Do all non-random patterns apply to attributes and variable charts including R chart?
L
luis.armendariz
Sorry for doing this but I'm trying to open another discussion in regards with "non random patterns" but it's been impossible, there is an error stating "you must select a preffix" or something and don't know how to fix it, anyways, <Split post off into new thread. - Miner, Forum Moderator>
Do all non random patters apply to attributes charts and variable charts including R charts?
I was told that attributes charts follow a normal distribution so that's why the same rules apply, but R charts supposedly follow a Chi-square distribution which is a variance distribution, not means distribution, so I was told that the only non random pattern that apply to R charts is the point ouf of control, no runs, no trends, etc.
Is that correct?
The answer is no.
Xbar/R (or s) chart: Nelson's or Western Electric Rules apply to all three types. Btw: Nelson recommended that only the first four rules be used in all cases. Rules 5 & 6 were optional rules if earlier warning was desired. Rules 7 & 8 were only intended as diagnostic tests when the chart were first set up. They provide alerts if the rational subgroups were incorrectly set up. If multiple process streams were included within all subgroups, rule 7 will alert, and if multiple process streams are sampled sequentially between subgroups, rule 8 will alert.
XMR chart: Nelson's or Western Electric rules apply to the X chart only. Points on the MR chart are not random (e.g., one point out on the X chart means two points out on the MR chart), so the one point outside the control limit is the only rule that should be used.
Attribute chart: Typically, only the first four rules apply from Nelson or Western Electric.
Final note: The more rules that you employ, the greater the chance of a false alarm. Use only those rules that are relevant to your process. For example, if your process does not trend out, do not use the rule.
L
luis.armendariz
Do all non-random patterns apply to attributes and variable charts including R charts
Thanks for your response, now, the following question is why?
Why it is considered rules 5 & 6 a warnings and 7 & 8 only at the beginning?
On the other hand, I realize now why Minitab 16 has only the first 4 rules for attributes charts, however, I run a I-MR chart with a run and trend intentionally on the MR chart, and Minitab showed these non random patterns, see attachement. Do you know why?
Another question that I have is why AIAG SPC second edition mentions a run as 7 points in a row, while Minitab shows 9 points, I have downloaded an article from internet and mentions also 9 points in a row, what is correct?
Steve Prevette
Deming Disciple
I do disagree with the previous posts.
If you follow Shewhart's original reasoning for control charts - that they work regardless of the underlying distribution, and work due to Tchebychev's Inequality, then once you select a set of rules (and yes, they vary from author to author), you would use these rules consistently on EVERY SPC chart, regardless of distribution type.
As to the first question, that is from the words of Lloyd S. Nelson himself in a Technical Aid printed in ASQ's Journal of Quality Technology, October 1984 entitled The Shewhart Control Chart-Tests for Special Causes. The link may require membership to ASQ.
To the second question, it appears that your process is undergoing oscillations of increasing amplitude. This could be caused by some type of positive feedback whether automated or manually induced such as process tampering. To the other, Minitab applies the rules to both charts in error. See Donald Wheeler's article What Makes the XmR Chart Work?
I believe that AIAG is using the Western Electric rules, which were empirically developed. Nelson modified these rules to provide equal probability of giving a false positive alarm. Minitab uses Nelson's Rules.
