Do we have to prove a link between the mill and our raw material supplier?
QE1993
We order our raw material from our distributor. The distributor sends us mill certs from the mill that supplied them the raw material. The mill cert states that the mill has sold the raw material to the distributor.
The distributor sends us a packing slip (along with the mill certs). So far, we have been throwing the packing slip away, so there is no documented link between us and the distributor.
I've always found this questionable because we have no documented evidence of the chain of events and now customers are starting to ask us about it too.
How can I explain to coworkers that this link is important?
Ninja
Looking for Reality
We order our raw material from our distributor. ........ there is no documented link between us and the distributor.
Your internal purchase request, signed.
Your purchase order.
Their invoice.
Your check or wire transfer.
Are these not documented links?
What specifically are you looking for, and to accomplish what?
QE1993
They send us a packing slip, which we throw away. I'm trying to convince management that we should be keeping the packing slip.
Golfman25
The question would be why keep the packing slip? It's not the most important document but:
The packing slip is evidence of what they sent you -- description and lbs. You certainly need to verify what you ordered/received with the packing slip to verify any discrepancy.
Also, how do you know what you are being invoiced for is what you received. We are old school and match up our PO, the packing slip, and invoice on each order. That good, albeit old fashioned, accounting 101.
Ninja
Looking for Reality
Keeping a packing slip is a piece of paper in a file drawer...useless.
What VALUE do you perceive the packing list to have?
If it has value, show the value it has.
If you can't...what are you trying to accomplish by convincing people to keep it?
Thus my question above: What specifically are you looking for, and to accomplish what?
Trying to keep a piece of paper with writing on it doesn't help you make the case...what if the packing slip states 1000pcs, and only 500pcs showed up?
What is the PURPOSE of keeping it?
Golfman25
It acts as a record of receipt. We won't pay with a packing slip as evidence of receipt. Could probably work around with today's electronic systems, but we're old.
hogheavenfarm
One of my unofficial duties now is receiving, so I scan everything that comes in with the order, millcerts, packing slips, BOL's, everything, and I deposit the scans into the job file by job number. I cannot tell you how many times this has been valuable when people come asking about things. Of course I have the PO as well, but that is usually already in the job file.
ScottK
Not out of the crisis
I would definitely show a link between the mill and distributor... if there is a problem with mixed material you need to know where the material came from and where the mix may have happened - was it at the mill or the distributor's warehouse? So yes - Id' say you need that link, somehow - whether it's a packing list or a separate cert.
In my last job, in the chemical world with pharma customers, we often had to show every single step in the supply chain, even if it went through multiple distributors, or through multiple sites under one distributor.
Ninja
Looking for Reality
Maybe I'm missing something...
So you have your PO, and possibly an order acknowledgement linking together you and the distributor...the physical supply chain.
So you have the cert, which shows the mill making and testing the material, and the sale (or at least shipping) of that material to the distributor you bought from.
No problem at all if you choose to keep the packing slip, or your own receiving paperwork, or whatever to show that the goods you're about to pay for actually arrived...as long as amount ordered, amount billed and amount arriving and amount paid for all match, there is a lot of freedom in which documents you keep.
Golfman's system chooses to use the Packing list...no problem.
Another system may choose to use the receiver's count...no problem.
Thus my question for a company that has been historically not keeping the packing list...
What is the value of keeping it now? Are you already achieving that value historically?
If not, and there's a break in tracking, certainly keep the Packing list now.
If you already have an unbroken chain, why bother starting to keep the packing list?
The packing list has no objective value on its own.
:2cents:
stevegyro
:2cents:
Agree with GolfMan ...
I’m assuming AS9100. What about the ‘HEAT LOT’ (for raw metals)? Traceability is absolutely needed for critical to function components. If ‘heat’ is not on packing slip now, should not be a big deal to request this from the distributor.
As far as ‘.. not starting additional requirements now ...’, personally I would advise to not do so. Honesty is best policy. Document the added requirement as a new discovery. Just my two-cents. Best regards.
