Do Engineering Standards require periodic review? ISO 9001 4.2.4 (b)
RosieA
4.2.4 (b) requires that controlled documents that are required by the quality system be reviewed and updated as necessary and re-approved.
Engineering Standards in my organization are controlled documents required by the quality system, but have no periodic review time. All other documents in our QMS are looked at every 2-5 years to ensure that they remain current.
Our Engineering manager maintains "Any changes are handled with a formal change notice process and then reissued. Again no reviews are done or required after the design has been developed. The ISO standards do not require it."
As these documents are used to purchase components, manufacture product and package product, it seems to me that a periodic proactive review is needed to ensure that the standards remain consistent with design and manufacturing changes and external industry standards.
As a side note, our internal employee corrective/preventive action process identifies 6-8 errors per year on these standards.
Comments, please?
Re: Do Engineering Standards require periodic review?
Comments, please?
What's an "engineering standard"? Something developed in-house, or something like an ASTM or SAE standard? If it's the former case, are we talking about product-specific standards, or general standards that are used for all (or most) products?
RosieA
Engineering Standards are created by our Engineering Dept. and fall into several categories.
1. Raw material specifications, often based on Industry Standards;
2. Product processing How tos, like: How to Heat Treat a certain grade of Steel, or how to perform a stamping operation; (again, sometimes case don industry standards)
3. Determination of product conformance, like visual inspection criteria;
4. Directions for finished product packaging to prevent damage.
Does that explain it better?
Yes. :D
A lot depends on how many documents there are--if there are hundreds of them (or even thousands), review of all of them periodically might not be practical. It might be helpful to get rid of some of them. For example, there's almost never a need for having your own material standards because there are published standards that cover the requirements adequately. Your #2 and #3 categories fit better in the idea of work instructions (it seems) and thus those should probably be reviewed on a regular basis, perhaps as part of internal audits. #4 (packaging specifications) shouldn't need to be reviewed once it's established that the specified packaging is adequate, imo.
Randy
Actually it's 4.2.3..... b) to review and update as necessary and re-approve documents,..... (in ISO 9001:2008 & 9001:2000, 4.2.4 doesn't have any lower case requirements)
And the key phrase is "as necessary", so the answer could be yes or could be no.....
It just depends on when and why it may become necessary.....
JaneB
The first sentence sounds fine... but the 2nd seems to contradict it! As for the 3rd - I'm not sure what he means there - can you explain?
I would have thought it reasonably important to make sure that the documents are up to date - but the degree of risk involved, as well as practicality (eg, numbers of docs must be factors)
How serious are the errors? What are the costs, effects, impacts? (real or potential)?
RosieA
Randy, I understand your point. My problem is that I'm not getting any rationale for why it isn't necessary. As an auditor, would you accept the answer "it isn't necessary" without having a reason?
The only thing I've heard is, "there's too many documents" and "no other engineering group in the comapny is doing this".
Neither seem like real valid reasons to me.
I'd like to see any document over 10 or 15 years old be reviewed, no matter what it relates to, because time changes things. For example, there are references in the Engineering Standards to industry standards that have been withdrawn or replaced. There are standards for products we no longer make and raw materials we no longer buy.
On the other hand, if I'm being too strict in my interpretation, that's good to know also.
Randy
How often is the US Constitution reviewed and/or revised? Only when it's been necessary. It's over 200 years old and still works doesn't it? (Rhetorically speaking) As long as it's working why review it?
The Constitution is under constant review. Ever hear of these folks?
