Do Quality Objectives have to be Measurable?
DomDom
#31
Re: Quality Objectives - Do Quality Objectives have to be Measurable?
Good day,
There is a sentence I like to use:
"There cannot be any improvements without measures" To me it says it all!
As it was lready mentionned in the thread, make sure it is SMART and do not try to eat an elephant at once, start by one leg to slow it down :D
Sidney Vianna
Post Responsibly
#32
For your information, instead of using percentage to indicate measurement, you can also use numbers. For example, to restrict customer complaints for 5 cases, to obtain 03 appraisals from customers, to restrict goods return for 04 cases.
While you can do, as you mentioned, it is not very smart to do so. If you increase your customer base, chances are, you will have a higher number of opportunities for complaints. Normalizing indicators is a wise thing to do.
Also, it is CRITICAL to realize that, differently from ISO 14001, ISO 9001 does not require targets. Quality objectives (albeit obligatorily measurable) don't have to have a target associated with.
#33
2 quick points...
1. ISO choses its words carefully. .... noticed that it says "measurable", not "measured". This does not make sense to me. What good is being measurable, without measurement? Although I could make a legalistic claim that measurement is not required, it would clearly contradict many of the requirments in clause 8. A
2. Also rememer the first part of 5.4.1 that mentions "including those needed to meet requirements for product". Your objectives will be more than those global objectives that related to all of your product/processes. For example, order # 62537 needing to be shipped by this Thursday. They need to be consistent with the policy, but not specifically mentioned with the policy. Those individual product requirements are objectives as well, and they also have to meet 5.4.1.
Sidney Vianna
Post Responsibly
#34
The reason for that is that objectives can be an attribute (instead of a variable). For example, a quality objective could be: attain CE-Mark for product XYZ by July 2012. Or, another example, attain gold level status as a supplier to Boeing in 2014.
There was an "official" interpretation from the TC 176 on that.
Aliveguy
#35
We review our Objectives in Management Review, Four times per year.
This is a good time to discuss plans moving ahead and any changes to the Objectives that may be needed.
Good Luck on your Task...:D
Big Jim
#36
Do you have a source for that interpretation?
I can find an interpretation for ISO 9001:2008 5.4.2, but not 5.4.1. I can't find one for ISO 9001:2000 for anything in 5.4.
howste
Thaumaturge
#37
:agree1: I was thinking the same thing.
I agree that ISO 9001 doesn't require the objectives to have targets. However, the process measurements (8.2.3), which I believe should be aligned with the objectives, are required to have "planned results." In my opinion, these should be targets/goals.
Sidney Vianna
Post Responsibly
#38
Yes, I have a source: TC 176. Below is a compilation of all "old interpretations", no longer posted in the TC 176 website. The one in red is the one I referred to.
Clause 1.2 (N850r):
Q: Does the standard require an organization that purchases a complete design, then manufactures a product to the design and sells it under its own brand name, to include “design” as one of the processes needed for the Quality Management System?
A: Yes.
Clause 2 (N649r):
Q: Do only terms and definitions of ISO 9000:2000 constitute provisions of ISO 9001:2000 through the reference in the text of Clause 2 of ISO 9001:2000?
A: Yes.
Clause 4.1 a) (N753):
Q: Does the expression “needed for the QMS” in Clause 4.1 a) require the organization to identify the QMS processes related to product realization only?
A: No, The processes needed for the QMS include those related to product realization as well as the other processes related to the implementation of the QMS, as per the NOTE in clause 4.1.
Clause 4.2.1 (N778):
Q: include “a quality manual” (item b) and “documented procedures required by this International Standard” (item c). Is it in compliance with the standard to include the “documented procedures required by the standard” in the quality manual instead of having two separate sets of documents?
Background: Some advisors recommend that organizations which are implementing their quality management system develop one manual, in addition to all the six documented procedures, because of clause 4.2.1.Yet clause 4.2.2 says: “The organization shall establish and maintain a quality manual that INCLUDES:
b) documented procedures established for the quality management system or reference to them”.
A: Yes.
Clauses 4.2.2 c) and 4.1 b) (N718):
Q: Does Clause 4.2.2 c), require that the manual include a description of the processes, in addition to a “description of the interaction between the processes of the QMS ”?
Attention is also drawn to the connection between Clause 4.2.2 c) and Clause 4.1 b), where the organization is required to “determine the sequence and interaction” of the processes. On this problem of interpretation there is a divergence of opinion between an organization and a Certification Body.
