Do we need an SOP for ISO 9001?
I'm new to both the Cove and the quality management field so I am hoping to get some input from the experts here.
I'm trying to get ISO 9001 for my company and one of the many advices I have gotten from talking to other quality managers from different ISO accredited companies is that we need to have proper procedures (I assume that requirement comes from Section 8.5 of ISO 9001:2015).
Currently my company has a "quality control manual" that outlines the responsibilities of each department and we have work instructions that provides the general steps for each incoming product to be made. We don't really have a formal "SOP Document" but do we need to make them for each department to satisfy ISO's requirements?
We don't have anything that would instruct the employees how to do their job per say, most of the people here have been working in their dept for 10+ years so they primarily know what to do via experience. The work instructions provides basic steps, like the sequence of steps but nothing too detailed.
Pardon my lack of understanding, I know my current level of understanding is very basic so I appreciate any insight and feedback.
You need to set up processes at your organization that meet the requirements of ISO 9001. Some of these processes must be documented to comply with ISO 9001. The amount (quantity, detail) of procedures you need depends on many factors including the size and type of your organization. Since you are just starting to scratch the surface, you probably will need a consultant to help you implement your quality system. Where are you located? I might be able to help you.
Thank you for the offer, my company is a medium sized company (approx 65 employees) in the Los Angeles area. While I wish I could hire a consultant, my top management is not giving me a budget for one unfortunately.
I thought you might be in California. Maybe because of the "Westside." I'm in the SF Bay Area. I can still be a free resource to you. I will PM you.
Hi Teddy,
Need to have written procedures according to ISO 9001:2015?
NO!
ISO 9001:2015 did away with the term procedure and didn't replace it with anything.
What is required is that you be able to show that you understand the requirements of ISO 9001:2015 and be able to explain how you meet them. Written procedures may help with that, but it is up to you, the organization to determine if you want them and if so to create them.
Over documentation was a pitfall of earlier times in ISO 9001 history. Do all you can to keep from falling into that pit yourself.
To clarify, ISO 9001 does require "documented information." This is typically in the form of procedures and records. However, fully agree that any documentation needs to be value added for the organization. It is possible to comply with ISO 9001 with only policy documents and forms (that become records).
You need to have another look at the standard. More than one. First of all read the appendix about what documented information is where it explains that documented information can be retained documented information and retained documented information. Maintained is documents. Retained is records.
The standared doew say that you need to retain and maintain the documented information required by the standard as well as any retained or maintained documented that the organization chooses to.
No where in the standard is there a requirement to maintain documented information for any procedures unless the organization chooses to do so.
Common practice may include having a quality manual (and I recommend one) and that you have some written procedures, but the standard does not require it! Be careful how much you decide to document or you will be overcome with overdocumentation as happened in the past.
Don't mislead the newbe.
Tagin
Documentation of processes/procedures does relate to 8.5, but also to 7.5.1b ("documented information determined by the organization as being necessary for the effectiveness of the quality management system"). I look at 7.5.1b as taking a 'risk-based' approach to documentation. If your product or service is fairly simple to produce, your staff has low turnover, etc., your documentation needs may be minimal for those processes. But where complexity comes into play, or there is too much to expect staff to reliably remember, etc., then more detailed process documentation, job aids, flowcharts, whatever, could be appropriate. You may also have customer or regulatory requirements for documentation in some areas.
At this early point, it would help to do a gap analysis. This would be where you list the clauses in one column; e.g.,
4.1
4.2
4.3
4.4.1
4.4.2
etc.
In the next column, write down how you currently address the requirements in that clause. This will give you a good perspective on where you need to address shortcomings, and spend your efforts.
I'd also say that's very useful to wrap your head around the PDCA concept of improvement. The structure of the standard describes this kind of big feedback loop, which is intended to promote continuous/continual improvement. It is shown in 0.3.2, but more typically I've seen it with PLAN as clauses 4-6, 7 straddles PLAN/DO, 8 as DO, 9 as CHECK, and 10 as ACT. Once you understand that PDCA structure, it will hopefully become more clear why the standard is organized as it is.
I agree with you, Big Jim. Procedures are not required; however, most companies decide that some procedures are necessary to support their quality system processes. A procedure can be a one-page flow chart. A procedure can be an appendix to a form that explains how to fill it out.
