Do we have to submit a new 510(k) for a device with a new MCU?
celia4237
Dear all:
We produce blood pressure monitor, and it has get the K number, now we want to change its MCU, so we will do the design modification verification on the new device, and i know that maybe it don't need to submit a new 510(k), according to the guidance document < Deciding when to submit new 510(k) for a change to the existing device>. However, at the same time, we don't want to discard the old design specification. Because the customer may ask for the device with the old MCU, do we have to submit a new 510(k) for the device with a new MCU?
G
gar4guv
i am guessing that MCU means microcontroller. i don't know too much about blood pressure monitors, but it sounds like the MCU is kind of like the CPU of a personal computer.
if that is the case, then i believe installing a new MCU would require a new 510k. my reasoning is this, if you look at flowchart B in the guidance document you mentioned, the first diamond asks if there is a control mechanism change, and the second diamond asks if there is an operating principle change. i am guessing that a new MCU would fall under one of these categories. therefore any of these types of changes would need the submission of a new 510k.
Stijloor
Dear all:
MCU means what?
Stijloor.
celia4237
thank you all.
Please look at this question:we don't want to discard the old design specification.
Let imagine that this kind of modification don't need a new 510(k), but if we want to keep the old design specification. Does it make any difference? Because it seems that if the old specification is kept, it is not a design change anymore, it sounds like a "new device" is created, because it has the entire design file. Do we have to submit a new 510(k) for this device? After all, this "new device" is a little different, isn't it?
G
gar4guv
if you conclude that this design change does not need a new 510k, then i believe you can reference the original K number for both the original model and the new model with the updated MCU.
i see no reason for you to discard the old specifications (unless there is a safety or effectiveness issue). both product lines would still have market approval under the same 510k.
with that said, you should be very certain that this change does not require a new submission. should the agency disagree with you, the new model could be the subject of an expensive recall.
W
wangyang
I want to know it is a rare thing, or everybody follow it?
I
icare2much
What is the difference between the new MCU and the old one? THis is significant. For example - often times a microprocessor is discontinued but the model is superceded by a new device that may have extended capability (that you don't need to use) but is fully backward compatible.
Similarly, is embedded software the same or did it change?
If the new processor is a simple drop in replacement, I think an argument can easily be made that no significant control changes were made.
W
wangyang
I have just got a FDA's response about this question.
You may only market one version or model of the subject device under the current 510(k) clearance. You may market the "old device" using the existing 510(k) clearance and the "new or modified device" using a separate FDA clearance.
supadrai Possible to Submit a 510(k) if you have never, do not and cannot produce the device for which you're submitting the application? US Food and Drug Administration (FDA) 4
Ronen E FDA releases new draft guidance on when to submit a 510(k) for device modification Other US Medical Device Regulations 10
C When to submit a 510(k)? After the DMR (Device Master Record) is finished? Other US Medical Device Regulations 4
shimonv Deciding When to Submit a 510(k) for a Change to an Existing Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 17
sagai New Draft Guidance - When to Submit a 510(k) for a Change to an Existing Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
C When to submit a 510(k) for a change to an exisiting medical device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 29
A Ownership of 510(k) to transfer or submit new one - Class 1 medical device ISO 13485:2016 - Medical Device Quality Management Systems 4
A Submit a 510(k) to an existing device vs. Just Documenting a Change ISO 13485:2016 - Medical Device Quality Management Systems 2
B Submit a 510(k) with a Predicate cleared but not Listed US Food and Drug Administration (FDA) 9
B Submit a Special 510(k) or "Documentation by our own" 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
J Can we submit data with Special 510(k)? US Food and Drug Administration (FDA) 8
A Should I submit the entire copy of my software in a 510(k) submission?? US Food and Drug Administration (FDA) 7
B Deciding when to submit a Special 510(k) US Food and Drug Administration (FDA) 10
C How to Submit an Expansion of Claims 510(k)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
N Can I submit 510(k) without Biocompatibility Test Results? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
C When to Submit a 510(k) in the Product Life Cycle 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
W Is Foreign Exporter required to submit a 510(k)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
E Do I need submit a traditional 510(k) or Abbreviated 510(k) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
P Can I submit a 510(k) without aging data? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
C Only appearance and PCB are changed - Do we need to submit a new 510(k)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
C Application for special 510(k) - What are the documents to submit to FDA? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
F How to submit a PPAP when a subcontractor is the sole manufacturer IATF 16949 - Automotive Quality Systems Standard 2
gunnyshore Adding a new facility - do I need to submit an amendment to the MDL or MDEL, or both? Canada Medical Device Regulations 3
D Does Manufacture can submit CE mark application under MDD with NB for his New product after May 2020? EU Medical Device Regulations 3
F How to submit PPAP without IMDS APQP and PPAP 10
M Informational TGA presentation: How to submit an effective good manufacturing practice clearance application Medical Device and FDA Regulations and Standards News 0
Watchcat EU Certification - What do you submit to an NB EU Medical Device Regulations 5
L Reasons to submit a new PPAP or notify the customer APQP and PPAP 3
L 510k exemption process - Do you still need to submit technical dossier? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
N How to deal with catalog parts suppliers who refuse to submit PPAP documents? APQP and PPAP 0
I Where to submit Adverse Events Reports in Europe EU Medical Device Regulations 7
B Should I Request/Submit a PPAP from/to a Supplier/Customer for only Repackaging Parts APQP and PPAP 7
L 20 days to submit PPAP APQP and PPAP 9
A Using Regulations.gov to Submit Comments on FDA Guidance Documents Other US Medical Device Regulations 5
E When to submit a Technical File for a Class IIb Medical Device EU Medical Device Regulations 3
P Do we need to submit Special 510K for a Blood Glucose System? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
D Customer will not submit Purchase Orders - System for ISO 9001 Compliance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
L Can we submit an AS9102 if we are not AS9100 certified? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
S Guidance to prepare and submit a Level 3 PPAP to a Customer APQP and PPAP 6
I Where do we submit the FAA Preapplication forms? Federal Aviation Administration (FAA) Standards and Requirements 1
O Medical Device Registration in EU - Which Ministry to submit Technical File? EU Medical Device Regulations 9
S How to Submit ISO/TS 16949 & ISO14001 Certificates to HMMA IATF 16949 - Automotive Quality Systems Standard 4
W Submit MDR for a device cleared by FDA but not sold in US? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
P Part Submission Form - Need to submit PSW only once? APQP and PPAP 5
M If I update a DFMEA do I need to submit to my Customer? FMEA and Control Plans 7
Howard Atkins Is there a time frame for CBs to submit the TS 16949 Audit Report? Registrars and Notified Bodies 2
J What is the time limit for an auditor to respond to NCR's and submit audit report? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
S How to locate a Sponsor in Australia to submit Product Approval Applications by TGA Other Medical Device Regulations World-Wide 4
R In 510k application do we submit documents showing compliance with 21CFRPart820 Other US Medical Device Regulations 12
P Does our company need to be certified in order to submit a 510k Other US Medical Device Regulations 4
