Do nonconformances always result in corrective action
Big Jim
#21
I'm with Jane on this one. If you tried to applie full blown correctivie action on every minute nonconformance you would get nothing else done. Forget about making money so you can survive.
To add to the discussion, from ISO 9000:2005, Quality management systems -- Fundimentals and vocabulary:
3.6.5
corrective action
action taken to eliminate the cause of a detected nonconformity or other undesirable situation
NOTE 1 There can be more than one cause for a nonconformity.
NOTE 2 Corrective action is taken to prevent recurrence whereas preventive action is taken to prevent occurrence.
NOTE 3 There is a distinction between correction and corrective action.
3.6.6
correction
action taken to eliminate a detected nonconformity
NOTE 1 A correction can be made in conjunction with a corrective action.
NOTE 2 A correction can be, for example, rework or regrade.
I should add that the audit nonconformance form used by some certification bodies requires the auditor to describe the nonconformance including objective evidence and a citation of the applicable element of the standard. The form then requires the auditee to respond with 1) correction, 2) root cause, and 3) corrective action. The corrective action is to speak to the root cause.
Many companies procedures provide for an appropriate authority to determine if a discrepant material report (DMR) (or whatever term your company uses) requires elevation to a corrective action report (CAR).
I guess that this whole thing turns on how you read element 8.5.2. "The organization shall take action to eliminate the cause of nonconformities . . . " Perhaps if you read that as ALL nonconformities you will have a different opinion than me.
joshua_sx1
#22
…I do agree with most posters here… for me, nonconformance requires either correction or corrective action itself, to eliminate the cause of a detected nonconformity or other undesirable situation - if it is really a nonconformance
:2cents:
#23
OK - let's step back. Big Jim is correct to bring up the following:
there is a difference between a nonconformance to the QMS and a product that has is nonconforming to specifications. both are being discussed here without clear distinction.
there is a difference between a simple ISO9000 QMS and all the others up to and including the FDA. the requirements are not the same...
and the old bugaboo of definitions comes into play with differering meanings of the word "correct".
let's be clear about which QMS system and which type of nonconformity and which definition of the word correction we are discussing.
Big Jim
#24
there is a difference bewteen a noncormance to the QMS and a product that has is nonconforming to specifications. both are being discussed here without clear distinction.
there is a difference between a simple ISO9000 QMS and all the others up to and including the FDA. the requriements are not the same...
and the old bugaboo of definitions comes into play with differering meanings of the word "correction".
Could you expand on that? I picture a product nonconformance as a QMS nonconformance, especially in the light of element 8.3, control of nonconforming product.
#25
This section of ISO9000 only addresses what to do with the product that is found to be nonconforming to specifications (i.e. defective); it does not in any way deal with actions related to the cause of the nonconforming or defective product.
The mere fact that defective product exists is not a nonconformance to the QMS; in fact the existance of 8.3 is a testament to the fact that some amount of nonconforming or defective product is to be expected. Section 8.3 addreses what to do with it when it occurs.
Failure to control defective product would be a nonconformance to the QMS (e.g. not identifying NC product as NC, knowingly shipping to a customer without the customers' agreement - or concession, etc.
There is no QMS that I am aware of that states that a defective product is a nonconformance to the QMS itself. The design and development section only requires that product be capable of meeting requirements - there is no statement about how capable it must be and certainly it never says that the product must be capable of meetign requirements 100% of the time. Section 8.2.4 does require testign to verify product conformance to requriements but does not say that all product must meet the requirements; in fact, this section is directly followed by 8.3 which addresses what to do with product that doesn't meet requirements.
There is no QMS that I am aware of that requires corrective action as to cause for every instance of a defective product or defect type. This would surely cripple an organization.
The phrase "Corrective action" as applied to internal audit findings (nonconformances to the QMS) or certain types of defective product as addressed by section 8.5 in ISO9000 is meant to be corrective action as to cause in order to prevent reocurrence....section 8.3 does not address this at all.
howste
Thaumaturge
#26
The way I read it, ISO 13485 gives us the flexibility to determine when we will take corrective action. Clause 8.5.2c says we must be:
...evaluating the need for action to ensure that nonconformities do not recur...
