One Document 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
J Incoming Inspection Plans under Design Control (part of DMR)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
O Distributors and ISO 13485 - DHF and DMR Responsibilities ISO 13485:2016 - Medical Device Quality Management Systems 7
U Document Revisions Required in DMR Index? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
J Referencing the DMR (Design Master Record) in the PO Document Control Systems, Procedures, Forms and Templates 2
C Do I need to show fasteners in my BOM's/DMR etc? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
C Re-Verification of Nonconforming Product prior to closing our DMR AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
T Manufacturing Process Deviation linked to DMR (Discrepant Material Report)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
B Format for Discrepant Material Report (DMR) - Nonconformance Report (NCR) Document Control Systems, Procedures, Forms and Templates 1
S What do we need for a DMR? Importer of Record and Going Crazy! 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
D What kind of DMR must a Medical Importer have? Other Medical Device and Orthopedic Related Topics 8
B Dealing with Outsourced Processes in a DMR ISO 13485:2016 - Medical Device Quality Management Systems 7
J Which supplies/suppliers need to be listed in DMR? ISO 13485:2016 - Medical Device Quality Management Systems 4
V Medical Products: CE Marking - Are the DMR's, Technical Files, DHF, required? EU Medical Device Regulations 6
C Technical Documentation, DMR, ISO 13485 vs. FDA, STED Document Control Systems, Procedures, Forms and Templates 10
C Structure and Content of DMR / Technical Documentation (FDA vs. ISO 13485)? Document Control Systems, Procedures, Forms and Templates 6
T DMR/DHF/DHR/Batch Records/Master Batch Records ISO 13485:2016 - Medical Device Quality Management Systems 3
M What Marketing/Market Penetration information should go on the DMR? ISO 13485:2016 - Medical Device Quality Management Systems 4
