Do HF accessories require EMC testing according to IEC 60601-1-2?
thesmyle
#11
Ascherp,
When you verified your accessory with FDA-cleared ESU, did you perform all testing (IEC 60601-1-2 and -2-2) or just partial. What was the EMC report like? engineering data or an official test report?
Thank you
-mark
ascherp
#12
Testing was partial: 60601-1-2 Clause 6 and CFR 47 Part 15.
As to the information submitted, since the request came at a very advanced stage of 510k review, the FDA accepted a Declaration of Conformity ("Device will conform before marketing to all relevant requirements of the standard...") in lieu of testing information. The Declaration of Conformity was only to IEC 60601-1-2.
For IEC 60601-2-2, we submitted the FDA's Standards Data Report for 510(k)s and a summary of the testing performed in the text of the 510(k). Neither data nor lab reports were necessary.
For current EMC testing requirements, the best place to look probably is the Draft Guidance for Electrosurgical Devices issued by the FDA in March 2014, which goes into some detail on the subject.
ascherp
#13
Premarket Notification [510(k)] Submissions for Electrosurgical Devices for General Surgery - Draft Guidance for Industry and Food and Drug Administration Staff. Date of issue: March 24, 2014
Peter Selvey
#14
I had a look at the March 2014 Guide.
For accessories, the key paragraph is Section XII:
If your submission is for a specific component of the electrosurgical device, you are still expected to evaluate your component while connected to other components of the electrosurgical device and consistent with how you intend or expect your component will be used.
The guide uses "component" to mean both accessories and the ESU unit, while "device" means the whole system, which is a bit confusing. So the paragraph applies equally to the unit as well as accessories. Also the paragraph appears in a section which covers both electrical safety and EMC. It comes after a paragraph on EMC, so a reader could assume the context is just EMC, but a proper reading covers both electrical safety and EMC.
So in other words, it is a fairly wide requirement, saying that if the submission is for any single component in the system, you should consider system issues as well.
That said, engineering common sense should still apply in selecting which requirements apply to which parts in a system. For electrical safety, for example, there are several tests on accessories which are reasonable, for example HF/mains dielectric strength, HF leakage etc.
For EMC though, it is 100% clear that tests are not required on simple accessories such as cable or electrode.
Yes, these kind of accessories can certainly influence the EMC result, but the source of the emission is the ESU unit, not the accessory.
Unless there is a contractual relationship between the manufacturer of the accessory and the ESU unit to report changes and exchange design information, any tests done by the manufacturer of the accessory are meaningless, because they have no control over design and production of the ESU unit, nor do they have the information about the internal design to know what are the worst case conditions, settings, mode etc, nor are they able to assess immunity without the designer's technical information and risk management file.
The ESU unit manufacturer is free to make changes at any time, and they are responsible to re-evaluate EMC after any changes. As the guide suggests, they should consider tests with a variety of accessories to represent the range expected in normal use.
But the manufacturer of the cable or electrode is unable to know what changes were made. It is a completely unacceptable for the FDA to insist on these tests.
I sure that any FDA reviewer asking for EMC tests on a cable or electrode is just working off a script without thinking, and they are sure to see common sense once explained.
ascherp
#15
I agree with everything you say, Peter. Thank you for your detailed analysis.
