Do we need to calibrate gauges on process equipment?
mjoakin
We have a machine we use to glue foam to leather (seat covers for GM), the foam has a special glue that melts to certain temperature. So we bought this machine (one of those used in a dry cleaning), so ... we installed a timer, a thermometer and a pressure gauge, but ... do we need to calibrate those gauges? the timer release the plate at 40 secs, the thermometer always keeps the plate at 140C and the preassure gauge is set to 80 lbs. We are a very small company and the lamination is not a safety issue, is there any way we can say we don't need to calibrate those gauges?
Jeff Frost
7.6 of TS 16949 does give guidance related to when measuring devices (timers, temp gauges and pressure gauges) must be calibrated. The items you list must be calibrated if they are used to meet a specified requirement or will be used to set the requirement. Also check your imposed customer requirements regarding calibration.
For general principle I would recommend that you calibrate this equipment to establish it accuracy and then using this calibrated equipment to monitor the process to assure uniformity of its output. You may find that room temperature or changes in air pressure has an effect on the quality of the product produced.
I worked for an organization that did ultrasonic welding of polyurethane and we discovered that changes in temperature of the room were the equipment was in operation did effected the quality of the weld and by charting the process we developed methods compensate for environmental effect on the welding equipment.
Hershal
Metrologist-Auditor
The real question is.....how do you know if something goes wrong?
If it is far enough out, it will likely be obvious.....but just enough out, maybe not.....
Phil Stein gave the best advice.....If the measurement matters, calibrate.....if the measurement does not matter, why is it being measured?
Hershal
Marc
Part of the point here is it is process equipment rather than for an inspection or test. Just because it is not used for measurement and test does not mean it isn't important. The more critical the process parameter(s), the more important calibration of the associated gage is.
But - I've seen lots of process equipment which had process parameters which weren't 'critical' and one or moe gages were essentially references.
So - Evaluate how critical the process parameter is and go from there.
Essentially I agree with Hershal and the others, but I do advise making an evaluation rather than blindly calibrating every gage on every machine in the house.
Marc is right on target here. The best method would be to perform a DOE on these parameters. If one has a significant impact on the output, calibrate it. If it does not, tag if as Reference Only, and the DOE is your proof that you made a good decision.
Performing a DOE will be much less expensive than calibrating a gauge that does not require it.
jrcook5
Is your question, do you need to calibrate the devices because you are trying to conform to a paticular standard or regluation or do the gauges provide some useful information? I think the answer depends on the question.
mjoakin
All we know is that we need to "set" our machine to those parameters to get the right lamination (glue the foam to the leather), if something goes wrong, simply the foam does not glue to the leather, will be an obvious defect. Now, the timer (just like any other regular timer) you set it to 40 secs and stops to 40 secs, the thermometer always keep the same temperature and the preassure gauge gives the sames lbs, if all this gauges make the machine "works" properly, my question is ... do I have to calibrate them? I mean, it is like when you re-heat food in your microwave, you need your food warm (or too hot), you only set the timer and the temperature, the microwave will do the rest. In our case, I just turn on the machine, it will reach the temperature needed and I can start laminating the leather. As I said before, it is not a safety issue, now, three time at day we do a destructive test to verify that the all the glue is being melted correctly, is that enough to control my process? Can I say to my registar that I chose not to calibrate those gages because I don't think it is necessary?
Not necessarily. Do you have to do environmental testing (heat, humidity,etc.)? It's possible to have apparently good adhesion at the machine and failure under adverse conditions in end use.
Another factor is your control plan. Does it detail the machine settings and tell how they're verified? If not, it probably should. If your control plan says that your verification of correct temperatures, etc. is a destructive adhesion test, then you're probably not beholden to calibrate anything except the device used in the pull test.
Hershal
Metrologist-Auditor
There is an obvious solution.....if calibration of the heat and pressure measurements are not necessary, remove the instruments involved.
The timer is a control tool, not strictly a measurement item.
Just a thought.
Hershal
mjoakin
Well, the temperature and the preassure (analog) gauges show only the parameter which the machine was set, I can not remove them from the machine. If I'm making tests to verify the adhesion was succesful, and all of them are Ok, so I don't need to calibrate those gauges, is that correct? I don't use any special tool to pull them, as soon as the piece comes out the machine, the glue is really hot and the parts can be easily separated from each other (the foam can't be used again). So, with this test I can validate the process/product and I don't really need to calibrate the gauges, you know, may be I'm using the word "gauges" incorreclty (sorry for my english) they are indicators that show the current setting of the machine.