A: No.
Clause 4.2.3 a) (N638r):
Q: Does documented purchasing information that is part of the quality management system, have to be approved according to 4.2.3 a)?
A: Yes.
Clause 4.2.3 a) (N641r):
Q: Do documented inspection and test procedures that are part of the quality management system, have to be approved according to 4.2.3 a)?
A: Yes.
Clause 4.2.3 a) (N774):
Q: Does sub-clause 4.2.3 a) require that documents required for the QMS be reviewed as well as approved prior to issue?
A: No, Clause 4.2.3 a) is applicable to new documents which are being developed. Some degree of checking, examination or assessment by the person or persons approving is inherent in “approval for adequacy”. There is no requirement for an additional “review” (as defined in ISO 9000:2000 clause 3.8.7).
Clause 5.4.1 (N765):
Q: Does Clause 5.4.1 of ISO 9001:2000 consider quality objectives defined by “YES/NO” criteria to be measurable?
Background: Several companies that we audit have established some (but not all) of their quality objectives based on “YES/NO” criteria. Example “Achieve product certification for “xxxxxxx” product by November 2002”; or “Develop a new product to meet the requirements of the “YYYYY” market by March 2003”. In order to provide a consistent and technically accurate audit, we would like to know if these are considered to be “measurable objectives”.
A: Yes.
Clause 5.4.2 (N708v):
Q: Is it a requirement of Clause 5.4.2 to have a document that describes the objectives, timeframe, action and responsibilities? (Note: The description of this document is not the same as the definition of “Quality Plan” in ISO 9000:2000, paragraph 3.7.5)
Background: Some users interpret Clause 5.4.2 of the standard to require a document (quality plan) that describes the objectives and the responsibilities etc. This is in addition to the quality manual and procedures document already established to control the relevant processes.
A: No
Clause 5.5.1 (N871r):
Q: Does Sub-clause 5.5.1, Responsibility and authority, address definition of responsibilities and authorities needed for an effective operation of the quality management system, not only for personnel involved in management of the system, such as the management representative and those who document, review and audit the system, but also for personnel involved in purchasing, production, development, testing, etc.?
Background Scenario: The question came up because of the fact that Clause 7.3.1 c) requires that the responsibilities and authorities for design and development have to be determined, while similar clauses like 7.2, 7.4 and 7.5 do not have such an explicit requirement.
A: Yes.
Clause 5.5.2 (N752):
Q: In our organization we have a management representative appointed by top management, who works for the company in a managerial capacity. He is not a permanent member of staff, but works full-time on a contract basis. Is it allowable under the standard, for such a person to act as the organization’s management representative?
A: Yes.
Clause 5.6.3 b) (N757):
Q: Outputs from the management review shall include decisions and actions on the “”improvement of product related to customer requirements”". If an improvement consists in the realization of a new product, does it respond to this specific requirement? (This clause is the only place where the improvement deals with the “”product”". In all other places the improvement concerns the “”effectiveness of the QMS”". But it’s not clear if the sentence “”improvement of product related to customer requirements”" intends to limit the improvement only to the products where the requirements have been already established (e.g. contractually). A clarification on this point will help users and auditors in understanding the extent of application of this requirement.)
A: Yes, The realization of a new product to improve an old one could be one of the results of the management review (Clause 5.6.3 b).
Clause 6.2.2 (N825r):
Q: Does Clause 6.2.2 e) require the organization to maintain records to demonstrate “the evaluation of the effectiveness of actions taken” to address competence needs, according to Clause 6.2.2 c)?
A: No, It is up to the organization to decide what records should be maintained.
Clause 6.3 (N640r):
Q: Does Clause 6.3 require records of the maintenance of infrastructures?
A: No.
Clause 7.1 (N716r):
Q: Does the use of the word “form” in the last sentence of this clause, mean that the output of the planning process must be documented?
Background: There has been some confusion due to the word “form” being interpreted as meaning “document used to record data”.
A: No, The word “form” means usual/suitable format.
Clause 7.2.1 (N743):
Q: In some countries, in order to perform professional work, a law requires that a professional be a member of the appropriate Order and that the Order prescribes its own rules. Some of the rules have an impact on the product. Are these rules of the professional Order to be considered requirements related to the product?
A: Yes.
