Do they use the same standards: Stand-alone software and embedded software?
CoWorkerM
any comments are appreciated to the following question, which I will demonstrate using an example:
Suppose you as manufacturer are building a medical device which is a medical system consisting of
- a medical equipment: an ECG sensor consisting of patient cable, electronic including CPU, embedded software, housing, USB connector to the PC
- non-medical equipment: PC including peripheries as printer etc
- a medical device: PC software working on the PC for recording, saving, printing, exporting, evaluating, and archiving the ECG recordings
Which software standards have to be applied?
1) IEC 62304 for the PC software and IEC 60601-1, chapter 14 PEMS for the embedded software in the ECG sensor?
2) IEC 62304 also for the embedded software in the ECG sensor?
3) IEC 60601-1, chapter 14 PEMS also for the (stand-alone) PC software?
Remarks: IEC 62304 states in "1.2 Field of application": This standard applies to the development and maintenance of MEDICAL DEVICE SOFTWARE.
IEC 60601-1, 3rd ed.: PEMS consists of PESS and PESS contains per definition one or more CPU.
Looking at those definitions, it is most straight forward to say "yes" to all three questions.
c.mitch
To begin with, I exclude the non medical equipmt of this discussion.
Yes, this was my first thought when I read your post. I usually think 60601-1 equals embedded and 62304 equals software.
This is my second thought. Well, if there is software in the ECG sensor, then 62304 should be applicable (see field of application of the standard).
But section 14 of 60601-1 already defines requirements about software.
So, what to do?
It depends on the size of the embedded software. If it is a very small software made (say, one or a few source files) then 60601-1 section 14 is enough. If the software is big enough to do what's required by 62304: architectural design and detailed design, then 62304 is applicable.
Coming back to your case. Since your embedded sw communicates with the
PC, I would say that it is relevant to consider both as two parts of a system and apply 62304 to the whole.
No, standalone software is immaterial has no applied parts and is not subject to hardware mechanical/chemical/physical hazards. Thus it is not covered by 60601-1.
Regards.
Mitch.
I would highlight the fact that clause 14 of 60601 states that it only applies to software that provides 'Essential Performance' or 'Basic Safety'.
And Annex C of 62304 shows how it is related to other standards, including 60601. It points out that Software Validation is not covered by 62304, as it is a 'system' level requirement. See figure C2 for a diagram of the portions of the "V model" of software development that lie outside the scope of 62304.
So, in answer to the original question of which standard to use - both of them.
CoWorkerM
To answer to Pads38:
Embedded software in an ECG sensor is not a small program, actually it has to cover the A/D process, the pacemaker detection in the signal, the configuration of sample rate and amplification, the buffering, the protocol handling and some other minor tasks. It also - in most cases depending on the intended use - provides 'Essential Performance', because ECG signal malfunction (modification or artefacts) could be a hazardous situation which potentially leads to wrong diagnosis.
So you mean: both of them for both software: embedded and stand-alone?
To answer c.mitch:
This is a great argumentation, I am thinking about it...
CoWorkerM
I would like to add some information to 3) also to follow up the discussion with c.mitch:
60601-1 states in 1.1 (Scope of application) that this norm applies for the 'Essential Performance' or 'Basic Safety' of medical electrical equipment (ME equipment) and medical electrical systems (ME systems).
A ME equipment is a device that connects to the patient (to shorten it a bit).
A ME system is a combination of devices that at least holds one ME equipment.
Now, the ECG sensor is a ME equipment, and therefore 60601-1 applies.
The PC with the PC software can be - looking at the example described in image A.7 (appendix 3.8)
- either together with the ECG sensor and the electrodes ONE ME equipment if the manufacture wants this to be so. This may result in other difficulties (eg. the verification of 60601-1-2 together with the PC). In this constellation the PC and the PC software is within the ME equipment and therefore 60601-1 and chapter 14 PEMS applies for the PC software also.
- or it can be part of a ME system where the system consists of the ME equipment (the ECG sensor) and another device, the PC (office device) with the PC software (which is a medical device). In this case, the PC software is a part of a ME system, and this hole system is a PEMS.
(see definition of a PEMS: ME equipment or ME system holding one or more PESS). Now, the PC software is a PESS of PEMS of a ME system and therefore 60601-1 applies also for the PC software.
Being logical, 60601-1 always applies to PC medical software, as long as the PC with the software is the part of a ME system as in our case.
Another argument is, such systems of PC-based ECG diagnosis are older than the 62304. And before, the 60601-1-4 (PEMS in 2nd edition) has been applied. Why should this stop now, just because 62304 has been published?
So, is there anybody out of the FDA, the NB or the writers of the norms or what's with the other applicants who know what to do and why?
CoWorkerM
adding to the question 2):
In a document shortly published by the team NB:
[www].team-nb.org/documents/2013/FAQ_62304_Final_130804.pdf (sorry, not having yet posted 10 posts, I was not able to include links. Pls. reconstruct)
we find in section 2.1 "Scope of EN 62304":
Assuming all software has a medical purpose, does the standard apply to the following?
b) Embedded software including FPGA's with single chip computers
Answer: "Software executed on a processor (can also be part of a FPGA) during the intended operation is considered a software item under EN 62304."
