Do we need GOOD and BAD Wire Harness "Dummy" Samples?
Izoyd
Hi All,
I could really use some help on this one.
We have simple wire harnesses created to drawing prints to check Warranty parts. Our Warranty returns are handled through a Corporate location, not Mfg. location, and the idea is to be able analyze the parts to send only problem parts back to the Mfg. location.
We are currently in-process to create Dummy Samples, or however everyone else refers to them, to verify the wire harnesses.
What I am wondering, is do we need Good Samples AND Bad Samples to verify the wire harnesses?
We have Final/End-of-line Inspection machines that are calibrated at the start of every shift with Go (good) / No-Go (bad) Dummy Samples that are
calibrated to the drawing/intent of the "bad" sample on a 6-month basis. The final inspection machines verify that product is actually good.
So, if a "Good" Dummy Sample is created from a production part that has passed the final inspection machine using these good and bad samples to verify the part, do we really also need to create a "Bad" Dummy Sample to check too?
Shouldn't the Good Dummy Sample consequently also be determining that the wire harness is capable of detecting a bad sample since the final inspection machine is checked for that, i.e., transferring the judgment?
I hope this isn't too complicated. I would appreciate any help that you can give!
Thank you!
tomvehoski
Is this a functional check - like a continuity and/or hipot test? Or is it a visual inspection for things like crimp location, grommet seating, label location, etc? Or both?
In any case it is a good idea to have both good and bad samples. If it is functional, just miswire one to make sure that your tester is still detecting defects. It would be good to check with the equipment manufacturer for their advice.
I would also avoid the term "dummy sample". It just makes me think I don't need to take it seriously. "Boundary Sample', "Master Sample", etc. would be better IMO.
Chennaiite
Never-say-die
Hi All,
I am little confused. Are you using Wiring Harness to check your Warranty returns? If so, what is the part you are actually supplying. Just for clarification.
Thank you!
For Electrical testing, I dont think Bad Sample is needed; it is enough that you confirm the testing equipment with only Good Sample. There are n number of discontinuities and cross-connections possible in a Wiring Harness depending upon the complexity. If you want to maintain a Bad Samples, how many different type of defect samples you would go for ? It is enough to confirm the continuity and connection only with the help of a good sample which are validated periodically.
T Zinc Phosphate Test Panels look bad - Need Help Manufacturing and Related Processes 2
M Do employee training records need to be controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
D What evidence to I need to supply as a remote location in relation to manufacturing sites? IATF 16949 - Automotive Quality Systems Standard 10
T Non API products need to comply to API Q1? Oil and Gas Industry Standards and Regulations 3
G Need journal and reference of abnormal bar chart SPC Statistical Analysis Tools, Techniques and SPC 3
MSeibert47 Daily Quality Topics - Need Ideas Please! Food Safety - ISO 22000, HACCP (21 CFR 120) 15
W Do Reference materials for IATF need to be 17025? IATF 16949 - Automotive Quality Systems Standard 15
D Need some Help on 8D fault tree analysis Problem Solving, Root Cause Fault and Failure Analysis 6
A Need to calculate tolerance Intervals with a set of non-normal data and 3-Parameter Weibull distribution Using Minitab Software 0
Melissa Risk Management Process, How far do I need to go? ISO 14971 - Medical Device Risk Management 10
F Need Quality Manager advice. Quality Manager and Management Related Issues 6
T Do we need an SOP for ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B Do CTQs need to be equipment specific? FMEA and Control Plans 8
K Contract Manufacturer Do they need a complaint procedure? Medical Device and FDA Regulations and Standards News 8
K Screen printing ink and machine selection_ Need help Manufacturing and Related Processes 6
D Do employee training records need to be centralized? IATF 16949 - Automotive Quality Systems Standard 10
H Need of EU Representative Designation for Turkey? EU Medical Device Regulations 3
H If we use agile - do we still need to document TF as a waterfall just for the notified bodies need? IEC 62304 - Medical Device Software Life Cycle Processes 2
briteme4 AS9102 First Article Inspection - do I need a second reviewer and signer? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J Furnace repaired - Do I need a new initial TUS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B Does FDA Registration QSR need to cover non-medical devices for contract repackager? US Food and Drug Administration (FDA) 1
S Need ISO 15189:2012 Documentation toolkit. Document Control Systems, Procedures, Forms and Templates 0
J Need a contract monitoring Tool General Information Resources 0
P UDI-PI requirements on reusable surgical device, do we need serialisation? ISO 13485:2016 - Medical Device Quality Management Systems 3
W 17025 and NIST handbook relationship (need advice) ISO 17025 related Discussions 8
K Need procedure for D&D inputs? ISO 13485:2016 - Medical Device Quality Management Systems 4
S Need help on "Country of Origin" Medical Device and FDA Regulations and Standards News 0
Ed Panek Immediate need for 80601-2-56 Consulting expert. PM me for details Career and Occupation Discussions 0
Tagin You're Gonna Need a Bigger Root Cause Coffee Break and Water Cooler Discussions 12
M PSA Suppliers - CSR matrix and need the quality manual of PSA APQP and PPAP 6
K Interesting Discussion "World Class Product" based QM. I need advice. Quality Management System (QMS) Manuals 14
I Do I need to sign off my annual audit calendar? Internal Auditing 2
P Do we need to retrospectively use the "MD" symbol (indicating device is a medical device) on labels, e.g. finished devices within expiration date? EU Medical Device Regulations 2
M Do I need separation in my circuit with a medical charger? IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
V Certified Auditor - Need of additional certification specific to industry ( GMPs) ASQ vs ECA vs others Professional Certifications and Degrees 1
D Low risk IVD study in the UK, do I need MHRA approval? UK Medical Device Regulations 1
J Do Software Subcontractors need to be ISO13485 compliant in the EU? EU Medical Device Regulations 3
K Do I need a "State of the art" plan? CE Marking (Conformité Européene) / CB Scheme 1
S Need advice for schooling Quality Manager and Management Related Issues 5
R What information do i need to get from the device manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
S Need guidance on project ISO 13485:2016 - Medical Device Quality Management Systems 2
J Need Change Control Yes/No Decision Tree Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Does an accessory need an IFU if it use is discussed in the Parent device IFU? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