Clause 7.2.1 a) (N647r):
Q: Does the word “specify” or “specified” quoted in various clauses require documentation? Clauses 7.2.1 a) and b), 7.3.3 d), 7.3.6 and others.
A: No, A relevant example to support the answer is in the definition of procedure (ISO 9000:2000, 3.4.5), “specified way to carry out an activity or process (3.4.1)”, with “Note 1 Procedures can be documented or not”.
Clause 7.2.1 a) (N851r):
Q: Are the contractual delivery dates of a product to be always considered as being part of the “requirements specified by the customer”, mentioned in sub-clause 7.2.1 a)?
A: Yes.
Clause 7.3 (N815r):
Q: Does ISO 9001:2000 require Clause 7.3 to be applied to the design and development of the package necessary to preserve the conformity of the product during delivery?
Background: This request for interpretation does not address the packaging process, but the package that is necessary to protect the product.
A: Yes, The organization is, per sub-clause 7.5.5, responsible for preserving the conformity of the product. Preservation includes packaging. In cases where design and development of the package is necessary to preserve conformity, this has to be performed in accordance with Clause 7.3 of the standard.
Clause 7.3.1 b) (N754):
Q: Does Clause 7.3.1 b) allow the organization to decide on the need, appropriateness and extent of the review, verification and validation to be carried out at each design and development stage?
A: Yes, Review, verification and validation at each stage of design and development shall be determined by the organization according to 7.3.1.b and shall be performed according to 7.3.4, 7.3.5 and 7.3.6.
Clause 7.4 (N812r):
Q: Do the requirements of Clause 7.4, Purchasing, also apply to products that are acquired without any payment being made?
A: Yes.
Clause 7.4 (N870r):
Q: Does Clause 7.4 apply to the purchase of products not intended for the organization’s customer if these purchases have an effect on subsequent product realization or the final product?
A: Yes, All purchased products must conform to their specified purchase requirements, but the type and extent of the control applied depends on the effect the purchased product has on the final product or product realization process.
Clause 7.4.1 (N816r):
Q: Does Clause 7.4.1 require that records of evaluations of suppliers and any necessary actions arising from these evaluations be maintained by all organizations, irrespective of their size?
Background: In small companies where the owners are personally responsible for the purchasing of resources and know their individual suppliers, maintaining records of supplier assessments can be very bureaucratic.
A: Yes.
Clause 7.4.3 (N639r):
Q: Does Clause 7.4.3 require records of the verification of purchased product?
A: No.
Clause 7.5.2 (N751):
Q: Does the process of an organization, whose results can be verified by means of monitoring or measurement after their realization and prior to delivery to the customer, need to be validated in order to comply with the requirements of clause 7.5.2?
Background: The organization provides transportation of orders (goods etc.) involving collection and dispatching services that can be monitored during their respective execution.
A: No.
Clause 7.5.2 (N776):
Q: Does Clause 7.5.2, Validation of processes for production and service provision, require the validation of the equipment, locations and people involved?
Background: The original query implied that the question arose in relation to a hospital)
A: No, Clause 7.5.2 does not say what shall be excluded from or included in validation of the process. It is up to the organization to determine which of the arrangements from a) to e) are applicable (refer also to 7.1).
Clause 7.5.2 (N777):
Q: Does Clause 7.5.2, Validation of processes for production and service provision, require that any applicable statutory and regulatory requirements must be taken into account?
A: Yes, Clause 7.5.2 makes no reference to statutory and regulatory requirements. However these statutory and regulatory requirements are general and must be taken into account wherever applicable to the intended product (see the Note in Clause 1.1).
Clause 7.6 (N757):
Q: Is it correct that Clause 7.6 requires only the measuring and monitoring devices utilized by persons responsible for release of the product to be calibrated or verified?
Background: The Client understands that all of the workers need to have all measuring devices calibrated or verified. The contract just requires compliance with ISO 9001:2000 in this case.
A: No, Clause 7.6 requires calibration or verification of measuring equipment “where necessary to ensure valid results”. It could be more than measuring equipment for product
release only (i.e.: verification of purchased products; in process inspection, etc.) but does not necessarily mean all measuring equipment. When the organization determines the monitoring and measuring required (as defined e.g. in clauses 4.1 a); 4.1 e); 7.1 c) and the first paragraph of 7.6), it shall decide which of them require calibration or verification of the measuring equipment because of the requirement of “valid results”.
