Do CTQs need to be equipment specific?
Good morning to everyone,
We have established process CTQs since few years now in my company but I was wondering if they need to be equipment specific or not.
For example, we have two reflow ovens where we introduced a CTQ to monitor the max temperature. The limits, the measurement tooling and the equiment are exactly the same for both reflow ovens. I created two different CTQs, but do I need to use two different CTQs? Or the CTQ is only one (max temp) and I can use it for all the ovens? There would be of course a different data collection for every equipment, but the CTQ would be one.
I hope my question makes sense.
Thanks!
John C. Abnet
Teacher, sensei, kennari
Good day @buralbe ;
I'm not sure what governance you are under (I assume IATF 16949 and/or your organization's own internal requirements).
IATF, for example, does not specify. Therefore, unless your organization's internal requirements specify, then it is up to you/your organization.
Be selfish. Do what is BEST and NEEDED by your organization.
It sounds to me as if the "CTQ" you are referring to are actually process controls.
Remember, however, that it sounds as if you'll be setting precedence. I would council that you determine and consider what I refer to as "control resolution" . For example, if the process controls for the type of equipment you are referring to are ALWAYS the same for that type of equipment, then to establish common/single process control by this equipment type is likely acceptable. HOWEVER, if the controls for this type of equipment may change based on the product/part numbers being produced, then the control resolution should be maintained and the PRODUCT/part number level. If that is the case (I assume it is) then I reiterate, that I would recommend establishing controls for each PRODUCT/part number.
Hope this helps.
Be well.
John, Jim,
Thanks for your answers.
I work for an Electronic Contract Manufacturer. We have several customers with different level of specifications and expectations. The most demanding customers in term of Quality use Automotive standards even if they are not Automotive.
John, Jim,
Once again, What certification is involved (ISO 9001, e.g.)? How does your company define "Critical to Quality"?
There is a lot of confusion over the usage of CTQ and not all agree. Most blur the distinction and meaning of CTQ. Your usage does this. The following is the one that I teach and feel is least confusing.
  • CTQ - The product characteristics that are critical to ensuring that the customer's needs are met
  • KPOV (Key Process Output Variable) - the associated measurable process output
  • KPIV (Key Process Input Variable) - the process parameters (e.g., temperature, etc.) that must be controlled in order to consistently provide a KPOV with minimal variation
This graphic illustrates this relationship.
John C. Abnet
I echo what @Miner points out in regards to "CTQ".
In addition, specific to an organization's internal controlled processes and documentation, I would add the following....
"If it is WRONG or GONE, can it lead to a nonconformance?"
This is an easy and memorable way to vet what is and is not critical to quality/in need of control.
For example, ....
* Sign"X" says... "turn off lights when leaving the room".: Sign "X" likely does not meet the condition for CTQ
HOWEVER,...
* Sign "Y" says ... "push this button or all parts will be N/G".: Sign "Y" does meet the condition for CTQ and control should be considered.
Hope this helps.
Be well.
Q CTC (Critical to Customer) vs. CTQs (Critical to Quality) Nonconformances Nonconformance and Corrective Action 6
K Subcontractors Providing Services Under MDD or MDR need ISO 13485 from EU Notified Body? CE Marking (Conformité Européene) / CB Scheme 3
E Need some peer advice Quality Manager and Management Related Issues 18
S Need clarification on UKCA and "Approved Body" UK Medical Device Regulations 7
S What types of changes need to be notified to NBs? Registrars and Notified Bodies 1
B Do I need a Cleanroom to manufacture Medical Devices? ISO 13485:2016 - Medical Device Quality Management Systems 2
J CMO in Canada do they need MDSAP/13485 certification? ISO 13485:2016 - Medical Device Quality Management Systems 1
M Attempting to Poke Yoke a wire crimping process...need help Design and Development of Products and Processes 3
C I need your help to find the action plan for these quality objectives Misc. Quality Assurance and Business Systems Related Topics 23
C Class 1 non-sterile device, need certified QMS or not? EU Medical Device Regulations 2
Steve Prevette I need a template to solve world hunger, a world class Quality Program, and make lots of money Coffee Break and Water Cooler Discussions 5
C Need to understand difference between an actual Calibration vs. a Calibration check General Measurement Device and Calibration Topics 3
S How many tester quantity we need on the line based on the cycle time and peak volume Manufacturing and Related Processes 3
R Need help on calibration result analysis Measurement Uncertainty (MU) 17
M Do i need to have equipment validation if 100% testing is completed? Qualification and Validation (including 21 CFR Part 11) 6
G Need Help with Run @ Rate for Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 0
F Need help in IMS management review Management Review Meetings and related Processes 3
S I need help in corrective action plan Nonconformance and Corrective Action 15
A Do clinical performance studies for IVDs need to be conducted in a member state? EU Medical Device Regulations 2
A Do clinical performance studies for IVDs need to be conducted in a member state? CE Marking (Conformité Européene) / CB Scheme 0
D Weird spec sheet - need help Measurement Uncertainty (MU) 3
E Do I need test reports for all standards mentioned in my 510k application? Other Medical Device Related Standards 8
J Japan registration need manual without temperature reading Japan Medical Device Regulations 0
Ashland78 Need IATF 16949 ISO Gap Analysis Excel File Internal Auditing 3
R Need for an Importer outside EU? EU Medical Device Regulations 0
T Do I need to add non-product related service providers to my ASL? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
K Need Help With Auditing Suppliers Against ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 50
A Need career advice on QMS & HSE (No hands on experience) Career and Occupation Discussions 6
B Need assistance with documents CE Marking (Conformité Européene) / CB Scheme 2
R Lead auditor scenario (Need help) is this non conforming to ISO13485 Manufacturing and Related Processes 2
Ashland78 Need to show evidence in accordance with QR-11012 and SPB-00001-09 Customer and Company Specific Requirements 5
E Does IVD need to integrate with hospital IT infrastructure? Medical Information Technology, Medical Software and Health Informatics 2
U Need Help With API Q2 Quality Manual Oil and Gas Industry Standards and Regulations 8
S In Need of GIDEP Guidance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M Do employee training records need to be controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D What evidence do I need to supply as a remote location in relation to manufacturing sites? IATF 16949 - Automotive Quality Systems Standard 14
T Non API products need to comply to API Q1? Oil and Gas Industry Standards and Regulations 3
G Need journal and reference of abnormal bar chart SPC Statistical Analysis Tools, Techniques and SPC 4
MSeibert47 Daily Quality Topics - Need Ideas Please! Food Safety - ISO 22000, HACCP (21 CFR 120) 18
W Do Reference materials for IATF need to be 17025? IATF 16949 - Automotive Quality Systems Standard 15
D Need some Help on 8D fault tree analysis Problem Solving, Root Cause Fault and Failure Analysis 6
A Need to calculate tolerance Intervals with a set of non-normal data and 3-Parameter Weibull distribution Using Minitab Software 0
Melissa Risk Management Process, How far do I need to go? ISO 14971 - Medical Device Risk Management 13
F Need Quality Manager advice. Quality Manager and Management Related Issues 6
T Do we need an SOP for ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
K Do Contract Manufacturers need a complaint procedure? Medical Device and FDA Regulations and Standards News 10
K Screen printing ink and machine selection_ Need help Manufacturing and Related Processes 6
D Do employee training records need to be centralized? IATF 16949 - Automotive Quality Systems Standard 10
H Need of EU Representative Designation for Turkey? EU Medical Device Regulations 3
H If we use agile - do we still need to document TF as a waterfall just for the notified bodies need? IEC 62304 - Medical Device Software Life Cycle Processes 2
