Do I need a Procedure for Each Process? And the Interaction of Processes - TS16949
Marc
#11
Re: Do I need a Procedure for Each Process?
I only know the process map to identify the interact of processes (Mandatory).
Technically you can describe the interaction of processes with a text description. A Process Map is just a Flow Chart derivation that makes it 'easier' for someone to visualize.
Johnson
#13
I would suggest that written procedures or process should exist at least for main processes as a clear evidence to show the system is in place. If you don't have a written procedure, it is difficulty to control that every related person is on the same boat. Especially when the process is complex and the personnel turn over rate is high. Though ISO 9001 and ISO/TS16949 require several written procedures but that's only minimum requirement.
Johnon Shao
Helmut Jilling
Auditor / Consultant
#14
Which tools?
The standard does not mention that process maps are required.
You can do diagrams, flowcharts, circles connected with lines, photographs, post-it notes, spagetti diagram, Turtles. You can also describe it with narrative text, describing how the pieces work together. There are surely other methods as well.
I certainly like flowcharts and process amps, but the standard leaves it flexible to allow each organization to select the methods best suited for its processes.
PS: a lot of companies will use different methods for different processes. For example, a linear production process lends itsef well to a flowchart. But some non-linear processes look silly on a flowchart and do much better in a diagram or narrative.
Jen Kirley
Quality and Auditing Expert
#15
I agree, though I have stayed away from post-it notes...:D
Since I've seen many cases where a process is split off into perhaps four procedures, my process maps and flow charts have included references to the governing document within the process step blocks. In a flow chart with more detail I may include the document's element number and a quick description of the task, but the element number is included mostly for my own use in auditing because that level of detail might not be desirable in most day-to-day cases.
In regulatory environments or when exacting details must be adhered to unfailingly or else, a flowchart with such an approach might be good for both the process document and at the workstation(s). I say might because it's really up to the organization to decide what mix of tools is best for them and how many procedures to write beyond the required number.
Helmut Jilling
#16
Sounds like a very nice approach.:applause:
jrubio
#17
H
hutchinson
#18
procedures are more useful,but I think you need just 7 procedures necessarily,organisition's need is the first.
I
IngridD - 2012
#19
Re: Do I need a Procedure for Each Process? And the Interaction of Processes - TS1694
hello,
I want to go more specific, who has thoughts about this:
TS 16949 paragraph 7.5.1.4 (maintenance) sais
".... as a minimum the system shall include the following:
* planned maintenance activities
* packaging and preservation of equipment and gauging
* availability of replacement parts for key manufacturing equipment
* documentation, evaluation and improving maintenance objectives ......."
QS9000 sais:
"....at a minimum, this system shall include:
* a procedure that describes planned maintenance activities
* schedules maintenance activities
* predictive maintenance methods......"
Note the difference in the first bullet for both specifications. TS does not mention a procedure!!!How should this be interpreted.
Up to know, we have the instructions (how do we do it), control charts, planning etc. We do not have the procedures (who does what when), ref other threads.
I strongly feel that with TS we can leave the procedure out, where with QS is was mandatory.
Who has ideas/experience about this???
Ingrid:confused:
Stijloor
#20
hello,
QS9000 sais:
Ingrid:confused:
Hello Ingrid,
Leuk om iemand uit Nederland te ontmoeten hier.
ISO/TS does not require a procedure for this. If you have all the required and necessary provisions in place, and you can demonstrate that the maintenance process is effective (i.e.: no unplanned downtime), than you're good to go. Remember that ISO/TS is a lot more about process performance than "paperwork." A great improvement over QS 9000.
Hope this helps.
Stijloor.
