Do Test Methods completed to a standard require validation?
d.conroy
My company designs and manufactures wound dressings.
We complete a range of dressing adhesion and moisture absorption tests that are taken directly for a an ISO standard, do these require validation under 13485?
Any suggestions welcome.
Ninja
Looking for Reality
I'm not in medical at all, so let me answer your question with questions instead...
How do you know the results you got were at all accurate or reproducible?
If you ran the test over again, would you get similar results or wildly different?
How do you know you ran the tests correctly?
d.conroy
Good questions, in general the standard has an annex addressing repeatability and reliability, where the test was performed in several labs and shown to be repeatable and repoorducable.
How do you know the results you got were at all accurate or reproducible? ---We use equipment that is as accurate as required by the standard, and it is calibrated within the correct limits of accuracy and reproducibility.
---We get similar results.
---You never really know that unless you are repeating each sample you test. The equipment is shown to be run repeatable at annual calibration.
That's my opinion, does anyone else have an opinion?
Ninja
Looking for Reality
That is THEIR results, not yours...they don't count (other than to show the technique is viable).
That means the equipment is capable of giving good data...not that your data is good...equipment vs. how equipment is used type thing...
Hmmm...this means you've already tested the equipment and technique together...multiple times...makes me think you've already validated it...so what are you asking?
Have you already validated it and just not called it "validation"?
You can "know it" if you put a known or standard in the mix and gotten the expected results...
Interested in others' responses...
regork
@d.conroy - IMHO, no. I would need to understand what the standard is and what the regulatory body requirements are for you to meet that standard.
Regards,
Steve
Ed Panek
QA RA Small Med Dev Company
This is a confusing question. If you manufacture wound dressing I sure hope you validate the dressings with real wounds at some point before shipping them globally by the truckload. Im only familiar with 60601 standards. If we test a product to the 60601 standard it passes that standard. We still need to verify and validate our device in its intended use.
BradM
Some really good points made already.
I don't think you need to validate the method; but you do need to qualify your process using the method.
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
S IVF medical devices standards and test methods Medical Device and FDA Regulations and Standards News 4
0 Improvement and Standardization of Test Methods between Sites Capability, Accuracy and Stability - Processes, Machines, etc. 5
C Comparing Two Test Methods - Acceptable Difference(s)? Statistical Analysis Tools, Techniques and SPC 3
M Biocompatibility Test Methods for Sensitization US Food and Drug Administration (FDA) 5
S Writing a Test Method Validation Procedure as well as Validation of Test Methods General Measurement Device and Calibration Topics 1
Z ISO 3108 Wire Rope Tensile Test Methods General Measurement Device and Calibration Topics 3
6 Fuel Testing Laboratory Test Equipment - Methods and Calibration General Measurement Device and Calibration Topics 2
C BS EN ISO 12952-1 thru 4 - Test methods for burning behaviour of bedding items Other ISO and International Standards and European Regulations 2
S Attribute vs. Variables Specifications - Test Methods Benchmarking 15
M Test Methods for Angle Blocks, Squares, Feeler Gages, Protractors, and Steel Rules General Measurement Device and Calibration Topics 2
M Laboratory: Different Standard Designations for the Same Test Methods Design and Development of Products and Processes 7
M Assigning a PDF for Analog Resolutions - OIML R49-2 Test Methods for Cold Water Meter Measurement Uncertainty (MU) 3
Q Ford's for material test methods for tensile strength, compression deflection, etc. Customer and Company Specific Requirements 4
T ISO 7587 - Electroplated coatings of tin-lead alloys - Specification and test methods Various Other Specifications, Standards, and related Requirements 1
M Knowledge of test methods in order to conduct an internal audit to ISO 17025? ISO 17025 related Discussions 3
E Test report to certify compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 1
E Tensile test machine, tinius olsen 602 Manufacturing and Related Processes 1
M Test failure Root cause not found Customer Complaints 10
D Tip test 10° -> 5° IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M Sponsor name presented in the test report EU Medical Device Regulations 4
M Packing Validation & Accelerated Aging Test ISO 13485:2016 - Medical Device Quality Management Systems 2
S OEM full range calibrations vs Validation special test points Medical Device and FDA Regulations and Standards News 0
S Shelf Life Test for IFU and Implant Card Other Medical Device Related Standards 1
S Critical characteristic on manufacturing operations test procedure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
S Knee Implant (Femoral -Cobalt chrome)-Sub chronic toxicity test (ISO 10993-11)choice of root Medical Device and FDA Regulations and Standards News 2
S Non parametric test for semi-quantitative data. Statistical Analysis Tools, Techniques and SPC 5
Ed Panek Disaster Recovery Test IT (Information Technology) Service Management 3
Z Is Op Amp Common-Mode Rejection Ratio (CMRR) test applicable to battery operated devices? Other Medical Device Related Standards 0
E When to perform accelerated aging studies and transport test(OQ or PQ) Qualification and Validation (including 21 CFR Part 11) 4
A Test requirements for marketing in US when RATED values are not of US IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
H Secondary Circuits, Voltage Test and Clearance/Creepage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
S Fogging test as per DIN 75201(50ug/g ) VDA Standards - Germany's Automotive Standards 3
R HV Test of HF Surgical Unit IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
E 60950-1 resistance to abnormal heat test Various Other Specifications, Standards, and related Requirements 0
S User evaluation for self monitoring blood glucose test systems US Food and Drug Administration (FDA) 4
E MSA for Push and Pull test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
J Confusing on Harmonic Emissions/Voltage Fluctuations/Flicker test for CISPR 11 Class A Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
