Do CNC Machine Programs need to be Controlled Documents?
Looking for some input.
Would CNC machine programs need to be controlled documents?
Obviously the engineering drawing needs control, and the measuring instruments need control, and the process hardware needs to be capable. However since the setup is checked against the engineering drawing before running, it wouldn't seem that the CNC programs would need to be controlled.
Any Views?
DICKIE
Our CNC programs have headers which identify them just like our controlled documents. Part number, revision, author, date etc. They are also backed up on a server computer. Our autitor has audited this in the past.
Greg Dickie
>>>Our CNC programs have headers which >>>identify them just like our controlled >>>documents. Part number, revision, author, >>>date etc. They are also backed up on a >>>server computer. Our autitor has audited >>>this in the past.
Is the rev level you use the Part Rev or the program rev?
James
Low tech is better than no tech.
>>Would CNC machine programs need to be controlled documents? <<
We treat our CNC programs as controlled documents. They are backed up on a server just for all the CNC machines we have. Our programs also have part number, print revision, date, etc. to identify them as controlled. If a line is added or subtracted from the program the operator fills out a change sheet, the Super signs it and turns it in to the CNC Programmer to document the change. Changes to existing lines are not documented. After a job is done it is uploaded to a que on the server to replace the old one.
Russ
tomvehoski
Does the operator have access only to the latest revision of the program? Are they being pulled from the same server if there are multiple machines running the same program?
I have used the procedure that the responsible engineer updates the machine program and deletes the old revision. The operator only has access to the correct revision. The file server is considered the master list, showing all current revisions. Auditors have never had an issue with this.
I also had one client (EDM company) that only allowed one program to be in the machine at a time. The engineer was responsible for loading the program. This way the operator could never pick the wrong program, since there was only one (assuming the engineer downloaded the correct file).
windsal
Re: Do CNC machining programs need to be controlled documents?
Any Views?
According to AS9100B,7.5.1.3,<Production equipment, tools and programs shall be validated prior to use and maintained and inspected periodically according to documented procedures.> CNC program shall be a documented procedure. Regarding to "documented procedure", 4.2.1<NOTE 1 Where the term “documented procedure” appears within this International Standard, this means that the procedure is established, documented, implemented and maintained.>
Conclusion as above, CNC machine programs shall be controlled documents.
Jeff Frost
AS9100B Clause 7.5.1.3 requires that you have a written (documented) procedure that describes how you control numerical control programs and validate them prior to use in production. Related to the program control you will need to describe the method for the creation of a new NC program, how you validate the program, method of revision control and method use prevent the use of older versions of the program.
ISO 9001:2000 does not have this type of requirement directly stated but you must have sufficient control on NC programs to prevent the production of product that does not meet your customer’s requirements.
Caster
An Early Cover
Ever had a problem caused by the wrong version of a program? If so you may want to "control" them.
If you are feeling all proactive, you may want to do a risk assessment and look at the potential costs and do a preventive action if it seems likely to be high cost.
We've had things "go bang real good" due to a mistake in a new program. Weeks of downtime and hundreds of thousands of dollars repair costs.
Amazingly some people still don't want to bother "controlling" the programs.
Jeff Frost
One other thing to consider is potential risk to the customer related to poor revision control. If wrong revision gets on the aircraft or into manned space flight service things can go bad really fast and cost a lot of money.