L Do we need a seperate procedure for each ISO 14001 sub clause? ISO 14001:2015 Specific Discussions 8
K Need procedure for D&D inputs? ISO 13485:2016 - Medical Device Quality Management Systems 4
S Do we need separate stand alone procedure for Suspect Unapproved Parts? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
L I need an example rework procedure/instruction for injected plastic parts Document Control Systems, Procedures, Forms and Templates 2
J Recycling Procedure (ISO9001) - Do I need a documented process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
T Need help developing an ECO (Engineering Change order) procedure Document Control Systems, Procedures, Forms and Templates 3
C Does every procedure need to be included within a policy? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B Developing a Queue Management Procedure - Need some help writing a Proposal Quality Manager and Management Related Issues 2
Z Does this Process need an established Documented Procedure? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q Need a new CA/PA Procedure to better interface with Portal Systems Nonconformance and Corrective Action 9
G Change of procedure for handling new projects - do the ongoing ones need to follow? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Need Help with procedure on Metcal Calibration and Metrology Software and Hardware 9
S Do we need to have enough documents to support APQP procedure? APQP and PPAP 10
A Do you need a separate procedure for the 6 mandatory procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Does a Procedure need to have a metric assigned to determine its effectiveness? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Batch or Lot release in to market - Need product release procedure Document Control Systems, Procedures, Forms and Templates 3
C Need a procedure or outline on Good Practices for Completing Quality Records/Document Document Control Systems, Procedures, Forms and Templates 2
D Do I need a Procedure on Legal Requirements? Regulated Insurance Sector ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
E Do I need a procedure for the procedure's template??? Document Control Systems, Procedures, Forms and Templates 10
T Changes to document control procedure - need review Document Control Systems, Procedures, Forms and Templates 4
K Need DETAILED Procedure Template for Dental Insurance Co. Document Control Systems, Procedures, Forms and Templates 21
T ISO 17025 Validation Procedure - Need Example ISO 17025 related Discussions 11
Crusader Spill Containment Procedure template - Need example Miscellaneous Environmental Standards and EMS Related Discussions 12
Howard Atkins What does the internal audit procedure for TS 16949 need to include? Clause 8.2.2 General Auditing Discussions 7
G Customer Owned or Customer Supplied Properties - Do we need a procedure anyway? Document Control Systems, Procedures, Forms and Templates 11
Q Do All Shifts Need to be Audited For Every Procedure? Internal Auditing 8
J Agilent Power Sensor Calibration - Need a Calibration Procedure General Measurement Device and Calibration Topics 13
P Writing a general procedure for CMM programming - Need advice Document Control Systems, Procedures, Forms and Templates 22
J Caliper repair procedure - I need a caliper repair procedure for dial calipers General Measurement Device and Calibration Topics 2
D Non-sector specific requirements: Do I need to write a physical procedure IATF 16949 - Automotive Quality Systems Standard 3
G Quality Circles - What kind of procedure do I need and does anyone have one to share? Document Control Systems, Procedures, Forms and Templates 7
N If we have a complete procedure in our Quality Manual do we need another one? Quality Management System (QMS) Manuals 6
D Need A Procedure for determining CMM Uncertianties General Measurement Device and Calibration Topics 4
A ISO 14001 Clause 4.4.2 - When do I need a procedure? Miscellaneous Environmental Standards and EMS Related Discussions 12
E Procedure Numbering Change? Still the need for maintaining Level 1, 2, 3, documents? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
D Sunnen Gages - Need Operating Procedure and Manual General Measurement Device and Calibration Topics 2
L Do I need a Procedure for Continuous Improvement (CI)? Preventive Action and Continuous Improvement 8
J Furnace repaired - Do I need a new initial TUS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B Does FDA Registration QSR need to cover non-medical devices for contract repackager? US Food and Drug Administration (FDA) 1
S Need ISO 15189:2012 Documentation toolkit. Document Control Systems, Procedures, Forms and Templates 0
J Need a contract monitoring Tool General Information Resources 0
P UDI-PI requirements on reusable surgical device, do we need serialisation? ISO 13485:2016 - Medical Device Quality Management Systems 3
W 17025 and NIST handbook relationship (need advice) ISO 17025 related Discussions 8
S Need help on "Country of Origin" Medical Device and FDA Regulations and Standards News 0
Ed Panek Immediate need for 80601-2-56 Consulting expert. PM me for details Career and Occupation Discussions 0
Tagin You're Gonna Need a Bigger Root Cause Coffee Break and Water Cooler Discussions 12
M PSA Suppliers - CSR matrix and need the quality manual of PSA APQP and PPAP 3
