Do all gages need calibration or only those used for final inspection?
trainerbob
#21
I guess that subconsciously I wanted to make sure "internal" was there and so my hands must of done this of their own volition. Thanks for noticing. As for "The Voices", I think there are times when we all may have a touch of that. Maybe it has something to do with this business we are in.
M Komarmy - 2012
#22
Another equation I like to consider is the one attached, total variation. When people measure an item, and expect it to represent the process, the forget that the result they get is not the measure of the process variation, but of the total variation. It includes the additive effects of all errors. So, if you have no idea what those other errors are, you really have no idea if the data you have comes anywhere near reflecting the process. I am not sure how that "shortcut" in analysis would make anyone comfortable with results of uncalibrated gages, as well as the other errors involved.
Of course you are spot on with this. All any gauge can give you is the total variation, it is up to you to determine the individual components of that variation. That is the primary purpose of gauge R&R, it will tell you whether the variation due to the gauge system (including operator and part influences) is overshadowing the variation of the process.
bobdoering
Stop X-bar/R Madness!!
#23
We must also separate calibration from verification. In many cases, verification may be that is all required.
The definition of calibration is pretty straight forward....but I suppose we can conjure up many definitions of "verification." For devices that have been shown to have correct linearity, but have the option to either have the zero set, or set to a offset - then "verification" to me is ensuring that the zero is still correct, or the setting to the offset is still correct. It is handy to do each shift - just in case the person before you "didn't get it quite right." But, IMHO, I do not look a verification as an alternative to calibration.
#24
If a gage is compared to a standard, calibration has taken place. There are different forms or levels of calibration, but what's commonly referred to as "verification" isn't different from "calibration."
Sidney Vianna
Post Responsibly
#25
I am still fairly new to the Cove and find this web-site so helpful and if I'm not in the correct thread please tell me.
Welcome to The Cove.
We are looking at AS9100 certification.
What makes me think you are in the supply chain of the aviation, space & defense sector. That is why I got really concerned when you stated
During one customer audit the auditor told us that we need to only calibrate those gages needed for final inspection of our final product.
It is mind boggling that, in this day and age, a 2[sup]nd[/sup] party auditor, (supposedly) quality professional would say something like this. So, while we have to deal with incompetence in the CB auditor community, incompetence of customer reps is also an issue.
bobdoering
#26
I suppose I can agree with that if zero or the setpoint is the range of measurement the gage will be used for...
#27
It depends on the measuring instrument. For example, XRF devices used for measuring plating thickness and metal assaying normally undergo a periodic "full-blown" calibration, but they're also calibrated before each use, using a special "master" standard. The same is true for other similar types of instruments, such as spectrophotometers.
bobdoering
#28
Yes, people do like to casually refer to those as calibrations. But, still, IMHO they are verifications - even (or especially) if an adjustment is made - just like a zero or preset setting on a micrometer. And, when that occurs over time and not tracked, any evidence of drift that is occurring - and it does, especially with electronics and light-based detection - it is lost (unless the machine will track it.)
So, your point is well taken There is not even agreement on definition of the term calibration. I suppose because of that I will have to coin a new term - "jack calibration" (sometimes referred to as "full-blown calibration.") If you are not verifying the full range of measurement, then you are not doing "jack". :tg: I sense an opportunity to use that term here often.
M Komarmy - 2012
#29
I am enjoying all the great comments about this topic. If I may I will add my 2 cents worth...
There are many types of gauges. Some are mechanical and not adjustable for gain, such as dial indicators, calipers, micrometers but may be adjustable for bias.
Others use transducers such as LVDT's, strain gauges, etc. and their signals are processed with computers or other methods (A/D converters and amplifiers) and give digital outputs. These are usually adjustable for both bias and gain.
For the first type, you can use artifacts such as certified master parts, gauge blocks, gauge rings, etc. to verify that they are measuring to the correct value and that they haven't changed. To me, that is verification. Depending on the robustness of the results, this verification may need to happen frequently (once per shift) or it could be once per day or week. The artifacts or masters used for verification need to be certified by a traceable lab on a scheduled frequency.
For electronic gauges, the electronics and mechanical settings need to be verified. Probes need to be mechanically set to the proper travel, as their linearity can be valid only over a relatively small range. This is best done with artifacts or master parts that cover 120% or more of the range of parts that will be measured. It is necessary for the gauge to be linear over more than the specification, because it is important to know the actual values of the parts that lie outside the specifications. I have used max, mean, and min masters for such gauges where the max and min exceed the spec limits by 20%. On the floor, this is typically called "mastering" the gauge, and unless probes are changed it usually only involves verifying that the zero(bias) and gain are correct. Many of these types of gauges will correct bias and gain errors automatically because the certified master values are entered into their databases. They can even recognize when the masters are loaded into the gauge in the incorrect order. If a change is made to correct gain and/or bias, I consider this calibration.
For CMM's, we verify them by measuring ball bars or ring gauges, and probes can be calibrated by measuring the artifacts and comparing the results to the certified values. The entire CMM is calibrated yearly by lazer alignment and compensating for wear of the mechanical elements. There are also standards available for doing this, such as ISO 10360-1 to 6. CMM probes are required to be calibrated because every time they are changed their position relative to the reference axis is slightly different.
