Do we have to find an ISO clause to define a nonconformity?
darkafar
ISO19011 defines “audit criteria” as “set of policies, procedures or requirements”, and “audit findings” as “results of the evaluation of the collected audit evidence against audit criteria”.
So I think for an internal audit it is unnecessary to find an ISO clause to define a nonconformity, as long as the procedures, laws, quality policy, or customer requirements are not followed
My friends disagree, so I want to see if someone here shares my view.
antoine.dias
From the ISO 9001 requirements ( used as basis for a lot of other standards )
Quote :
8.2.2 Internal audit
The organization shall conduct internal audits at planned intervals to determine whether the quality management system
a) conforms to the planned arrangements (see 7.1), to the requirements of this International Standard and to the quality management system requirements established by the organization, and
b) is effectively implemented and maintained.
Unquote
( I did add the underlining )
So, from this requirement it is very well possible that a non conformity can be set against an internal requirement (e.g. in a procedure) without the need to refer to an item in the standard.
Best regards,
Antoine
chergh - 2008
When raising and reporting NC's in internal audits I never mention a standard clause. I will raise NC's against our internal documents, sales orders, service level agreements etc. but never an ISO standard clause. Most of my internal audit team have never read the ISO 9001 standard that we are certified to. Our system is built to conform to the 9001 standard and by auditing against our processes and procedures we ensure that our QMS conforms "to the requirements of this international standard" 8.2.2.a.
When new processes are being introduced or existing processes modified I will be involved and will ensure that ISO 9001 requirements are met.
chergh - 2008
In addition to what I just wrote I also believe that raising NC's against an ISO standard, as it is an external document to which our company has had no input to, would also lead to an increase in negative perception about our QMS where as raising NC's against internal documents etc. is less likely to as these are what we as a company have decided to do.
Craig H.
Why not cite both the internal nonconformance and a reference to the applicable ISO 9001 clause?
Antonio Vieira
Involved - Posts
However we must consider one different kind of internal audit.
Those I’m hired often to do:
- Internal audits made by an external auditor, just before registration audit.
In this kind of internal audit I’m always told by the quality manager of the audited organization that I should perform the audit on the basis of ISO 9001 requirements.
Of course that if we consider the real internal audit we just have to check if internal processes are according to what is supposed to be. But this is only possible assuming that the system is already according to ISO 9001 requirements, otherwise we will have a process audit and not a system audit.
:cool:
chergh - 2008
I just don't see any benefit in citing the ISO clause. Myself and my boss may get some benefit by having a look at number of NC's versus the ISO clause but in general the auditor is not going to be capable of assigning an NC to the appropriate clause and I see no benefit at all to the auditee or the process owners.
Craig H.
I have certainly been in situations where being able to "show the shall" in the standard has ended "discussions" with groups I have audited.
If you feel comfortable running around uncovered like that, then by all means...
chergh - 2008
Uncovered like what?
I would much rather spend more time convincing the process owner there is a real benefit to the item/activity rather than saying "we have to do it to comply with ISO 9001". Quoting 9001 is more likely to result in reinforcing negatives attitude towards the QMS than anything else.
Craig H.
I would much rather spend more time convincing the process owner there is a real benefit to the item/activity rather than saying "we have to do it to comply with ISO 9001". Quoting 9001 is more likely to result in reinforcing negatives attitude toward the QMS than anything else.
Believe me, I despise doing anything just "to meet the standard" (see my rants on "Customer Satisfaction" for example). But, there have been times when corner-cutting has been proposed, or worse, and some folks will not take the word of someone outside of their "area of expertise". But, responding with "Upper Management has said that this is the way we are going to do it. Are you sure you want to be the one who varies?" is the final, use only as a last resort, trump card.
I have only resorted to "this is the standard" a couple of times internally, but ultimately the standard is what we, as QA folks, are held to. To me, covering ourselves with knowledge and application of the standard, however difficult to see on the surface, becomes a matter of survival.
Again, if you are comfortable with another approach, then so be it.