E Do you need a Certification to Calibrate Gauges? General Measurement Device and Calibration Topics 2
N Scale with Internal Calibration - Do I need to calibrate? How to document this? Calibration Frequency (Interval) 8
I Need help finding an Accredited Lab that can Calibrate Brunson 76-RH Survey Transits General Measurement Device and Calibration Topics 5
M Controlling Temperature and Time - Do I need to calibrate the thermostat? IATF 16949 - Automotive Quality Systems Standard 4
N Thermocouple Inhomogeneity - Need to calibrate a roll of 50m thermocouple type K General Measurement Device and Calibration Topics 3
K Do I need to calibrate inside tri-mics? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V Calibration of a Digital Vernier - Need to check/calibrate/validate all 3 functions? General Measurement Device and Calibration Topics 9
A Glassware calibration - Do we need to calibrate or recalibrate laboratory glassware General Measurement Device and Calibration Topics 3
A Calibration of steel rulers - Why do I need to calibrate it again? General Measurement Device and Calibration Topics 12
B Need to know how to calibrate inch and metric gage blocks correctly. General Measurement Device and Calibration Topics 2
D Calibration - What do we need to calibrate and what don't we need to calibrate? QS-9000 - American Automotive Manufacturers Standard 4
J Need a contract monitoring Tool General Information Resources 0
P UDI-PI requirements on reusable surgical device, do we need serialisation? ISO 13485:2016 - Medical Device Quality Management Systems 0
W 17025 and NIST handbook relationship (need advice) ISO 17025 related Discussions 8
K Need procedure for D&D inputs? ISO 13485:2016 - Medical Device Quality Management Systems 4
S Need help on "Country of Origin" Medical Device and FDA Regulations and Standards News 0
Ed Panek Immediate need for 80601-2-56 Consulting expert. PM me for details Career and Occupation Discussions 0
Tagin You're Gonna Need a Bigger Root Cause Coffee Break and Water Cooler Discussions 12
M PSA Suppliers - CSR matrix and need the quality manual of PSA APQP and PPAP 2
K "World Class Product" based QM. I need advice. Quality Management System (QMS) Manuals 14
I Do I need to sign off my annual audit calendar? Internal Auditing 2
P Do we need to retrospectively use the "MD" symbol (indicating device is a medical device) on labels, e.g. finished devices within expiration date? EU Medical Device Regulations 2
M Do I need separation in my circuit with a medical charger? IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
V Certified Auditor - Need of additional certification specific to industry ( GMPs) ASQ vs ECA vs others Professional Certifications and Degrees 1
D Low risk IVD study in the UK, do I need MHRA approval? UK Medical Device Regulations 1
J Do Software Subcontractors need to be ISO13485 compliant in the EU? EU Medical Device Regulations 3
K Do I need a "State of the art" plan? CE Marking (Conformité Européene) / CB Scheme 1
S Need advice for schooling Quality Manager and Management Related Issues 5
R What information do i need to get from the device manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
S Need guidance on project ISO 13485:2016 - Medical Device Quality Management Systems 2
J Need Change Control Yes/No Decision Tree Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Does an accessory need an IFU if it use is discussed in the Parent device IFU? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
B Countries with no need for FSC (Free sales certificate) Other Medical Device Regulations World-Wide 0
R The term "Benefit Risk Ratio" in EU MDR, do I need to present benefit risk analysis as a RATIO Risk Management Principles and Generic Guidelines 4
A Brexit When does the UK responsible person need to be in place? UK Medical Device Regulations 10
N IPC-A-630 - Is this free or do i really need to pay for it? Manufacturing and Related Processes 4
P Need a programmer for QVI's VMS software for optical inspection machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
silentmonkey How to decide what characteristics need to be verified during incoming inspection? ISO 13485:2016 - Medical Device Quality Management Systems 5
T Do I need a qualified compiler for class B software? IEC 62304 - Medical Device Software Life Cycle Processes 3
E 13485:2016, Sections 4.1.6, 7.5.6 and 7.6 - Validation of Software - Need some Advice please ISO 13485:2016 - Medical Device Quality Management Systems 3