L Do we need a Labelling SOP for ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 5
W ISO 10005 Guidelines for Quality Plans - Do we need an SOP? ISO 13485:2016 - Medical Device Quality Management Systems 1
E CSR SHIPPING - Need suggestions for making SOP/WI for our shipping dept (automotive)... Customer and Company Specific Requirements 11
T Need help understanding AS6174 clause 3.1.5. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
B Spare parts of medical device need CE mark? EU Medical Device Regulations 0
F Change in address for critical supplier - does NB need to be informed? CE Marking (Conformité Européene) / CB Scheme 19
leftoverture REACH Folks - We Need Common Sense! RoHS, REACH, ELV, IMDS and Restricted Substances 23
B Whose waste carrier licence do I need? ISO 14001:2015 Specific Discussions 4
I I need some fun examples of teaching the 5 Whys Lean in Manufacturing and Service Industries 43
R First Time Managing Calibration and Measurement System. Need Help. General Measurement Device and Calibration Topics 19
M CE marked medical device - do they need UKAS certified calibration provider ISO 17025 related Discussions 4
C I need some clearing on requirements of Asuring the validity of results ISO 17025 related Discussions 2
C Need help in determining applicable clause for an audit finding (based on AS9120B) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
K Subcontractors Providing Services Under MDD or MDR need ISO 13485 from EU Notified Body? CE Marking (Conformité Européene) / CB Scheme 8
E Need some peer advice Quality Manager and Management Related Issues 18
S Need clarification on UKCA and "Approved Body" UK Medical Device Regulations 7
S What types of changes need to be notified to NBs? Registrars and Notified Bodies 1
B Do I need a Cleanroom to manufacture Medical Devices? ISO 13485:2016 - Medical Device Quality Management Systems 2
J CMO in Canada do they need MDSAP/13485 certification? ISO 13485:2016 - Medical Device Quality Management Systems 1
M Attempting to Poke Yoke a wire crimping process...need help Design and Development of Products and Processes 3
C I need your help to find the action plan for these quality objectives Misc. Quality Assurance and Business Systems Related Topics 23
ChrisM Class 1 non-sterile device, need certified QMS or not? EU Medical Device Regulations 2
Steve Prevette I need a template to solve world hunger, a world class Quality Program, and make lots of money Coffee Break and Water Cooler Discussions 5
C Need to understand difference between an actual Calibration vs. a Calibration check General Measurement Device and Calibration Topics 3
S How many tester quantity we need on the line based on the cycle time and peak volume Manufacturing and Related Processes 3
R Need help on calibration result analysis Measurement Uncertainty (MU) 17
M Do i need to have equipment validation if 100% testing is completed? Qualification and Validation (including 21 CFR Part 11) 6
G Need Help with Run @ Rate for Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 0
F Need help in IMS management review Management Review Meetings and related Processes 3
S I need help in corrective action plan Nonconformance and Corrective Action 15
A Do clinical performance studies for IVDs need to be conducted in a member state? EU Medical Device Regulations 2
A Do clinical performance studies for IVDs need to be conducted in a member state? CE Marking (Conformité Européene) / CB Scheme 0
D Weird spec sheet - need help Measurement Uncertainty (MU) 3
E Do I need test reports for all standards mentioned in my 510k application? Other Medical Device Related Standards 8
J Japan registration need manual without temperature reading Japan Medical Device Regulations 0
Ashland78 Need IATF 16949 ISO Gap Analysis Excel File Internal Auditing 3
R Need for an Importer outside EU? EU Medical Device Regulations 0
T Do I need to add non-product related service providers to my ASL? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
K Need Help With Auditing Suppliers Against ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 50
A Need career advice on QMS & HSE (No hands on experience) Career and Occupation Discussions 6
B Need assistance with documents CE Marking (Conformité Européene) / CB Scheme 2
R Lead auditor scenario (Need help) is this non conforming to ISO13485 Manufacturing and Related Processes 2
Ashland78 Need to show evidence in accordance with QR-11012 and SPB-00001-09 Customer and Company Specific Requirements 5
E Does IVD need to integrate with hospital IT infrastructure? Medical Information Technology, Medical Software and Health Informatics 2
U Need Help With API Q2 Quality Manual Oil and Gas Industry Standards and Regulations 8
S In Need of GIDEP Guidance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M Do employee training records need to be controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D What evidence do I need to supply as a remote location in relation to manufacturing sites? IATF 16949 - Automotive Quality Systems Standard 14
T Non API products need to comply to API Q1? Oil and Gas Industry Standards and Regulations 3
G Need journal and reference of abnormal bar chart SPC Statistical Analysis Tools, Techniques and SPC 4
