Do I need a procedure for the procedure's template???
E
eohara - 2008
Hi all,
I find that I overthink things, so this may be another example. I am wondering if I need to document the template/format of my procedures and work instructions. We have good formats that work, and we base future SOPs and WIs on existing, to keep the same format. However, this isn't documented. Should it be? I don't want to lose the template requirements, but I don't want overkill.
Also, another reason for my question is that my company used to be GMP certified. They had a procedure that covered the procedure format. Here is a clip from it:
Each SOP will have a “header” which contains the following information:
Logo Block: As referenced above in this SOP, each SOP will contain a Logo Block that includes the logo and the generic title of “Standard Operating Procedures”.
SOP Title: Each SOP is identified with a brief description of the subject matter.
SOP No: Each major SOP is identified with an SOP number, which compliments the SOP title. The SOP number is intended to simplify the referencing of SOPs to improve communication throughout the corporate involvement of implementing these procedures.
Each SOP will have a statement for the listed elements, and be preceded by a number character.
1.0 Purpose and Scope: Describes SOP need and applicability.
2.0 Policy: Describes policy in regard to the SOP.
3.0 Definitions: Explains acronyms and specific terms used within SOP.
4.0 Responsibility: List responsible parties for implementing SOP.
5.0 Procedure: Describes processes to be followed and personnel responsible for ensuring that the process is followed.
6.0 Related Documents: References the documents or procedures that will be used in conjunction with the procedure.
7.0 History: Itemizes major changes in an SOP in a chronological format (time from initial SOP issue).
My SOPs follow the nice format listed above, but I have archived the old GMP SOP. I am wondering if I need to re-issue it.
Comments?
Thanks!!!
Will it be helpful to control the format? If so, do it.
P
Pazuzu - 2009
No, you dont. The procedures you need to have are the big 6 as stated by ISO (Internal audits, control of records, control of documents, NC product, prev. actions, and corr. actions), and and any others that you and the company deem are required for effective management. Nowhere does ISO say you shall template in a particular formate and/or have a procedure illustrating it. How you do it is up to you and as Jim stated, if it helps, giv'er!
Benjamin28
Do it!
If it were me, yes, I would have a standard format, it only helps to keep things organized, nicely formatted, standardized, and is a natural portion of a document control system.
SteelMaiden
You can have a template that can be opened and completed (somewhat like a form), you can have a work instruction or sop, you can have a procedure, or you can have the template and the sop/wi/procedure. Whatever works for you, but as my esteemed colleagues have said, there is not ISO requirement for a documented procedure detailing how a procedure is formatted.
E
eohara - 2008
Thanks everyone. I know it's not required, but it's good to hear the feedback of "do what works for the company". That's been my motto as I implement ISO. It's got to both work for us, and comply.
So, I like the idea of the form (that way I don't need all the approval signatures that an SOP/WI require). Or, another idea was to make it a "reference" document.
Thanks!:D
Not only is a documented procedure not mandated, there is also no ISO mandate for the stuff you listed in your procedure. You are not required to have the stuff you have listed (1.0-7.0), nor a header. All of the stuff you have listed may be nice to have, or even really important at your company, but not mandated by the standard.
Remember, the more control features you have, the less flexibility you get.
E
eohara - 2008
Good points db. So, is it safest to just base my future SOPs and WIs on the existing formats? I just don't want anything to get lost. It's worked so far though. I think the old GMP requirements threw me off a little.
Thanks!
Thanks!
The standard gives you a lot of leeway here for a reason. You need to have enough strictness to ensure control, but you don’t want to tie your hands. One company I was working with was really struggling on how to make the prints they generate fit their procedure. When you have that battle, your system is probably too strict.
L
Logic
Hi all,
Later Post:
Eohara:
You have indicated that you are going to use the "nice format" anyway, so why is it necessary to abandon the SOP? I am a bit concerned if the main reason for not keeping this SOP active is to avoid the approval signatures that an SOP/WI require. SOP/WI should have approval signatures at appropriate levels and this would not be considered a critical SOP so the approval process should be simple.
If you had to write an SOP to cover this, I would say it is not critical to have but think of the value to a new employee who may need to write an SOP and needs to understand what is required for the sake of the company - not auditors. It is standard practice for companies who operate under GMP to have a standard format for their SOPs and it certainly makes life easier for inspectors.