Clause 7.6 a) (N805r):
Q: Clause 7.6 a) states: “Where necessary to ensure valid results, measuring equipment shall a) be calibrated or verified at specified intervals, or prior to use, against measurement standards traceable to international or national measurement standards; where no such standards exist, the basis used for calibration or verification shall be recorded.” Can the word “OR” in the phrase “be calibrated or verified at specified intervals….” be interpreted as meaning that these two activities are always mutually exclusive?
Background: According to the concept of metrological confirmation established in ISO 10012:2003 (e.g. Figure 2 Metrological confirmation process for measuring equipment) for carrying out verification activities, it is indispensable to define the measuring equipment metrological requirements, and the latter are compared against the results of calibration activities.
A: No, Calibration and verification can both be applicable depending on the situation.
Clause 8.2.1 (N804r):
Q: In the situation described in the background information, does the standard require an organization to consider also the end user as a customer for monitoring satisfaction?
Background: An organization designs and manufactures a product to its own specifications and sells it to end users through a distribution chain. It is not technically modified between the organization and the end user. The end user can identify the organization through the use of a brand name or a trademark. The organization has contracts with distributors, which in turn sell to stores where end users buy the product.
A: Yes.
Clause 8.2.2 (N780):
Q: In clause 8.2.2 it is stated that: “An audit programme shall be planned, taking into consideration the status and importance of the processes and areas to be audited, …”.
Is it a requirement of this clause that the criteria to determine the status and the importance of the processes and areas to be audited have to be documented?
Background: There is divergence with the auditor regarding a requirement for documentation of “status and importance criteria” despite the fact that evidence was provided that the planning of the audit programme has taken the status and importance of the processes and areas to be audited into consideration.
A: No.
Clause 8.3 (N698.1r):
Q: When an organization detects, after delivery or after use has started, a product which does not conform to one of the “requirements specified by the customer” (Clause 7.2.1 a)), does the standard require that the organization inform the customer of the nonconforming product?
A: No, The last paragraph of Clause 8.3 specifies that it is the organization’s responsibility to take appropriate action regarding the nonconforming product.
Clause 8.3 (N698.2r):
Q: When an organization detects, after delivery or after use has started, a product which does not conform to one of the “statutory and regulatory requirements related to the product” (Clause 7.2.1 c)), does the standard require that the organization inform the competent authority of the nonconforming product?
A: No, The last paragraph of Clause 8.3 specifies that it is the organization’s responsibility to take appropriate action regarding nonconforming product.
Clause 8.3 (N742):
Q: A product is at the final stage of realization and a nonconformity is found on a product related requirement which had been specified by the customer (ISO 9001:2000 7.2.1 a)). The organization believes that the best solution is to accept and deliver the product as is, i.e. with a nonconforming characteristic. The customer has not issued instructions on the reporting of nonconformities. Does Clause 8.3 require a concession by the customer for the use, release or acceptance as is of the product?
A: Yes, Clause 8.3 identifies three different ways to deal with nonconforming products. Clauses 8.3 a) and c) do not apply in this case. Clause 8.3 b) specifies that the use, release or acceptance shall be authorized. In this case authorization involves a concession by the customer. Furthermore, Clause 5.2 requires that customer requirements are determined and are met.
Clause 8.5.1 (N717):
Q: Does the continual improvement of the QMS required by Clause 8.5.1 also cover the “improvement of the product related to customer requirements” required by Clause 5.6.3 b) to be included as an output of the management review?
Background: Clause 5.6.3 mentions in bullet a), the improvement of the “effectiveness of the quality management system” and adds, in bullet b), the “improvement of the product related to customer requirements”. Clause 8.5.1 requires only the “improvement of the effectiveness of the quality management system”, with no mention to the “improvement of the product related to customer requirements”.
A: No.
Clause 8.5.3 a) (N853r):
Q: Does sub-clause 8.5.3 a) require organizations to demonstrate, with objective evidence in the form of records, that they have undertaken actions to determine the existence of “potential nonconformities and their causes”?
A: No.
Aqeel Abbas
#39
You quality objective can be like ....
To improve this this this (desirable) from this this this level to this this this level by this this this time with a this this this periodic review.
To reduce this this this (un-desirable) from this this this level to this this this level by this this this time with a this this this periodic review.
Measurable offcource ~~~
Pick them objectively so as to tempt you to go get it. It must not be too easy nor too unreachable. It all depends upon your process and its capability.