E Controlling CNC Machine Programs - Your recommendations appreciated Manufacturing and Related Processes 12
R Control of CNC Machine Programs in Engineering Workshops (Aerospace, AS9100) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
B IQ/OQ/PQ of CNC Milling Machine Qualification and Validation (including 21 CFR Part 11) 2
GreatNate Qualifying a CNC machine Manufacturing and Related Processes 3
F AS9100D Process Matrix for a small cnc machine shop AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S Machine Setup for a CNC Machine Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
S Need Continuous improvement Suggestions - Small (30 of us) all-CNC machine shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
J CNC Machine Tool Calibration - 6 dof Calibration Interferometers General Measurement Device and Calibration Topics 1
P Machine Shop Tool Crib Procedure - Tooling for CNC mills Quality Tools, Improvement and Analysis 1
B SPC Software Selection for use in a CNC Machine Shop - InfinityQS and Lighthouse Quality Assurance and Compliance Software Tools and Solutions 3
K Probe on CNC machine - Inspecting on cnc machine tools vs. CMM Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Q Operational Qualification of a CNC machine ISO 13485:2016 - Medical Device Quality Management Systems 4
P CNC machine validation for Contract Manufacturer of medical devices Qualification and Validation (including 21 CFR Part 11) 1
C CNC Machine Operational Qualification Recoverability Testing Other Medical Device and Orthopedic Related Topics 1
B Is a work instruction mandatory - CNC machine ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
I CNC Machine Validation Requirement ISO 13485:2016 - Medical Device Quality Management Systems 20
J CNC Calibration - What should be calibrated on a HAAS machine? General Measurement Device and Calibration Topics 7
M Machine Tool Calibration - Machine Capability Studies on CNC Machine Tools Manufacturing and Related Processes 5
M Volumetric Positioning - Machine capability studies for CNC machine tools General Measurement Device and Calibration Topics 4
M Cost Estimating Spreadsheet for a CNC Machine & Weld Shop Manufacturing and Related Processes 8
P SPC in job shop? CNC machine producing a max of 50 pieces per job Statistical Analysis Tools, Techniques and SPC 4
D Machine Capability Studies on CNC Lathes Statistical Analysis Tools, Techniques and SPC 35
T Pin gage identification in a small CNC/Screw machine job shop General Measurement Device and Calibration Topics 9
A CNC Mill and Lathe - Validation Manufacturing and Related Processes 2
R Process Validation on CNC Lathe and Milling machining process Design and Development of Products and Processes 1
R CNC Software Validation requirements as per ISO 13485:2016 Other ISO and International Standards and European Regulations 8
A ISO 9001 Control of Production Equipment - CNC Machines ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
C O-Ring Groove Measurement Method in CNC Machined Parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
D OQ, PQ Requirement for Aerospace? Recently purchased CNC AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S FMEA for CNC Manufacturing FMEA and Control Plans 9
V Ultrasonic NDT on CNC Product made of Stainless Steel General Measurement Device and Calibration Topics 2
M AS9100 Control of CNC programs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Quality Assurance Plan template for CNC Milling Industry AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
H Control plan example format for CNC machining activities FMEA and Control Plans 3
H FMEA sample for complete CNC machining process FMEA and Control Plans 1
L Caliper Calibration Standards - One for CNC and one for Sheet Metal? General Measurement Device and Calibration Topics 9
C Equipment Qualification of a CNC Mill Center ISO 13485:2016 - Medical Device Quality Management Systems 5
P Internal Audit of CNC Programing Internal Auditing 3
S CNC Machining Process Validation for Prototypes ISO 13485:2016 - Medical Device Quality Management Systems 1
A Are CNC Program Backups Required by TS 16949? IATF 16949 - Automotive Quality Systems Standard 3
G Sampling Plan for Inspection of Metal Parts after CNC Machining Inspection, Prints (Drawings), Testing, Sampling and Related Topics 34
bobdoering Capability of new CNC machines Capability, Accuracy and Stability - Processes, Machines, etc. 32
V CNC Probe Qualification and DME Interface General Measurement Device and Calibration Topics 4
B CNC Machining Shop still heavily relies on First Piece and Final QC Inspection Manufacturing and Related Processes 5
A Engineering Production Skills Matrix for Assembly or CNC Machinists Management Review Meetings and related Processes 6
V CNC Process Validation Cpk Ppk & In-Process Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
R CNC OTS Software Validation Separate from full IQ/OQ/PQ for 21CFR Part 820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
S Receiver Gages vs. CNC CMM Checks Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
M Commercially available software solution for the control of our CNC programs. Records and Data - Quality, Legal and Other Evidence 3