D Where I can find an ISO 13485:2016 Audit Schedule example? ISO 13485:2016 - Medical Device Quality Management Systems 4
P Calibration in the UK to ISO 17025..cant find anyone ISO 17025 related Discussions 8
P Where to find conformance statistics for ISO 15189 Other Medical Device Regulations World-Wide 1
H How to find a good ISO 9001 Implementation Consultant in Calgary, Canada? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M How to find a Good Registrar (Certification Body) for ISO TS 16949 certification Registrars and Notified Bodies 3
B IEC 60601-1 3rd Edition adoption - I cant find this standard on the ISO page Reliability Analysis - Predictions, Testing and Standards 9
K ISO Certified, now where to find work? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
Q How to find definitions from ISO 9001 when implementing ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 8
SteelMaiden Help me find ISO Standards list Other ISO and International Standards and European Regulations 8
apestate How do you find nearby ISO 17025 registered calibration laboratories? ISO 17025 related Discussions 1
I ISO 9001:2000 Implementation Project: How to find assistance (training, consulting)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 54
J ISO 9001 Certification/Regist Database to find ISO9001 Registered companies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S Trying to find the actual ISO 17025:2005 standard requirements ISO 17025 related Discussions 6
A Where can I find a list of all ISO/TS 16949 registered companies? IATF 16949 - Automotive Quality Systems Standard 9
D Disaster Recovery Plan - I cannot find references to same in ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 3
C Where can a small company find a automated ISO software package thats cheap Quality Assurance and Compliance Software Tools and Solutions 13
A Where does one find the complete list of ISO standards? Book, Video, Blog and Web Site Reviews and Recommendations 1
K Where might I find the ISO 9001:2000 standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
R Trying to find an ISO 17025 accredited testing laboratory to verify our test results ISO 17025 related Discussions 14
L Where can I find ISO 9000 Promotional items? Misc. Quality Assurance and Business Systems Related Topics 11
Gman2 ISO 9001:2000 Internal Audit: Someone PLEASE find me the "Shall" on "Process Audits" Process Audits and Layered Process Audits 37
S ISO 19011 - Where can I find a copy? General Auditing Discussions 17
T Finding ISO 9001 Certified Suppliers - How can I find them? Supplier Quality Assurance and other Supplier Issues 13
D List of ISO 9001 Registered Companies - Where can I find? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
K ISO and Quality LOGOS - Where Can I Find? Other ISO and International Standards and European Regulations 2
G Where can I find a copy of ISO 10110? Optics and Optical Instruments Other ISO and International Standards and European Regulations 3
D Any recommendations on where to find experienced quality hires in Chicago area? Job Openings, Consulting and Employment Opportunities 3
M Find updates to REACH and Rohs regulations REACH and RoHS Conversations 1
N Where to find Regulations for Reprocessing and Reuse of Single-Use Devices Other Medical Device Related Standards 2
D Where to find Guidance Class II Amendment Canada Medical Device Regulations 1
S How to find technical specification for facilities maintainance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Where can I find examples of PPAP? APQP and PPAP 6
J Where can I find the latest update to Reach and ROHS? REACH and RoHS Conversations 9
G Where to find Proficiency Test provider for photometrics (spectral %R, %T, photo density) General Measurement Device and Calibration Topics 9
C TL-9000 Certifying Body Issue - Auditor failed to find an issue for 10 years TL 9000 Telecommunications Standard and QuEST 16
R How to find out the UMDNS code for medical devices CE Marking (Conformité Européene) / CB Scheme 1
M Plating standards - Where to find information AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Proud Liberal DFMEA / PFMEA linkage - Where in the standards do I find it? FMEA and Control Plans 5
N Where I can find an Excel sample/template for recording Delivery Time and Cost Excel .xls Spreadsheet Templates and Tools 2
R Specification on flare testing extruded aluminum - Where to find Design and Development of Products and Processes 1
A AS9100 Rev:D in Spanish - where can I find a Spanish version? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
I Moving into Clinical Trials and need to find GMP Suppliers 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
B Where can I find an English version of Japan's PMD Act? Other ISO and International Standards and European Regulations 2
S Where to Find DEV and DFE numbers on FDA Website Other Medical Device and Orthopedic Related Topics 3
N Where to find a Qualified FDA Supplier Auditor located in China China Medical Device Regulations 7
G Where I could find any project HSE plan templates Occupational Health & Safety Management Standards 4
A Where to find a Draft Copy of IATF 16949:2016? IATF 16949 - Automotive Quality Systems Standard 23
M How to find the number of required data - Correlation with 4 variables Using Minitab Software 2
I Where to find VDA 6.3 Robust Production Process (rpp) PDF file ? VDA Standards - Germany's Automotive Standards 1
P Where to find the UMDNS code for CE Mark CE Marking (Conformité Européene) / CB Scheme 1