For a start up company which does not have enough non conformity data and which is just starting its operations, what kind of mesaurable objectives can be set and how? Can objective be set like : to gather this this this data by this this this date and to improve them by this this this amount with this this this periodic review?
Please help. Thanks
John Broomfield
#40
Please help. Thanks
Aqeel Abbas,
These are the data required by 8.4:
a. Product conformity data
b. Customer satisfaction data
c. Process performance data
d. Supplier performance data
May I suggest that you initially tie your quality objectives to these data streams?
From each of these data you can obtain the information you need to set your objectives and see how well your management system is helping your organization to meet them.
You do not need nonconformity data yet (the inverse of 8.4a).
John
A Measurable Quality Objectives of the Corporate Communication Department ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
D Top Management Quality Objectives - Setting objectives and Measurable goals ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
W Measurable Quality Objectives which can relate to Quality Policy - 5.4.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
J Quality Objectives and resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
U Examples of Quality Objectives for a Medtech start up ISO 13485:2016 - Medical Device Quality Management Systems 4
V Quality Objectives - ISO 9001 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
I Quality Policy and Objectives examples Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 5
M Specific Values of Quality Objectives Benchmarking 7
Q Quality Objectives Not Met - Resources promised by investors ISO 13485:2016 - Medical Device Quality Management Systems 4
V What plans have been put in place to achieve quality objectives? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Objectives in Quality Policy ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
K ISO 13485 section 5.3 Quality Policy - No framework for establishing and reviewing quality objectives ISO 13485:2016 - Medical Device Quality Management Systems 2
S QUALITY OBJECTIVEs for third party garments factory inspection ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R ISO 13485 Software validation procedure and Quality Objectives Monitoring wanted Document Control Systems, Procedures, Forms and Templates 1
F Quality Objectives - Where in the QMS Quality Objectives should be located ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Farley.0 QMS Sales Goals & Quality Objectives Manufacturing and Related Processes 22
qualprod Annual SWOT for 4.1? I plan to revise quality objectives and strategic route ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Setting Quality Objectives (for the first time) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
V Discussion of ISO 9001:2015 - "Quality Objectives" term ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
P Quality objectives - must they include CAPA and internal audit topic? ISO 13485:2016 - Medical Device Quality Management Systems 28
S Quality Department Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
K Where in the quality manual do I put our Quality Objectives and our Quality Policy Quality Management System (QMS) Manuals 19
R ISO 13485:2016 - Quality Objectives Regulatory Requirement Examples ISO 13485:2016 - Medical Device Quality Management Systems 1
Q Additional KPI to Top Management beside Quality Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
R Examples of Quality Objectives related to ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 6
Q Setting Quality Objectives with a Timeframe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Identifying Objectives & Targets for Quality Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
R 5.4.1 Quality Objectives - Nonconformity: The process was not fully effective ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
dubrizo If Quality Objectives are not known to employees, is it a Nonconformance? General Auditing Discussions 7
M Quality Objectives and Monitoring & Measurement of Processes - Clause 8.2.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T Corrective Action for Quality Objectives which are not Measureable Nonconformance and Corrective Action 7
T Best place in QMS to manage Quality Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q Quality Objectives for Quality Control and Quality Assurance functions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
T Setting Quality Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K Are Quality Objectives applicable on HSE Department? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J Will these Quality Objectives cover the Product Requirements? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Presentation for tracking Quality Objectives across sites Preventive Action and Continuous Improvement 3
M Quality Objectives - Acceptable Levels and Functions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 37
H ISO 9001 Quality Objectives Scorecard or Matrix template to share ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Setting Quality Objectives for Service, Repair and Sales ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Understanding Quality Objectives, Metrics and KPI ISO 13485:2016 - Medical Device Quality Management Systems 15
L Changing Quality Objectives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
G Differences between Quality Objectives and Business KPI's ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Where to document Quality Objectives ISO 13485:2016 - Medical Device Quality Management Systems 6
J Quality Objectives for Engineering Department and R&D Quality Manager and Management Related Issues 5
A Quality Objectives 5.4.1 - KPI SOP - ISO 13485 Audit Observations EU Medical Device Regulations 6
A Are Explicit Quality Objectives Required? Quality Management System (QMS) Manuals 8
G Defining Quality Objectives for Product Realization and Design and Development AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
J Quality Objectives - Telephone Calls ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S Quality Objectives for Aerospace Chemical Conversion & other Surface Treatment Plant AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
