DMS (Document Management Software) vs. Paper Copies - Cataloging all of our docs.
selena15
Hi Covers
how are you doing ? :D hope doing well.
I´ve got a question:
I`ve got to estimate our reel amount of documentation to establish our need in DMS (softoware of doc control). my worry is how can i be sure that i won´t forget something :
to give picture, some of our doc are managed through softwares which take it from first elaboration to become a record, but the archive option aren´t supported by these software. some are on hand copy and i don´t see the need to change them on electronic form since it is well located and controlled.i´m also thinking to favorite web-based application against an open source or classical soft.
How to establish a reel need :bonk:and have an idea of our future need. I want to get advice and tips from experienced Covers ;)
:thanx: in advance
Sel
selena15
Re: DMS (Document Management Software) vs. Paper Copies - Cataloging all of our docu
no feedback ? :confused:
Pancho
wikineer
Dear Sel,
A few comments:
1)
You say that you've got to estimate the amount of documentation, but that you worry about missing something. If all you need is an estimate of the real amount of documentation, it shouldn't really matter if you miss a document or two when taking stock of what you currently have on your different systems. You can complete the list as you start using it in your new software.
2)
You ask how to establish a real need and have an idea of future need. I think you are talking about the need for Document Management Software. If so, by the fact that you do not have already an inventory of documentation and that you are afraid of missing some of the documentation, the need is established.
3)
Start by compiling the inventory of documents (list of documents). You will need this whatever software you select.
4)
Look into using a wiki for your DMS. If your list is on the wiki, just draw brackets around each entry to create a page for each doc and have it become the index to all of them, then upload up your existing docs, or better, copy and paste them onto wiki format.
Good luck!
Pancho
selena15
Hi pancho
Thanks you for feedback
it is look interessting, i would get a deep glance on it and see if it can answer our requirement :D
i would give feedback
thanks friend :)
Sel
selena15
Hi pancho
thank for your paper of geometria
i have a question
does this wiki just software or is it possible to have it as web-based ?
i´ve liked lot the functionalities as include and links and quick access
Pancho
wikineer
It is web based. Authorized users can accesses it from anywhere around the world.
And yes, the linking is fantastic. For example, our SOP: Purchasing is linked to the SOP: Material requisition, the SOP: Material reception, our standard PO Terms and Conditions, our standard subcontract form, and other various forms and records that it needs or produces. But the best part is that all the links are contextual: right at the point where the other document is named in the procedure.
selena15
Hi all
does anyone of you have used before windream system as DMS?
could you give me your feedback about it please
thanks
selena
B Problem Calibrating a Krautkramer DMS 2 Ultrasonic Thickness Meter Calibration Frequency (Interval) 2
P A SAP DMS Q: Sequantial work flow for DMS review and Approval Document Control Systems, Procedures, Forms and Templates 1
A Document Review and Document Approval --- 2 Signatures needed acc. §820.40? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
K 25-year lifetime of medical device - document storage period EU Medical Device Regulations 1
J UDI - Where to document it? EU Medical Device Regulations 8
S Changing revision status of a reviewed document Manufacturing and Related Processes 4
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
Q Document ownerships Document Control Systems, Procedures, Forms and Templates 14
E Document Change Request forms (or no forms)? ISO 13485:2016 - Medical Device Quality Management Systems 9
O Any info on release date of FDA “Computer Software Assurance for Manufacturing and Quality System Software” document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
B Document Approval Matrix Benchmarking Document Control Systems, Procedures, Forms and Templates 3
J Document Approval Signature Order Document Control Systems, Procedures, Forms and Templates 10
M What is the proper way to document measurements Measurement Uncertainty (MU) 1
P Equipment 21 CFR 820.70(g) - User Requirements Document for Off the shelf equipment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
B Do IFU designs have to be document controlled under ISO 13485? Document Control Systems, Procedures, Forms and Templates 2
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Document "Correspondence IATF 16949 vs ISO13485" available? IATF 16949 - Automotive Quality Systems Standard 0
R Document Retention - Discard hard-copies after scanning? ISO 13485:2016 - Medical Device Quality Management Systems 2
P Mylar plot suppliers in accordance with D6-51991 document AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Document Change Notice vs complete System re-write Manufacturing and Related Processes 4
Q Document approval through SharePoint (without signature) Records and Data - Quality, Legal and Other Evidence 4
S What is considered a "core algorithm"? (From an FDA guidance document) Medical Information Technology, Medical Software and Health Informatics 4
U Document Approval - Software company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
O Please, help with document on ISO/ TS 17758 and (IDF 87: 1979). Thank you. Manufacturing and Related Processes 1
I Nitpicking on document released dates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Refusal to Document Complaints Customer Complaints 39
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
I Can a document (form) approval record be separate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T Advice needed - Environmental MS - unwritten but customer requests policy document ISO 14001:2015 Specific Discussions 5
T Control of downloaded document copies by employees Document Control Systems, Procedures, Forms and Templates 3
T Document control ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
I Is highlighting on a printed document considered a change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C QMS Document Management Software Recommendations Quality Assurance and Compliance Software Tools and Solutions 14
E Part 11 Compliance, Excel living documents (i.e. document master list, equipment list, approved supplier list) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
Sidney Vianna Informational New IAQG Document - AS9100 Clarifications of Intent AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S How to determine & document Organizational Knowledge of a company Document Control Systems, Procedures, Forms and Templates 4
D Are medical device companies required to document every change made to their website? Document Control Systems, Procedures, Forms and Templates 2
M Informational IMDRF draft document – Principles and Practices for Medical Device Cybersecurity Medical Device and FDA Regulations and Standards News 0
M Nonconformity for missing form number on the job description document Nonconformance and Corrective Action 1
R Training Matrix for Document revisions ISO 13485:2016 - Medical Device Quality Management Systems 4
