Do desktop calendars need to be calibrated?
P
pcsmith
#21
Why would a calendar from the wrong year be on a desk? If the process is THAT important that someone thinks the calendar should be 'calibrated', I can't imagine they'd still have one from last year.
If it is important, just verify against someone elses calendar every day and have them initial each date verified on the paper calendar.
jrcook5
#22
The calendar represents time just like a clock does excepte larger increments and many folks calibrate their clocks.
BradM
#23
I think I may know what the OP is asking. If so, not a bad question...
The same logic (if it's the same) would apply to a tape measure. How do you know the length on the tape measure is acccurate? Just because it displays an inch, how do you know it's an inch? It might be 1.2 inches.:)
So akin to that, how do we know that the days and dates printed on a calendar are correct?
My response would still be there is no needed verification. However, if it is important to a process, then randomly pick months and days in the months, and verify against another standard.
I would think the western calender is a generally accepted standard.:)
BradM
#24
Not necessarily. A calendar does not measure or assess time, or the passing of time. It merely represents numbers and word designations of blocks of time. If today is Tuesday, one week from now will always be a Tuesday. Always.
A clock is a different matter. One can assess that a clock is accurate to World Time. A clock accumulates a maximum amount of error over an hour, a day, etc. That error may affect a timed process.
True Position
#25
It's not hard to calibrate them, set them on an annual schedule and write the procedure as verification directly to NIST via www.time.gov or call the NIST time phone number(303-499-7111).
Big Jim
#26
This phrase, from ISO 9001:2008 element 7.6 just before the a-f portion, should be memorized by all that work in an ISO 9001:2008 environment.
"Where necessary to ensure valid results . . . "
Figure out if a calibrated calendar is necessary for valid results and you should have your answer.
I'm having trouble imagining a circumstance for which it would be necessary, but I'll keep an open mind if the OP can explain the need.
You also need to address if a calendar is monitoring and measuring equipment.
I'm all ears.
RDQuality
#27
Do desktop calendars need to be calibrated? I was asked this question but did not have an answer. Any takers???:
:eek::confused:
(1)Is the calendar used in anyway that would affect the quality of the product? (2)Is the calendar used to record the date on required records? (3)Is traceability a requirement? (4)Is the calendar electronic?
If the answer to the above four questions is NO, then calibration would not be required. If the answer to all four questions is YES, then the calendar should be calibrated. If the answer to questions (2), (3) and (4) is YES, then the calendar should be calibrated.
If the answer to questions (2 ) and (4) is yes, refer to section 8.2.4 of the ISO 9001-2008 standard. An argument could be made either was as to whether a date is required on records. Good practice would be to record the date in which case the calendar should be calibrated.
I hope this helps.
jrcook5
#28
Brad, you may be the genius I have been looking for. Is there in existence, a common sense standard that is applicable to cases like the calendar and the wall clock?
Is it in fact true, even though I look at the calendar to ensure I have the correct date to put on my report, common sense, ease of verification, and the low probability of error, are collectively sufficient to allow me to forego a formal calibration on the trusty old almanac.
What is this convention called and can it be used instead of the previous standard which also remains unnamed however it gets applied everywhere and anywhere confusion surfaces regarding the necessity to cal or don’t cal. I vaguely recall it being something like; if it affects quality or you don’t know enough about it to explain it to an auditor then obviously it requires calibration.
As you can plainly see, I need help…
#29
What we don't know at this point is why you asked specifically about calendars (frankly, a silly question) in the first place. What do you want to know? ISO 9001:2008 says that calibration must be done when calibration is needed to ensure valid results. What this means is that if a measuring device is used in situations where calibration would provide greater assurance of valid results and a relatively high level of confidence is necessary or prudent, the thing should be calibrated. If, on the other hand, calibration won't add anything useful, it's not required. In the latter case, it should be a simple matter to explain the rationale.
#30
following Jim's lead: it would be helpful if you (the OP) could provide context for your question. The standard itself gives you the common sense answer you are looking for. In oder to help you frame a logical answer we really need to know the context of the original question.
T Biocompatibility for "Desktop" used Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 4
F Additional Isolation Required? Doppler Probe Desktop Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
H Supplier Audit (Desktop) Issues Supplier Quality Assurance and other Supplier Issues 19
C Desktop Assessment Criteria for Part 145 Certification EASA and JAA Aviation Standards and Requirements 3
JoCam Budding Consultant: What to charge for performing a desktop study. Career and Occupation Discussions 10
T Suggestions on collaboration tool or remote desktop software needed After Work and Weekend Discussion Topics 1
Q Customer Care Quality Assurance Plan in a Small Computer Desktop Assembly Company World News 6
V What Desktop Icons do at Night Funny Stuff - Jokes and Humour 8
Q Desktop Icon Settings After Work and Weekend Discussion Topics 3
D Customer Network and Desktop Support - Master Product History ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Marc The Future of the Linux Desktop? DirectFB After Work and Weekend Discussion Topics 0
Marc Go Linux Desktop Now After Work and Weekend Discussion Topics 0
J Need a contract monitoring Tool General Information Resources 0
P UDI-PI requirements on reusable surgical device, do we need serialisation? ISO 13485:2016 - Medical Device Quality Management Systems 0
W 17025 and NIST handbook relationship (need advice) ISO 17025 related Discussions 8
K Need procedure for D&D inputs? ISO 13485:2016 - Medical Device Quality Management Systems 4
S Need help on "Country of Origin" Medical Device and FDA Regulations and Standards News 0
Ed Panek Immediate need for 80601-2-56 Consulting expert. PM me for details Career and Occupation Discussions 0
Tagin You're Gonna Need a Bigger Root Cause Coffee Break and Water Cooler Discussions 12
M PSA Suppliers - CSR matrix and need the quality manual of PSA APQP and PPAP 2
K "World Class Product" based QM. I need advice. Quality Management System (QMS) Manuals 14
I Do I need to sign off my annual audit calendar? Internal Auditing 2
P Do we need to retrospectively use the "MD" symbol (indicating device is a medical device) on labels, e.g. finished devices within expiration date? EU Medical Device Regulations 2
M Do I need separation in my circuit with a medical charger? IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
V Certified Auditor - Need of additional certification specific to industry ( GMPs) ASQ vs ECA vs others Professional Certifications and Degrees 1
D Low risk IVD study in the UK, do I need MHRA approval? UK Medical Device Regulations 1
J Do Software Subcontractors need to be ISO13485 compliant in the EU? EU Medical Device Regulations 3
K Do I need a "State of the art" plan? CE Marking (Conformité Européene) / CB Scheme 1
S Need advice for schooling Quality Manager and Management Related Issues 5
R What information do i need to get from the device manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
S Need guidance on project ISO 13485:2016 - Medical Device Quality Management Systems 2
J Need Change Control Yes/No Decision Tree Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Does an accessory need an IFU if it use is discussed in the Parent device IFU? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
B Countries with no need for FSC (Free sales certificate) Other Medical Device Regulations World-Wide 0
R The term "Benefit Risk Ratio" in EU MDR, do I need to present benefit risk analysis as a RATIO Risk Management Principles and Generic Guidelines 4
A Brexit When does the UK responsible person need to be in place? UK Medical Device Regulations 10
N IPC-A-630 - Is this free or do i really need to pay for it? Manufacturing and Related Processes 4
P Need a programmer for QVI's VMS software for optical inspection machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
silentmonkey How to decide what characteristics need to be verified during incoming inspection? ISO 13485:2016 - Medical Device Quality Management Systems 5
T Do I need a qualified compiler for class B software? IEC 62304 - Medical Device Software Life Cycle Processes 3