Sent from my iPad using Tapatalk
P How to Scientifically Prove the Importance of a Process - CMMI Process Areas Software Quality Assurance 7
B How to prove that an organization implements anti bribery policy IATF 16949 - Automotive Quality Systems Standard 8
C UDI Label Verification - How do we ensure the barcode is correct and prove it? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S How to Statistically Prove 2 Dimensions are Related Using Minitab Software 18
U Sample size to prove parts are good with 99.73% confidence Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
L What needs to be done to prove compliance with RoHS and WEEE EU Medical Device Regulations 5
A Is MSA useful to prove a Measurement System after Relocation? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P How to prove that Cr oxide makes a stent biocompatible (e-polished 316LVM) Manufacturing and Related Processes 9
P Testing a US device in Europe to prove Equivalence in a ?head-to-head? Study EU Medical Device Regulations 6
J Reliability Prove-out, Pass-Fail Testing Reliability Analysis - Predictions, Testing and Standards 2
K What would you give up to prove conformity and honesty? Internal Auditing 21
S ISO 17025 requirements not enough to prove NIST Traceability? ISO 17025 related Discussions 10
I Prove or disprove that a cube can be cut in 27 smaller cubes in less than 6 cuts Brain Teasers and Puzzles 14
M How do I prove I don't receive a controlled product? Ractopamine Hydrochloride Misc. Quality Assurance and Business Systems Related Topics 4
C Clinical Data to Prove Equivalence Other US Medical Device Regulations 4
U Can anyone prove that: 2x2=5 ? Coffee Break and Water Cooler Discussions 63
D Testing an Inspector to Prove Competency in Visual Inspection Records and Data - Quality, Legal and Other Evidence 2
S Lean System Developer - How should I work to prove myself? Lean in Manufacturing and Service Industries 19
D How to Prove and Explain to Consultant (Internal Auditor) and Manager? Internal Auditing 7
M Planning requirement 5.4: How should the management prove compliance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J How to prove that we conform to legal requirements Miscellaneous Environmental Standards and EMS Related Discussions 11
L Is there any way to prove a process is in control other than with a control chart? Statistical Analysis Tools, Techniques and SPC 6
H How do we prove that we are improving the continual improvement process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
L How do you prove you need resources? Misc. Quality Assurance and Business Systems Related Topics 5
J Finished Goods Testing - Using historical test data to prove finished goods OK Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
A Contract Review - How do you prove it? Contract Review Process 16
K Statistical Hypothesis Testing to prove signficant quality improvement or decline Statistical Analysis Tools, Techniques and SPC 6
dgrainger Medical Device News MDR postponed - link to Official Journal of the European Union (24-4-2020) EU Medical Device Regulations 2
dgrainger Informational Corrigendum 2 OJ link Medical Device and FDA Regulations and Standards News 0
Marc Problem with 21 CFR Part 820 - US FDA Quality System Regulations (QSR) sub-forum link - 2 May 2019 Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 1
D Link between FMEA, flow chart and control plan FMEA and Control Plans 10
F IMDRF opened a Consultation on Annex E & F and the link to ISO 14971 ISO 14971 - Medical Device Risk Management 4
S FEE Registration LINK - EU Medical Device CE Marking (Conformité Européene) / CB Scheme 6
M What is the link between Poka Yoke and Firewall? General Auditing Discussions 2
J Macro Question: Get Column Name by Column Number / or Use Text constant to link on a Using Minitab Software 1
K How to setup DDEs in Minitab to link a project to an Excel workbook Quality Tools, Improvement and Analysis 2
V The best practice to maintain & link Design and Process FMEAs FMEA and Control Plans 8
N Is there a formula to link words in Excel sheet to a graph? Excel .xls Spreadsheet Templates and Tools 5
T How to link Process Design Changes in Serial Production to Design & Development? Design and Development of Products and Processes 6
K Link between Control of Documents, CPAR & Control of Non-Conforming Product Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
somashekar Link to important websites within the Cove Book, Video, Blog and Web Site Reviews and Recommendations 1
M Food Transportation the Weakest Link? Mixing cargo in food trucks Food Safety - ISO 22000, HACCP (21 CFR 120) 0
J How to Link Electronic Records (510k Documents) to Handwritten Signature Other Medical Device Regulations World-Wide 16
A SPC Software Packages - Real Time and can link to Databases including Oracle Statistical Analysis Tools, Techniques and SPC 7
T Dock to Stock Approval form, link or information Document Control Systems, Procedures, Forms and Templates 3
AnaMariaVR2 Link between failure to comply w/ Lab PPE standards & ISO9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Link between Risk Management, Usability Engineering and R&D in Medical Devices ISO 14971 - Medical Device Risk Management 2
S Help needed to link accounting and ISO procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J0anne Link to find 502 (f)(1) which is quoted several times in 21 CFR 820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
S Quality Manual Review - Should the manual link all procedures Quality Management System (QMS) Manuals 5
