Do Volume Spikes impact Quality Scores and Utilization? Which Tool To Use
Mayank Trivedi
Hello all,
We work in a financial services process which supports Asset management services. This is a back end support for processes that take place in the US.
To support the work that comes in we have 50 resources but during tax season, between December and April, we increase resources from 62-65. During tax season work volumes spiral up.
Two of the matrices we work on are utilization of the resources and their quality scores. These scores however are not reported at the individual level to the client. What goes to the client is a monthly averaged score for all resources.
The client wanted to know if the spike in the volume impacts quality scores and utilization. And how are they related.
We have data for the last 27 months i.e. 27 data points each for volume of work each month, utilization and quality scores each month.
Does it make sense to do a correlation test with these 27 data points?
Or will it make sense to do a paired t-test to see how these 50 associates perform before and after the peaks? What does it imply if the performance remains the same in spite of spikes and that they do more amount of work during spikes?
Regards,
Re: Which Tool To Use
before choosign any statistical test, the best approach is to simply plot your data in time series and in this case in a scatter diagram. Onc ewe understand the data patterns we can determine the correct statistical test.
can you post your data? or perhaps the plots of our data?
Steve Prevette
Deming Disciple
Hello all,
Regards,
Have you done a control chart to see if the averaged data are changing on a monthly basis? I would assume as work and people ramp up for the tax season you could see scores go up or down, but the important thing is to run the SPC and see. As suggested by Bev some form of scatter or plotting two variables at a time may allow you to see if there is some correlation visually, but that would not necessarily be significant.
One effect you might see is a reduction in the variability of the data as you average more people together, but I doubt you'd be able to see that in only two cycles.
M Should volume of sales be factored into risk probability assessments? ISO 14971 - Medical Device Risk Management 33
CPhelan Best metrics for monitoring low volume (<1000) parts per vendors Supply Chain Security Management Systems 1
Z Best Practices - small volume medical device tube cutting (0.020" to 0.080" OD)? Manufacturing and Related Processes 3
M Medical Device News TGA update 26-09-18 - Medical Devices Safety Update, Volume 6 September 2018 Other Medical Device Regulations World-Wide 0
A Maximum bubble volume for subcutaneous injection IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
G Stable, Predictable, Control - High Volume Mfg Statistical Analysis Tools, Techniques and SPC 9
M David vs Goliath (Large Suppliers vs Low Volume Purchasers) Supplier Quality Assurance and other Supplier Issues 11
B IEC 60601-2-24 - Defining Storage Volume IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
B Determining the "storage volume" (ISO 8536-8:2004 clause 6.14) Other Medical Device Related Standards 4
B Determing Machine Capability in a High Mix, Low Volume Sheet Metal Shop Manufacturing and Related Processes 4
S How to Capture Low Volume Process Info? Lean in Manufacturing and Service Industries 3
M Need Machining Low Volume Family Control Plan and PFMEA APQP and PPAP 1
C Suggestions on Sample Plans for High Volume/Low Cost/Low Risk Components Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S FMEA Manual aimed at Low Volume Fabrication Industry FMEA and Control Plans 1
J CAPA Effectiveness Checks on Low/No Volume Processes Nonconformance and Corrective Action 7
J How to determine a Capability Study for Low-Volume Suppliers Capability, Accuracy and Stability - Processes, Machines, etc. 3
J Use of PPMs in Low Volume Machine Shop AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
K Probability of Occurrence Ranking for Low Volume Manufacturing vs High Volume FMEA and Control Plans 11
A Quality Improvement in Low Volume Manufacturing Quality Tools, Improvement and Analysis 3
M PPAP on Low Quantities (Low Volume Manufacturing) APQP and PPAP 6
Q Process Control in High Volume Custom Electrical Enclosures Environment Statistical Analysis Tools, Techniques and SPC 4
V Injectibles PFS with PEN-Device 'Deliverable Volume' vs 'Volume in Containers' 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
M What is an acceptable PPM for large volume fasteners? APQP and PPAP 6
6 JSP 456 Volume 3 (Catering Standard for the UK Military) Information wanted Food Safety - ISO 22000, HACCP (21 CFR 120) 3
G Any Statistical Model for Low Volume Capital Devices? Manufacturing and Related Processes 4
S Audits in Volume Manufacturing vs. Confidence/AQL Levels Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
A How to control and improve the suppliers of low volume purchases ? Supplier Quality Assurance and other Supplier Issues 9
P Corrective Action Verification for Low Volume Production Nonconformance and Corrective Action 3
R Volume of Alarm Signal per IEC 60601-1-8 IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
M GRI (Global Reporting Initiative) En 1 Materials used by Weight or Volume Sustainability, Green Initiatives and Ecology 1
B Is Liquid Reagent Volume Underfill a Recall Requirement? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
K Low Volume Products Data Analysis help needed Statistical Analysis Tools, Techniques and SPC 6
N Sampling Plan for Small Low Volume Shops - Biggest order was 200 AQL - Acceptable Quality Level 7
D Aerosol Volume required for a Specific Pressure Manufacturing and Related Processes 2
K Process Validation of Low Volume Production of Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 9
M Where to buy VDA volume nr 12 in English Language VDA Standards - Germany's Automotive Standards 2
S FSC Chain of Custody - Volume Control & Conversion Factors Various Other Specifications, Standards, and related Requirements 7
R Implementation of TS 16949 for Low Volume Production IATF 16949 - Automotive Quality Systems Standard 2
L SPC in Low Volume Manufacturing - 5 flanges will be produced per month Statistical Analysis Tools, Techniques and SPC 16
E Environmental Screening of PCBAs in High Volume Electronics Contract Manufacturing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S Sampling plan for Inspection by Variables (high volume production) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S Density Measurement of small volume of sample Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
F Supplier Rating System - Weighting low volume suppliers vs. high volume suppliers Supplier Quality Assurance and other Supplier Issues 2
A Tabular Gap Analysis of the EU (volume 4) and US (210/211) cGMP Regulations Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
D PPM (Parts Per Million) for Low Volume Production Quality Tools, Improvement and Analysis 1
K Change in Occurrence for Low Volume Assembly Process FMEA (PFMEA) FMEA and Control Plans 8
apestate How to calculate volume of material removed during threading? Manufacturing and Related Processes 13
S Water to Surface Water - Discharging a Volume of Water to Controlled Waters Miscellaneous Environmental Standards and EMS Related Discussions 5
A Definition Low Volume Manufacturing - What is Low Volume Manufacturing? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
D Should low volume supplier PPM comparisons consider level of opportunity for error? Quality Tools, Improvement and Analysis 2
