Do nonconformances always result in corrective action
#31
ah - but you're trying to apply logic and reason!
The difference between a nonconformance to the QMS or of the product to requirements is the key to the OP's question: the question being: "do nonconformities ALWAYS result in corrective action or are there cases where a nonconformity DOES NOT result in a corrective action".
If we accept that his use of the phrase of "Corrective Action" means the standard definition = "corrective action to prevent recurrence" then we must be aware that for ISO9000, section 8.2.2 internal audit (which addresses nonconformities to the QMS) states very clearly "The management responsible for the area being audited shall ensure that actions are taken without undue delay to eliminate detected nonconformities and their causes. Internal audit is focused on QMS compliance and not product conformance. In this case, corrective action is generally interpreted to be required.
internal auditors tend to fudge about with the definition of what constitutes a 'finding' of nonconformance. isolated instances of a signel clerical error or mistake may not be deemed a finding of nonconformance by some auditors so as to avoid corrective actions, but this approach is subject to intense debate...
#32
Bev D - you maybe right about what's generally interpreted - and that's where conventional wisdom is often incorrect!
A few years back, At the ASQ conference, a keynote address was given by Jack West which (basically) said that he external audit model was to balme for 'over interpreting' the need for corrective action (including root cause analysis) instead of allowing for correction.
I'd go further and say the whole internal audit model needs to change (away from current 'wisdom'), including ensuring that auditors only report non-conformities (and effectiveness is key, here) and allow management to decide on how to treat the actions. After all, it's their business.
If they fail to get serious about this, no internal auditor is going to change anything, no amount of threats about the CB auditor finding the same or grading nc's as major/minor will drive any actions! Indeed, treating all audit findings as needing (root cause) corrective actions, is IMHO, one of the fastest ways to bring the system down to simply keeping a certificate on the wall
#33
yes - it's just soooooo difficult to get past the statemetn in the internal audit section "The management responsible for the area being audited shall ensure that actions are taken without undue delay to eliminate detected nonconformities and their causes". If the statement stopped at eliminate nonconformities, simple correction would be accepted as allowable. but alas "and their causes" takes us beyond simple correction...:(
Big Jim
#34
I think you're over thinking this. defective product in and of itself has never been interpreted to be a nonconformance to the QMS. a corrective action as to cause to prevetn reocurrence for every defect would be completely onerous and absurd. the entire purpose of 8.3 is to deal with the inevitability that defective product will be made. 8.5.2 does not say ALL. in fact the second sentence says "Corrective actions shall be appropriate to the effects of the nonconformities encountered", meaning that sometimes corrective action is simply rework or throw away and move on...teh nonconformities in this case refer to both QMS and product requirements. you must read the standard as a whole and not as stand alone bits and pieces.
I think you and I are closer than you realize. I'm the one who first posted that I don't believe that ALL is the intent of the standard.
The point in which we may need to agree to disagree is about product nonconformance being included in QMS nonconformance. Reading the entire standard as a whole, I don't understand how it could be any other way. In either case, we both have lots of company.
#35
Only if you let it..........
Too many QMS folks spend way too much time agonizing over root cause. Often the cause is right under our noses, so I fail to see why it can't be considered as part of the correction. Just like how we treat non-conforming product really! Don't forget, Mr. West is on TC 176, so I take it they talked at length about this! I'm sure they didn't all mean root cause for all audit non-conformities.
Of course, if I ruled the world, the audits would tackle issues that management have a vested interest in, so their responses wouldn't rely on any wording in the standard - they'd get on with it because their (personal functional) performance depended on it! Maybe the next revision of ISO 9000 might address a more robust focus for internal audits!
JaneB
#36
There are times when Corrective Action is required...a full blown root cause analysis, an action plan, a verification plan, etc.
There are times when (working for a steel mill) I say it's a 'quick wham-bam-let's-get-back-to-making-steel' approach. This means we implement a correction and get back to making our product.
Each process owner(s)/department should define their own set of triggers, but it is great to consolidate this information. By structuring the processes/departments in a sequential flow that mimics the creation of your product or service, this Matrix helps to show how a failure in one process can adversely impact their internal Customer (i.e., the next process/department in line).
The good part about this approach is that if you focus and properly apply your problem solving skills and resources on those top issues, your organization will get them under control and they will cease to be problems. As part of a regular data analysis program (e.g., annual review of trends, indicators, etc.), a new "top 20" list may arise and you can revise your triggers for the following cycle.
Yes - great advice and a very practical approach. I couldn't agree with you more.
Some organisations may choose a 'corrective action' for every nonconformity. That's their choice, and hopefully for sound reasons. But it's not one I'd recommend in 99% of circumstances, and I'd really want to discuss with any company proposing it their reasons for doing so. 80/20 rule tends to be more valuable.
I have seen companies impose this kind of blanket, B&W rule... and also seen that in many cases, it can take far longer to fill the form in than to actually fix whatever the issue is... and for virtually zilch value! At times it seriously does become 'quality gone mad'. Definitely the kind of thing that tends to turn people off.
If only common sense were more common. :(
John Nabors - 2009
#37
I'm with RC and Jane. There are issues that really are indicators of a broken system, and there are issues that are just a bug on the windshield of progress. A bug on the windshield does not necessitate removing the windshield to wipe it off.
BobA5835 - 2009
#38
AndyN said:
I'm going to step in here and offer some thoughts, I've no doubt Geoff will too.
-Snip-
Geoff, I believe, is also looking at the results of audits as needing the auditor to be aware of the likely cost/benefit ratio of any corrective action - which is often overlooked.