Embedded software is included in the scope of 62304?!
sagai
It is more or less only up to your regulatory plan for your particular product and/or also up to the compliance explicitly may be declared in you quality management system.
Other than that ... nope ...
One question relates to this subject. Are you looking into IEC/TR 80002-1:2009 as well?
Regards
S Is firmware or embedded software subject to the same standards as software? Qualification and Validation (including 21 CFR Part 11) 9
V Sister companies selling same medical device under different names ISO 13485:2016 - Medical Device Quality Management Systems 3
Scanton Double Major for the same infraction? IATF 16949 - Automotive Quality Systems Standard 11
G Same parts but new customer - What will the auditor ask me? IATF 16949 - Automotive Quality Systems Standard 2
K 510K new manufacturer but same components Other US Medical Device Regulations 6
A Several sections of traditional 510(K) have the same or similar requirement of content. US Food and Drug Administration (FDA) 4
J Sub-supplier change from manual to automated process - same specs - Report to FDA? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Q Must product name be listed the same name in FURLS, UDI, GUDID and Company Website? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
B Unit of Use DI (Device Identifier) - Products using the same device US Food and Drug Administration (FDA) 0
G Same intended use devices - Technical file EU Medical Device Regulations 5
K More than one importer for the same device EU Medical Device Regulations 3
Q Legal Manufacturing Address Change – multiple registrations at same address 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
K Validation of new machine (second machine of the same type) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
M MSDS process audit - Can any one give idea for checklist of the same Occupational Health & Safety Management Standards 14
L PMA and Non-PMA parts in same finished goods area? Federal Aviation Administration (FAA) Standards and Requirements 1
D CE Marking Requirements MDD & MDR - new product development covered under same scope EU Medical Device Regulations 1
C Failure nets - Same level effects FMEA and Control Plans 0
C Subsidiaries; same/different Quality Policies? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
qualprod Add new action plans in CA, while waiting effectiveness - Same problem reappears ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
C Can a manufacturer (in South of Korea) have multiple Brazil Registration Holder (BRH) for same brend name? Other Medical Device Regulations World-Wide 1
S Multiple Authorized Reps in the EU for the same device? EU Medical Device Regulations 3
Z Two Payment Identification Number (PIN) for the same order in DFUF website 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
L Help me to decide which test to use - If each proportion belongs to the same population Using Minitab Software 7
qualprod Write down same nonconformity in several processes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J UDI Requirements - Products that all fall under the same family 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
S Is an Annual Layout Inspection the same as an Annual Re-validation? Internal Auditing 1
B AS9100 Multiple Distributor warehousing locations under same Company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
GStough Informational SN EN ISO 9001:2015 and SN EN ISO 13485:2016 on Same Certificate? Registrars and Notified Bodies 7
A Doubt on multiple inspection carrying out for same balloon number during Stage Inspection and Final Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
I Corrective Action Tracking for Product and Process in the same system? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
MrTetris Informational Risk Register - Same hazardous situation, different severity of harms ISO 14971 - Medical Device Risk Management 7
K Is minimum repair or replace guarantee period for medical devices in EU the same as consumer guarantee law of 2 years? EU Medical Device Regulations 5
D IATF 16949: Do we have too many processes? Are they all the same? Registrars and Notified Bodies 7
S CE Marking requirements - A Medical device with different config sold under same name EU Medical Device Regulations 0
qualprod ISO 9001 - Cl 6.1 and 9.3 and 10 - Opportunities for Improvement the same? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
P Is throughput yield the same as FPY or FTY? Rolled Throughput Yield Manufacturing and Related Processes 3
J Is a stable process also normal at the same time? Manufacturing and Related Processes 7
qualprod Transition and recertification at the same time? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Legal requirement for same indications as in Country of Origin Other Medical Device Regulations World-Wide 4
H Numbering for documents with same content but different language ISO 13485:2016 - Medical Device Quality Management Systems 4
D CE Mark with same NB (Notified Body)? CE Marking (Conformité Européene) / CB Scheme 4
A Why I get a different kind of regression equation when I do the same data in a differ Using Minitab Software 7
B PMCF study plan is same to clinical investigation plan? EU Medical Device Regulations 3
W Is sharing resources treated same way as remote function? IATF 16949 - Automotive Quality Systems Standard 1
K Is an annual "audit schedule" the same thing as an audit scope/ audit plan? Internal Auditing 8
Jane's You may or may not have the same person managing Operations and QA ISO 13485:2016 - Medical Device Quality Management Systems 18
S Is it advisable to do MDSAP and ISO 13485:2016 at the same time? ISO 13485:2016 - Medical Device Quality Management Systems 11
Q Risk Analysis - Same Risk Treatment for Context and Interested Parties ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N Gantt Chart / Time Tracker in Excel - Combining Tasks on the Same Line Excel .xls Spreadsheet Templates and Tools 2
F CE and FDA Mark on same IVD/Medical Device Label EU Medical Device Regulations 12