I'm a big proponent of using the corrective action process effectively when it's needed. Prioritize how you'll use your limited resources. I think the type of nonconformity and the effects of the nonconformity will help us to decide if taking corrective action is appropriate. If it's a significant customer contract requirement or regulation that's being violated, yes. If it's a safety issue, definitely.
However, if we impose a non-value-added requirement on ourselves, then find a nonconformity against it, it would be better to eliminate the requirement (correction) instead of wasting time evaluating root cause of why the requirement wasn't met. Also, a $10,000 solution to a $10 a year problem would be rediculous. Use common sense! (Even though sometimes it's not so common...)
Bob Bonville
#27
Howste, you have wisdom beyond your years. I couldn't agree with you more.
Right ON!
Bob
Big Jim
#28
Thank you for helping me to better understand 8.3.
In light of 8.5.2 I still don't see how product nonconformance is not a QMS nonconformance. I think you comment about 8.3 being a testiment that junk happens when dealing with product is correct, but I think a similar argument can be made about QMS nonconformances as well in that the entire standard helps provide remedy when QMS nonconformances are found.
So perhaps we are still centered on how you read the opening of 8.5.2. "The orgainzation shall take action to eliminate the cause of nonconformities in order to prevent recurrence." If you read that as ALL nonconformities then it would be very difficult to live with.
#29
I think you're over thinking this. defective product in and of itself has never been interpreted to be a nonconformance to the QMS. a corrective action as to cause to prevetn reocurrence for every defect would be completely onerous and absurd. the entire purpose of 8.3 is to deal with the inevitability that defective product will be made. 8.5.2 does not say ALL. in fact the second sentence says "Corrective actions shall be appropriate to the effects of the nonconformities encountered", meaning that sometimes corrective action is simply rework or throw away and move on...teh nonconformities in this case refer to both QMS and product requirements. you must read the standard as a whole and not as stand alone bits and pieces.
RoxaneB
#30
A nonconformance with the product or the process or the QMS is irrelevant. A failure is a failure...end of story. Which path we follow in the treatment or the resolution of the failure is key to ensure that we add value to our Stakeholders (of which the Customer is one).
There are times when Corrective Action is required...a full blown root cause analysis, an action plan, a verification plan, etc.
There are times when (working for a steel mill) I say it's a 'quick wham-bam-let's-get-back-to-making-steel' approach. This means we implement a correction and get back to making our product.
The question becomes, however, when is Corrective Action required and when is a Correction appropriate?
The answer is..."What ever works for your organization." Data analysis will tell you where your largest problems are occurring. I'd adopt Correction Action for the top 20% of the problems and Corrections for the remaining 80.
To ensure consistency, develop, document and implement Nonconformance Triggers. This is a matrix that shows for each process/department within your organization when a failure requires a Correction or Corrective Action.
For example, in your manufacturing process, you may deem that less that 5 pieces scrapped on one order will result in a Correction but >= 5 will prompt Corrective Action. In your Customer Complaint process, you may state that any complaint < x $ is a Correction but anything higher will be a Corrective Action.
Each process owner(s)/department should define their own set of triggers, but it is great to consolidate this information. By structuring the processes/departments in a sequential flow that mimics the creation of your product or service, this Matrix helps to show how a failure in one process can adversely impact their internal Customer (i.e., the next process/department in line).
The good part about this approach is that if you focus and properly apply your problem solving skills and resources on those top issues, your organization will get them under control and they will cease to be problems. As part of a regular data analysis program (e.g., annual review of trends, indicators, etc.), a new "top 20" list may arise and you can revise your triggers for the following cycle.
