The standard clearly allows for errors/nonconforming outputs NOT to be treated via a corrective action. ISO 9001:2015 10.2.1 b). evaluate the need for action....
There will be non-critical, non-repetitive issues where correction only is adequate.
10.2.1 The intent of this subclause is to ensure that the organization manages nonconformities, and implements corrective action, appropriately.
When a nonconformity occurs (including those arising from complaints; from identified nonconforming outputs [see ISO 9001:2015, 8.7]; problems arising from external providers or other relevant interested parties; audit results; or the effects of unplanned changes), the organization should take action to investigate what has gone wrong, to correct it if possible, and to avoid similar issues from recurring in the future. The organization should seek to eliminate permanently the causes and consequent effects of problems that could have a negative impact on its:...
The organization should take action to control or correct any nonconformity. This can be achieved by containing the problem while investigations continue...
When evaluating the action needed for a nonconformity the might be instances where the cause of a nonconformity cannot be eliminated, therefore, the organization should consider taking actions to be able to detect and minimize the effects of the nonconformity if it were to occur again.
That said, I understand small things should get small actions as long as we stay aware of repeats and/or occurrence elsewhere. That is why I put the Corrective Action Log into the Resources, which (based on three criteria) includes a low-risk level "3W" option (Who will do What, and When); the entries in there can be tracked for recurrence.
