Do I need a Cleanroom to manufacture Medical Devices?
J1980b
Good day to you all,
I have a simple question but I can't seem to find a definiate answer anywhere.
To manufacture medical devices, do I need a cleanroom?
In other words will a simple controlled area be sufficent, for certain products? For sterilisation purposes I can still account for Bioburden levels.
Thanks you
G
Gert Sorensen
Re: Do I need a cleanroom?
If you need to supply your products sterile then you need to have a cleanroom.
If you can already account for bioburden then you must have something that resembles a cleanromm already, right?
somashekar
Thanks you
Your simple question has no simple answer.
For that reason you have what we call risk management, which when done scientifically, will answer your own question.
What is the outcome of your risk management ?
Your control of risk not only will answer YES or NO to this but will further also answer what class of clean room you will need.
So answer will be DETERMINE YOURSELF ~~~
MIREGMGR
"Cleanroom" doesn't have a universally agreed meaning. If you already are achieving consistently controlled and sufficiently low bioburden levels (i.e. not exceeding some upper threshold, every time), you already have an environmentally controlled area.
The "controls" for instance might be secondary to other purposes, i.e. your whole factory is maintained at that level of cleanliness for other reasons. That's fine...there's no requirement that controlled bioburden be achieved via capabilities put in place specifically for that purpose. All that matters is the result, and perfect consistency.
If your present bioburden level and character is consistent with the capability of your sterilization process and the other requirements of your product (i.e. implantables and fluid contact devices have pyrogenicity requirements, etc.), you're already where you need to be. If not, you may have to step up your game to achieve more cleanliness. If the only way to assuredly get and perfectly consistently maintain the level of cleanliness you need is to create a purpose built space, so be it.
Bottom line: it's results that matter. There is no requirement to have a cleanroom unless you need one to achieve the required results, which are a requirement.
Ronen E
Problem Solver
Moderator
@ J1980b - Please note that some sorts of medical devices / applications may be adversely affected by the presence of non-viable particulate matter; hence, a controlled "cleanroom" environment (e.g. ISO 14644 class 8 etc.) may be important for other-than-bioburden-control purposes.
J Need for a cleanroom in the manufacture of a medical device for a clinical trial EU Medical Device Regulations 4
S Need ISO 15189:2012 Documentation toolkit. Document Control Systems, Procedures, Forms and Templates 0
J Need a contract monitoring Tool General Information Resources 0
P UDI-PI requirements on reusable surgical device, do we need serialisation? ISO 13485:2016 - Medical Device Quality Management Systems 0
W 17025 and NIST handbook relationship (need advice) ISO 17025 related Discussions 8
K Need procedure for D&D inputs? ISO 13485:2016 - Medical Device Quality Management Systems 4
S Need help on "Country of Origin" Medical Device and FDA Regulations and Standards News 0
Ed Panek Immediate need for 80601-2-56 Consulting expert. PM me for details Career and Occupation Discussions 0
Tagin You're Gonna Need a Bigger Root Cause Coffee Break and Water Cooler Discussions 12
M PSA Suppliers - CSR matrix and need the quality manual of PSA APQP and PPAP 2
K "World Class Product" based QM. I need advice. Quality Management System (QMS) Manuals 14
I Do I need to sign off my annual audit calendar? Internal Auditing 2
P Do we need to retrospectively use the "MD" symbol (indicating device is a medical device) on labels, e.g. finished devices within expiration date? EU Medical Device Regulations 2
M Do I need separation in my circuit with a medical charger? IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
V Certified Auditor - Need of additional certification specific to industry ( GMPs) ASQ vs ECA vs others Professional Certifications and Degrees 1
D Low risk IVD study in the UK, do I need MHRA approval? UK Medical Device Regulations 1
J Do Software Subcontractors need to be ISO13485 compliant in the EU? EU Medical Device Regulations 3
K Do I need a "State of the art" plan? CE Marking (Conformité Européene) / CB Scheme 1
S Need advice for schooling Quality Manager and Management Related Issues 5
R What information do i need to get from the device manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
S Need guidance on project ISO 13485:2016 - Medical Device Quality Management Systems 2
J Need Change Control Yes/No Decision Tree Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Does an accessory need an IFU if it use is discussed in the Parent device IFU? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
B Countries with no need for FSC (Free sales certificate) Other Medical Device Regulations World-Wide 0
R The term "Benefit Risk Ratio" in EU MDR, do I need to present benefit risk analysis as a RATIO Risk Management Principles and Generic Guidelines 4
A Brexit When does the UK responsible person need to be in place? UK Medical Device Regulations 10
N IPC-A-630 - Is this free or do i really need to pay for it? Manufacturing and Related Processes 4
P Need a programmer for QVI's VMS software for optical inspection machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
silentmonkey How to decide what characteristics need to be verified during incoming inspection? ISO 13485:2016 - Medical Device Quality Management Systems 5
T Do I need a qualified compiler for class B software? IEC 62304 - Medical Device Software Life Cycle Processes 3
E 13485:2016, Sections 4.1.6, 7.5.6 and 7.6 - Validation of Software - Need some Advice please ISO 13485:2016 - Medical Device Quality Management Systems 3
C ISO 13485 :2016 - CAPA - Does every CAPA need to be checked by regulations? ISO 13485:2016 - Medical Device Quality Management Systems 9
L Proof of Concept Studies - Do we need to comply with SAE reporting? Medical Device and FDA Regulations and Standards News 3
gunnyshore Adding a new facility - do I need to submit an amendment to the MDL or MDEL, or both? Canada Medical Device Regulations 3
N FDA UDI - Label vs. Labeling - Does the insert need to include UDI? Other US Medical Device Regulations 1
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
A Demonstration of Equivalence - Need for comparing biological characteristics for an SamD EU Medical Device Regulations 1
G Need to change KPI we called NC parts (maximum 3%.) to FTQ (first time quality) IATF 16949 - Automotive Quality Systems Standard 4
W Need for current design or process control FMEA and Control Plans 2
L Turkish Requirements - Does the Software need to be translated? CE Marking (Conformité Européene) / CB Scheme 2