B How many nonconformances have you received on average during IATF audits? General Auditing Discussions 24
Tagin Evaluating nonconformances for escalation using Bayesian methods? Statistical Analysis Tools, Techniques and SPC 2
G Differences - Nonconformances vs CAPA, Corrections vs Corrective Actions ISO 13485:2016 - Medical Device Quality Management Systems 16
R Extension of product nonconformances - Construction project Nonconformance and Corrective Action 7
I Audit Nonconformances - Can reported corrective actions be incomplete? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J EU ISO 13485:2016 Recertification Audit - Effect of 10 Minor Nonconformances EU Medical Device Regulations 2
W Closing of Stage 2 Audit Nonconformances AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M User Errors and Product Nonconformances Nonconformance and Corrective Action 22
K Notified Body - Minor Nonconformances - They have withheld all certificates General Auditing Discussions 3
Q Several Nonconformances with same Root Cause with just one CA ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
V 21 CFR 820 Compliant way to use Kaizen to address Nonconformances Nonconformance and Corrective Action 9
N Nonconformances in the Construction Industry Nonconformance and Corrective Action 6
T Perishable Tooling Supplier - Nonconformances and Metrics AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
H NADCAP Audit Nonconformances - Vacuum Furnace Load Sensors AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
L Internal Audit Nonconformances - Your opinion? Internal Auditing 8
M Supplier Nonconformances - Key Points to ask a Metal Stamping Supplier Supplier Quality Assurance and other Supplier Issues 7
L Insurance to cover for nonconformances ? Misc. Quality Assurance and Business Systems Related Topics 2
T Defining Nonconformances in a Service Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C ISO 9001 Nonconformances an how to handle them ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N Second Registrar Visit to Confirm Major Nonconformances Fixed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
L Definitions for Minor & Major Nonconformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
F Response to ISO 13485 Audit Minor Nonconformances ISO 13485:2016 - Medical Device Quality Management Systems 6
M Seven Document Review Nonconformances Document Control Systems, Procedures, Forms and Templates 9
J KPI for time to close NCs (Nonconformances) Quality Manager and Management Related Issues 17
R Internal Audit Cancellation when Nonconformances are Found Quality Manager and Management Related Issues 13
J Question about GM special requirement - Open Major Nonconformances IATF 16949 - Automotive Quality Systems Standard 2
K CAPA Training for Process Nonconformances Nonconformance and Corrective Action 2
A Nonconformances and Rework in a Machine Shop Nonconformance and Corrective Action 6
Fender1 Nonconformances that do not require Corrective Action Nonconformance and Corrective Action 21
C Who does the Analysis of Nonconformances and other Data Analysis? Nonconformance and Corrective Action 23
T NonConformances as a Tool to Measure Employee Performance Nonconformance and Corrective Action 21
A Surveillance Audit Result - Multiple Audit Nonconformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B Suspension of ISO 9001 Certificate - Major Nonconformances Identified ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
B The Distribution that represents the Severity of Nonconformances Nonconformance and Corrective Action 2
L Non Conformance Register (aka Tracking Nonconformances and Corrective Actions) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J How many Major Nonconformances could let the Audit be Terminated? General Auditing Discussions 9
R ISO 13485 Surveillance Audit Nonconformances and Report Help Needed ISO 13485:2016 - Medical Device Quality Management Systems 9
A ISO 14001 Surveillance Audit Nonconformances ISO 14001:2015 Specific Discussions 6
J Corrective Action Timeframe for Internal Nonconformances Nonconformance and Corrective Action 14
R Is it useful to adapt PFMEA's with nonconformances? FMEA and Control Plans 4
P Boss doesn't want Nonconformances called Nonconformances in Internal Audit Reports ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
C System Root Cause and CA (Corrective Action) for ISO 13485 Audit Nonconformances ISO 13485:2016 - Medical Device Quality Management Systems 3
M Can a KPI (Key Process Indicator) be created against Nonconformances? Nonconformance and Corrective Action 8
J Certification Body follow up on clearing Audit Nonconformances Registrars and Notified Bodies 4
M NCR and Cost Collection - Capturing nonconformances in the field Nonconformance and Corrective Action 1
Q CTC (Critical to Customer) vs. CTQs (Critical to Quality) Nonconformances Nonconformance and Corrective Action 6
A Escalating Minor Nonconformances into Major Nonconformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
D NCRs (Nonconformances) allowed during ISO 9001 Recertification Audit General Auditing Discussions 21
P Is Blaming Operators for Nonconformances correct? Quality Manager and Management Related Issues 62
C CB Client Contract Agreement - Identifying nonconformances - AS9100 Registrars and Notified Bodies 7