Revision36 Engineering Change Order Industry Standards Other Medical Device and Orthopedic Related Topics 4
jkuil Cleanroom Equipment and Furniture Engineering Standards Other Medical Device Related Standards 2
M Referencing Standards in Engineering and Regulatory Documents Other ISO and International Standards and European Regulations 1
S IPC 620 Standards vs. Company Engineering Drawings (Prints) Various Other Specifications, Standards, and related Requirements 3
A Where can I find the most up-to-date and current engineering standards? IATF 16949 - Automotive Quality Systems Standard 3
D What standards apply to engineering design and drawings? Design and Development of Products and Processes 14
Marc Engineering Technician - Suspense 5 April 2021 Job Openings, Consulting and Employment Opportunities 0
Marc Engineering Technician - Suspense 11 February 2021 Job Openings, Consulting and Employment Opportunities 0
Bev D Essential References for Practical Quality Engineering Misc. Quality Assurance and Business Systems Related Topics 0
D ECO (Engineering Change Order) process questions ISO 13485:2016 - Medical Device Quality Management Systems 7
D Engineering Change Order (ECO) metrics to track ISO 13485:2016 - Medical Device Quality Management Systems 6
J UCLA extension Medical Device Engineering Program Training - Internal, External, Online and Distance Learning 0
G Engineering retest in line - Machine stability issues IATF 16949 - Automotive Quality Systems Standard 8
A FDA and NB audit of Engineering Drawings in DHF and DMR. Medical Device and FDA Regulations and Standards News 1
I Good resources for learning statistics (quality engineering related) Statistical Analysis Tools, Techniques and SPC 10
B Lessons Learned Implementing ISO 50001 (Chemical Engineering Progress) Other ISO and International Standards and European Regulations 0
G Engineering Specifications - APQP APQP and PPAP 5
O Vendor vs Engineering Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C E signatures on Engineering Change Notes AS9100 / AS9116 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Icy Mountain Engineering Change Order...Modification Order Document Control Systems, Procedures, Forms and Templates 18
J Implementing Machine Replacement Part Reverse engineering technology Manufacturing and Related Processes 3
T Why do most companies have Quality reporting to Engineering or Operations and not to CEO? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 45
I Document templates required for ISO ISO 45001 - Engineering Construction company Occupational Health & Safety Management Standards 5
R The alignments and contradiction in Quality Engineering and management between the Automotive and Aerospace industry AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
D Engineering Drawing Review and Approval Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
V Thinning percentage in sheet metal forming per SES (Suzuki Engineering Standard) Manufacturing and Related Processes 1
P Usability/human factors engineering requirement (standard) for IVD medical device Other Medical Device Related Standards 2
R Creating WIs for a Heavy Civil Engineering Services company Document Control Systems, Procedures, Forms and Templates 19
S Ballooned Drawings and Engineering Changes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
J Class 1 Medical Device ECR (Engineering Change Request) Changes 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
P Tactics to work with Design Engineering on CAR Nonconformance and Corrective Action 3
D Are detailed engineering requirements Design Inputs or Design Outputs 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 14
2 First Article Requirements for Revision Changes of Engineering AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S Engineering change order versus a design change request ISO 13485:2016 - Medical Device Quality Management Systems 1
C Applicability of ISO 9001:2015 Section 8.5 - Engineering company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T Setting up a quality department in an Engineering Firm Quality Management System (QMS) Manuals 11
C ISO 9001 2015 Documentation for Engineering and Design ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
I Engineering Drawing = Record or Document? Document Control Systems, Procedures, Forms and Templates 8
G ISO 9001:2015 8.3 Design and Development (in Civil Engineering) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
G FAI (First Article Inspection) Responsibility - QC or Engineering? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Q M-282 - Engineering Standard for Tolerances - Is it ASTM, DIN? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
L Supplier Revision Confirmation of Received Engineering Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Document Control Guidelines in Engineering Projects - Excel sheets with VBA coding Document Control Systems, Procedures, Forms and Templates 3
A Software Suggestions for Engineering Change/QMS Design and Development of Products and Processes 2
M New MHRA guidance on Human Factors - Usability Engineering IEC 62366 - Medical Device Usability Engineering 1
S Process Map for an Engineering Consulting Firm Process Maps, Process Mapping and Turtle Diagrams 6
S Quality Measure for Engineering Services Misc. Quality Assurance and Business Systems Related Topics 1
G Senior Project for BS Mechanical Engineering Student Career and Occupation Discussions 4
L BSI White Paper on Human Factors/Usability Engineering IEC 62366 - Medical Device Usability Engineering 12