Mr. Andy:
Thank you for the additional information. I've shared this thread with Dr. P, my Audit Manager. The Cove has helped generate some lively interaction for us.:applause:
However, Dr. P says, sorry, no, as the concept of the OP's original question has been shifted somewhat. Some of this is putting the cart before the horse. It is not up to me to be influenced by possible "economic" considerations while doing our (Regulatory) Audits. As far as the Results of the Audit and any Corrective Actions and dealing with Management, that's his job, not mine (as the Auditor). :)
BobA5835
#39
-Snip-
Mr. Andy:
BobA5835
The OP didn't state anything about doing regulatory audits, which is a different kettle of fish.
However, I still maintain, that any internal auditor should have their antenna up regarding the cost impact of what they're seeing.
Dr. P may not see it that way, not many do (IMHO) and, as a result, organizations tend to get little to no benefit from their audits.......
maxwell
#40
I want to thank everyone who contributed to the discussion (Do non conformances always result in corrective action). I appreciate being able to get different so many different opinions from so many quality professionals (thank you cove). In the end I guess it is ultimately the organizations choice. :thanks:
B How many nonconformances have you received on average during IATF audits? General Auditing Discussions 24
Tagin Evaluating nonconformances for escalation using Bayesian methods? Statistical Analysis Tools, Techniques and SPC 2
G Differences - Nonconformances vs CAPA, Corrections vs Corrective Actions ISO 13485:2016 - Medical Device Quality Management Systems 16
R Extension of product nonconformances - Construction project Nonconformance and Corrective Action 7
I Audit Nonconformances - Can reported corrective actions be incomplete? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J EU ISO 13485:2016 Recertification Audit - Effect of 10 Minor Nonconformances EU Medical Device Regulations 2
W Closing of Stage 2 Audit Nonconformances AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M User Errors and Product Nonconformances Nonconformance and Corrective Action 22
K Notified Body - Minor Nonconformances - They have withheld all certificates General Auditing Discussions 3
Q Several Nonconformances with same Root Cause with just one CA ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
V 21 CFR 820 Compliant way to use Kaizen to address Nonconformances Nonconformance and Corrective Action 9
N Nonconformances in the Construction Industry Nonconformance and Corrective Action 6
T Perishable Tooling Supplier - Nonconformances and Metrics AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
H NADCAP Audit Nonconformances - Vacuum Furnace Load Sensors AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
L Internal Audit Nonconformances - Your opinion? Internal Auditing 8
M Supplier Nonconformances - Key Points to ask a Metal Stamping Supplier Supplier Quality Assurance and other Supplier Issues 7
L Insurance to cover for nonconformances ? Misc. Quality Assurance and Business Systems Related Topics 2
T Defining Nonconformances in a Service Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C ISO 9001 Nonconformances an how to handle them ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N Second Registrar Visit to Confirm Major Nonconformances Fixed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
L Definitions for Minor & Major Nonconformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
F Response to ISO 13485 Audit Minor Nonconformances ISO 13485:2016 - Medical Device Quality Management Systems 6
M Seven Document Review Nonconformances Document Control Systems, Procedures, Forms and Templates 9
J KPI for time to close NCs (Nonconformances) Quality Manager and Management Related Issues 17
R Internal Audit Cancellation when Nonconformances are Found Quality Manager and Management Related Issues 13
J Question about GM special requirement - Open Major Nonconformances IATF 16949 - Automotive Quality Systems Standard 2
K CAPA Training for Process Nonconformances Nonconformance and Corrective Action 2
A Nonconformances and Rework in a Machine Shop Nonconformance and Corrective Action 6
Fender1 Nonconformances that do not require Corrective Action Nonconformance and Corrective Action 21
C Who does the Analysis of Nonconformances and other Data Analysis? Nonconformance and Corrective Action 23
T NonConformances as a Tool to Measure Employee Performance Nonconformance and Corrective Action 21
A Surveillance Audit Result - Multiple Audit Nonconformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B Suspension of ISO 9001 Certificate - Major Nonconformances Identified ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
B The Distribution that represents the Severity of Nonconformances Nonconformance and Corrective Action 2
L Non Conformance Register (aka Tracking Nonconformances and Corrective Actions) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J How many Major Nonconformances could let the Audit be Terminated? General Auditing Discussions 9
R ISO 13485 Surveillance Audit Nonconformances and Report Help Needed ISO 13485:2016 - Medical Device Quality Management Systems 9
A ISO 14001 Surveillance Audit Nonconformances ISO 14001:2015 Specific Discussions 6
J Corrective Action Timeframe for Internal Nonconformances Nonconformance and Corrective Action 14
R Is it useful to adapt PFMEA's with nonconformances? FMEA and Control Plans 4
P Boss doesn't want Nonconformances called Nonconformances in Internal Audit Reports ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
C System Root Cause and CA (Corrective Action) for ISO 13485 Audit Nonconformances ISO 13485:2016 - Medical Device Quality Management Systems 3
M Can a KPI (Key Process Indicator) be created against Nonconformances? Nonconformance and Corrective Action 8
J Certification Body follow up on clearing Audit Nonconformances Registrars and Notified Bodies 4
M NCR and Cost Collection - Capturing nonconformances in the field Nonconformance and Corrective Action 1
Q CTC (Critical to Customer) vs. CTQs (Critical to Quality) Nonconformances Nonconformance and Corrective Action 6
A Escalating Minor Nonconformances into Major Nonconformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
D NCRs (Nonconformances) allowed during ISO 9001 Recertification Audit General Auditing Discussions 21
P Is Blaming Operators for Nonconformances correct? Quality Manager and Management Related Issues 62
C CB Client Contract Agreement - Identifying nonconformances - AS9100 Registrars and Notified Bodies 7