P
Pro CNC
#30
We are AS9100 certified and we place much more emphasis on in-process inspection than we do final inspection. After all, you want to catch non-conformance at the source, not at the end. So we have not allowed machinists to have their own equipment. Everything is company owned and calibrated on a schedule. We came up with our own web-based quality software which tracks the history, results, calibration process, and live alerts for when it is due in the future. It helps immensely.
I am certain and auditor wouldn't go for only final inspection equipment being calibrated.
my 2 cents.
Paul
procnc.com
T Calibration and Control - Need help with plug, ring, and thread plug gages General Measurement Device and Calibration Topics 12
D Sunnen Gages - Need Operating Procedure and Manual General Measurement Device and Calibration Topics 2
S Formula for Calculating NoGo Major Diameter for UN gages Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
D Preventative Maintenance for Gages, handtools etc Other Medical Device Regulations World-Wide 1
M Procedure or Specification For Extending Gages Calibration Calibration Frequency (Interval) 2
M How to verify profile gages provided by customer General Measurement Device and Calibration Topics 5
PastorBee13 Source for the blades for Reef Snap Gages General Measurement Device and Calibration Topics 2
M AS9100 Rev D and Pin Gages General Measurement Device and Calibration Topics 7
M Calibration of Thread Plugs and Ring Gages - Various Thread Standards General Measurement Device and Calibration Topics 3
D Cp/Cpk on Gages for MSA (vs. Cg/Cgk) Capability, Accuracy and Stability - Processes, Machines, etc. 21
A Adjusting Calibration Intervals for Welding related Gages AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Calibration Recall - Lost Gages procedure example wanted General Measurement Device and Calibration Topics 4
Q Is it normal practice to lubricate Ring Gages before use? General Measurement Device and Calibration Topics 17
T How to Calibrate Taper Gages General Measurement Device and Calibration Topics 1
C Manufacturing Thread Ring Gages Manufacturing and Related Processes 3
C Measuring Solid Thread Ring Gages General Measurement Device and Calibration Topics 17
P Best Method of Cleaning of Thread Ring Gages Calibration Frequency (Interval) 5
M Control Plan MSA's - Pressure Gages IATF 16949 - Automotive Quality Systems Standard 2
C Implementing a set of bore gages at a machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
F Checking Gages In and Out and Verifying Calibration Status Calibration and Metrology Software and Hardware 8
D Calibration requirements for New Gages General Measurement Device and Calibration Topics 11
Q Number of Calibration Verification Points - Calipers, height gages, etc General Measurement Device and Calibration Topics 6
C Calibration of Master Thread Plug Gages General Measurement Device and Calibration Topics 2
C Measurements of Major Diameters of plug thread gages General Measurement Device and Calibration Topics 12
J Verification of Gages Before Use Calibration Frequency (Interval) 10
L Inexpensive Gage Management Software recommendations for less than 75 Gages Calibration and Metrology Software and Hardware 8
T How do I calibrate NPT Thread Plug Gages? General Measurement Device and Calibration Topics 9
V How to measure radius without radius gages APQP and PPAP 4
N When and which gages require a Gage R&R study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
K Calibration Requirements for Thread and Ring Gages AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
BHobbs_Busche ISO/TS16949:2009 - MSA requirements for common gages IATF 16949 - Automotive Quality Systems Standard 5
D Calibration and Tolerance Ranges of Pressure Gages General Measurement Device and Calibration Topics 8
M Calibrating Digital Pressure Gages In-House General Measurement Device and Calibration Topics 10
M Sealed in Wax Thread Gages - ISO 9001 Clause 7.6 Calibration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J Doing a "yearly" mass calibration of gages over the weekend. Any advice? General Measurement Device and Calibration Topics 4
R Recently purchased a large number of gages (measurement equipment) General Measurement Device and Calibration Topics 13
D Gage Tracking Systems - Infinity's QS GTS System and Retired Gages General Measurement Device and Calibration Topics 4
R Calibration stickers on gages or on boxes? General Measurement Device and Calibration Topics 16
R Calibration Requirements for Employee Owned Gages General Measurement Device and Calibration Topics 5
M Does 17025/NADCAP allow deferring Calibration Start Dates on Gages which are Stored? ISO 17025 related Discussions 10
K Unclean Gages affect Measurement Output General Measurement Device and Calibration Topics 5
S Pressure Gages - Equipment Tolerance vs. Product Specification Calibration and Metrology Software and Hardware 2
F Developing a Robust MSA Program - over 35,000 gages in 1 million square ft. facility Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
D Calibration Frequency of Thread Gages use for Aluminium and Stainless Steel Products Calibration Frequency (Interval) 6
E Gages on Computer Screens General Measurement Device and Calibration Topics 2
S Special Gages for Measuring Pre-Heat Treat Thread Size Measurement Uncertainty (MU) 3
CycleMike 7.6.1 - ".....type of measurements system" and Plug Go/NoGo gages IATF 16949 - Automotive Quality Systems Standard 4
U Dial Gages of all types in company flood - How to recover them General Measurement Device and Calibration Topics 6
S Selecting Wires for Measuring P.D. of Thread Gages General Measurement Device and Calibration Topics 9