The FDA script is unfortunately followed to the letter by many reviewers, no matter how sound the applicant's reasoning. But people change, so it's always worth a try! :)
L Programmer accessories classification EU Medical Device Regulations 0
E Configurable/Custom made or accessories? EU Medical Device Regulations 0
D Class IIB Medical Device Accessories - OTS Tablets Other Medical Device Regulations World-Wide 1
A Packaging device with accessories already on the market Other Medical Device Regulations World-Wide 0
R An indication that the device is a medical device (MDR, Annex 23.2q) - applicable for accessories? EU Medical Device Regulations 5
S How to register class IIA medical device accessories EU Medical Device Regulations 1
J Are DAM tools, Mobile application, clinical dashboard, etc. considered accessories to medical device or supportive functions? Manufacturing and Related Processes 4
N Question on creepage/clearance requirements for HF Active Accessories for 2nd edition 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M OTS (Off-the-shelf) Medical Device Accessories - Camera EU Medical Device Regulations 1
B Marking of Medical Electrical equipment and accessories - Cl. 7.2.2 "Identification" and Cl. 7.2.4 "Accessories" IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
DitchDigger UDI, Labeling Accessories, General Insanity, Etc. US Food and Drug Administration (FDA) 1
K Medical Device Symbol(s) on Accessories EU Medical Device Regulations 28
M Informational FDA Classifies Suitable Accessories into Class I as Required by the FDA Reauthorization Act of 2017 Medical Device and FDA Regulations and Standards News 0
D Example for Accessories of "Annex XVI non-medical devices" and how to classify it now with respect ot EU MDR Other Medical Device Regulations World-Wide 1
M UDI labeling MDR requirement for reusable medical device accessories EU Medical Device Regulations 12
E IEC 60601-1-2 compliance for accessories - Electromagnetic compatibility of the ME system IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Medical Device Accessories - Health Canada - CMDR Section 21 Canada Medical Device Regulations 1
shimonv Summary of FDA Guidance on “Medical Device Accessories” (Dec 2016) Other US Medical Device Regulations 1
M CE Scope on Medical Device & Device Accessories to the Foley Catheter CE Marking (Conformité Européene) / CB Scheme 2
H When are Medical Device Accessories MD's? Other Medical Device Regulations World-Wide 8
A Hundreds of Medical Devices & Accessories - 3 DHF's? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
R Medical Device Accessories vs. Detachable Parts IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
J 510k file requirements for non-sterile medical device accessories 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
B Applications required for main accessories (electrodes) of CE Medical Products EU Medical Device Regulations 4
D Separate Classifications for Medical Device Accessories EU Medical Device Regulations 2
M Who is the Manufacturer - Medical Device Accessories? EU Medical Device Regulations 6
M Providing accompanying Medical Device Accessories CE Marking (Conformité Européene) / CB Scheme 2
R RoHS Medical Devices: Application to Accessories, Components and Non-EE parts CE Marking (Conformité Européene) / CB Scheme 10
A Classification of Medical Device Accessories 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
I CE Mark of Aviation Maintenance Trailer with Elevation Accessories (Jacks) CE Marking (Conformité Européene) / CB Scheme 2
R RoHS for Medical Devices - Does the directive apply to non-EEE accessories? RoHS, REACH, ELV, IMDS and Restricted Substances 1
Q Technical File for Medical Device Accessories CE Marking (Conformité Européene) / CB Scheme 4
S OEM Supplier of Accessories Registration and 21 CFR 820 QSR Controls Applicability 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
N Dental Implants and their Accessories - CE Mark Conformity Assesment EU Medical Device Regulations 3
G Medical Device Accessories (e.g.: ECG Patient Cables) - Traceability Requirements ISO 13485:2016 - Medical Device Quality Management Systems 2
S Do HF Accessories need to perform a Risk Management Process of 60601-1:2005? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A Selling Medical Devices and/or Accessories Online US Food and Drug Administration (FDA) 11
A Customized Medical Device Accessories for Research Purposes Only EU Medical Device Regulations 14
T Device Master Record For Medical Device Accessories ISO 13485:2016 - Medical Device Quality Management Systems 2
S Re-selling off-the-shelf (OTS) accessories for medical devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
H ISO10993 Requirements for Accessories Other ISO and International Standards and European Regulations 2
P Accessories or Spare Parts need CE MARK? Breast Pump Feed Containers EU Medical Device Regulations 2
D Confused about registration scope - Engine accessories supplier IATF 16949 - Automotive Quality Systems Standard 3
Marc GGG-G-15 - Gage Blocks & Accessories - Cancelled July 1999 General Measurement Device and Calibration Topics 0
W States that require service provider to have state license Medical Device and FDA Regulations and Standards News 0
E Our company is planning to file MDD not MDR next month. Do we require to show chemical characterization report ? CE Marking (Conformité Européene) / CB Scheme 2
A Does AS9100 require traceability to operators performing the work? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Y When will Notified Bodies require MedDev manufacturers to fully implement ISO 14971:2019? ISO 14971 - Medical Device Risk Management 1
qualprod When to write up a nonconformance and require a NCR - We produce labels ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