K Need procedure for D&D inputs? ISO 13485:2016 - Medical Device Quality Management Systems 4
S Do we need separate stand alone procedure for Suspect Unapproved Parts? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
L I need an example rework procedure/instruction for injected plastic parts Document Control Systems, Procedures, Forms and Templates 2
J Recycling Procedure (ISO9001) - Do I need a documented process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
T Need help developing an ECO (Engineering Change order) procedure Document Control Systems, Procedures, Forms and Templates 3
C Does every procedure need to be included within a policy? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B Developing a Queue Management Procedure - Need some help writing a Proposal Quality Manager and Management Related Issues 2
Z Does this Process need an established Documented Procedure? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q Need a new CA/PA Procedure to better interface with Portal Systems Nonconformance and Corrective Action 9
G Change of procedure for handling new projects - do the ongoing ones need to follow? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Need Help with procedure on Metcal Calibration and Metrology Software and Hardware 9
S Do we need to have enough documents to support APQP procedure? APQP and PPAP 10
A Do you need a separate procedure for the 6 mandatory procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Does a Procedure need to have a metric assigned to determine its effectiveness? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Batch or Lot release in to market - Need product release procedure Document Control Systems, Procedures, Forms and Templates 3
C Need a procedure or outline on Good Practices for Completing Quality Records/Document Document Control Systems, Procedures, Forms and Templates 2
D Do I need a Procedure on Legal Requirements? Regulated Insurance Sector ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
T Changes to document control procedure - need review Document Control Systems, Procedures, Forms and Templates 4
L Do we need a seperate procedure for each ISO 14001 sub clause? ISO 14001:2015 Specific Discussions 8
K Need DETAILED Procedure Template for Dental Insurance Co. Document Control Systems, Procedures, Forms and Templates 21
T ISO 17025 Validation Procedure - Need Example ISO 17025 related Discussions 11
Crusader Spill Containment Procedure template - Need example Miscellaneous Environmental Standards and EMS Related Discussions 12
M Do I need a Procedure for Each Process? And the Interaction of Processes - TS16949 IATF 16949 - Automotive Quality Systems Standard 20
Howard Atkins What does the internal audit procedure for TS 16949 need to include? Clause 8.2.2 General Auditing Discussions 7
G Customer Owned or Customer Supplied Properties - Do we need a procedure anyway? Document Control Systems, Procedures, Forms and Templates 11
Q Do All Shifts Need to be Audited For Every Procedure? Internal Auditing 8
J Agilent Power Sensor Calibration - Need a Calibration Procedure General Measurement Device and Calibration Topics 13
P Writing a general procedure for CMM programming - Need advice Document Control Systems, Procedures, Forms and Templates 22
J Caliper repair procedure - I need a caliper repair procedure for dial calipers General Measurement Device and Calibration Topics 2
D Non-sector specific requirements: Do I need to write a physical procedure IATF 16949 - Automotive Quality Systems Standard 3
G Quality Circles - What kind of procedure do I need and does anyone have one to share? Document Control Systems, Procedures, Forms and Templates 7
N If we have a complete procedure in our Quality Manual do we need another one? Quality Management System (QMS) Manuals 6
D Need A Procedure for determining CMM Uncertianties General Measurement Device and Calibration Topics 4
A ISO 14001 Clause 4.4.2 - When do I need a procedure? Miscellaneous Environmental Standards and EMS Related Discussions 12
E Procedure Numbering Change? Still the need for maintaining Level 1, 2, 3, documents? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
D Sunnen Gages - Need Operating Procedure and Manual General Measurement Device and Calibration Topics 2
L Do I need a Procedure for Continuous Improvement (CI)? Preventive Action and Continuous Improvement 8
P UDI-PI requirements on reusable surgical device, do we need serialisation? ISO 13485:2016 - Medical Device Quality Management Systems 0
W 17025 and NIST handbook relationship (need advice) ISO 17025 related Discussions 8
S Need help on "Country of Origin" Medical Device and FDA Regulations and Standards News 0
Ed Panek Immediate need for 80601-2-56 Consulting expert. PM me for details Career and Occupation Discussions 0
Tagin You're Gonna Need a Bigger Root Cause Coffee Break and Water Cooler Discussions 12
M PSA Suppliers - CSR matrix and need the quality manual of PSA APQP and PPAP 2
K "World Class Product" based QM. I need advice. Quality Management System (QMS) Manuals 14
I Do I need to sign off my annual audit calendar? Internal Auditing 2
P Do we need to retrospectively use the "MD" symbol (indicating device is a medical device) on labels, e.g. finished devices within expiration date? EU Medical Device Regulations 2
M Do I need separation in my circuit with a medical charger? IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