P Individuals Chart for Non-Sequential Data - Random Sample without Reference to Time Statistical Analysis Tools, Techniques and SPC 4
G Dealing with non conformity caused by Supplier Components detected in the production line IATF 16949 - Automotive Quality Systems Standard 8
M Who are the go to companies for non-destructive hardness testing? General Measurement Device and Calibration Topics 3
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
A FDA guidance on non-sterile Medical Device Packaging Medical Device and FDA Regulations and Standards News 6
E Qualification for non gmp service providers Supplier Quality Assurance and other Supplier Issues 1
R MDD x PPE Directive - Statement of Non-Applicability EU Medical Device Regulations 3
B Exclusions or justification for non-applicability of IEC standards Reliability Analysis - Predictions, Testing and Standards 1
C Non-EU Language Requirements Other Medical Device Regulations World-Wide 3
A Non-Conformances Found After 3rd Party Sorting Supplier Quality Assurance and other Supplier Issues 12
T ISO 13485 8.3 - Non-Conforming Materials - on-line rework or part of process? ISO 13485:2016 - Medical Device Quality Management Systems 11
N Audit non-compliance API Q1 - Use of External Documents 4.4.4 in Product Realization Oil and Gas Industry Standards and Regulations 5
D Using non-conforming components even though the final assembly is conforming? Manufacturing and Related Processes 5
N Competent Authority notification for non-EU manufacturer EU Medical Device Regulations 4
M CE marking for NON-EU EU Medical Device Regulations 0
E Non-GMP examples in Pharmaceutical industry Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
S Non-Conformance and Deviations ISO 13485:2016 - Medical Device Quality Management Systems 4
B Risk Assessment Checklist for Non product Software IEC 62304 - Medical Device Software Life Cycle Processes 1
T Ideas for developing a Supplier Quality Management System, non automotive ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
N Audit non-compliance - API Spec Q1 9th Ed 5.6.1.2 b Oil and Gas Industry Standards and Regulations 10
R Applicability of new non-harmonized standards (MDD/MDR) EU Medical Device Regulations 8
M Scope of Combined ISO 9001 and IATF 16949 QMS - Non-automotive customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Guidance on manufacturing non-surgical face masks US Food and Drug Administration (FDA) 3
D Do non-IATF customers need to be included in audit scope? IATF 16949 - Automotive Quality Systems Standard 23
C If it doesn't prevent a non-conformance, is it a preventive action? IATF 16949 - Automotive Quality Systems Standard 13
G Addressing Non-Conformances from an Internal Audit that are not product related ISO 13485:2016 - Medical Device Quality Management Systems 11
T Non conformance product identification and traceability 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
I Non-Conformance vs OFI -- your best descriptions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 61
G Question about Non-conformances during New Product Introduction Nonconformance and Corrective Action 14
B Bioburden monitoring for surgical instrument provided non-sterile EU Medical Device Regulations 3
Y Packaging validation for non-sterile Medical Equipment Other Medical Device Related Standards 1
S Can we provide training plan as corrective action for IATF 16949 Non conformity? IATF 16949 - Automotive Quality Systems Standard 9
J Medical System with non-medical device and FCC US Food and Drug Administration (FDA) 5
L PMA and Non-PMA parts in same finished goods area? Federal Aviation Administration (FAA) Standards and Requirements 1
W Non-Conformance from recent Audit carried out on Purchasing AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
D Do purchasing controls apply to non-medical parts? ISO 13485:2016 - Medical Device Quality Management Systems 5
S Service record requirements for Non-Serviceable Medical Devices CE Marking (Conformité Européene) / CB Scheme 1
S Industry Labelling Standards - non medical Manufacturing and Related Processes 0
B Using non CE parts in a machine CE Marking (Conformité Européene) / CB Scheme 1
B To detect the non standard variable IATF 16949 - Automotive Quality Systems Standard 5
A Single use non-sterile syringe used in the oral cavity - Laboratory test advice US Food and Drug Administration (FDA) 7
K Relying on mitigations implemented in non-medical device IEC 62304 - Medical Device Software Life Cycle Processes 5
M What to do about Non Conformance forms that are deleted or missing? Nonconformance and Corrective Action 4
Marc A 20 Hour Non-Stop Flight - (October 2019) Travel - Hotels, Motels, Planes and Trains 19
C On spontaneous but non-standard rankings FMEA and Control Plans 3
N Non traumatic edge - Remark in some of my company drawings EU Medical Device Regulations 1
qualprod Internal Audits - Categories of non conformances Internal Auditing 12
C Neglect or legitimate deferral? Is excessive workload or lack of resources in a department or a team a valid root cause for a non-conformance? Problem Solving, Root Cause Fault and Failure Analysis 12
