Do we need to keep MSDS documents for all "chemicals" used in the factory?
Q
qalsang
HI
Do we need to keep MSDS for all "chemicals" used in the factory?
How about detergent that we used to clean the floor? IS it classified as
chemicals?
Is it sufficient just to keep MSDS for those chemicals that are considered
"toxic " or "poisonous"??
Randy
Re: MSDS For all chemicals
What are your legal OHS requirements in Singapore for having MSDS's? You're answer is there.
Marc
Can anyone in Singapore help with this one? My Thanks in advance!
samsung
HI
chemicals?
I agree with Randy. Through a quick Google search I found the 'Health & Safety legislation' of Singapore. If you look at Section 43 (page # 32), the chapter titled as 'Safety Datasheet' prescribes:
Safety data sheet 43. —(1) Where any hazardous substance is used, handled or stored in a factory, it shall be the duty of the occupier of the factory to —
(a) obtain a safety data sheet of the substance;
(b) assess the information in the safety data sheet and take precautionary measures to ensure the safe use of the substance; and
(c) make available the safety data sheet to all persons at work in the factory who are liable to be exposed to the substance.
Now it's not about the 'toxic' or 'poisonous' only, you need to understand what constitutes a hazardous substance. The definition is given at page#2:
"hazardous substance" means any hazardous substance specified in Part II of the Fifth Schedule to the Act;
Now you need to look for Part II, 5th schedule to determine what substances are covered under hazardous category and accordingly maintain MSDS for all those substances.
Hope this helps.
Wes Bucey
As a guy who had the responsibility for maintaining such records in several locations, I think it will save some grief for others in that position to understand that almost ALL such regulations, regardless of country, have a clause buried in the text which sets a threshold limit for the quantity of the substance in use or on hand before reporting and record-keeping take effect.
Thus, you probably don't have to report the vinegar in the break room cupboard, but you probably have to report and record the six cases of vinegar used by maintenance people each month to de-calcify bathroom fixtures in areas where hard water is a major problem.
In effect, almost any product can be toxic or dangerous in sufficient quantity or concentration. Thus, the acetic acid in common vinegar is not in the same category as glacial acetic acid (used in producing PET [Polyethylene terephthalate] and products as diverse as aspirin and heroin.)
Potential Acute Health Effects of glacial acetic acid:
Very hazardous in case of skin contact (irritant), of eye contact (irritant), of ingestion, of inhalation. Hazardous in case of skin
contact (corrosive, permeator), of eye contact (corrosive). Liquid or spray mist may produce tissue damage particularly on
mucous membranes of eyes, mouth and respiratory tract. Skin contact may produce burns. Inhalation of the spray mist may
produce severe irritation of respiratory tract, characterized by coughing, choking, or shortness of breath. Inflammation of the
eye is characterized by redness, watering, and itching. Skin inflammation is characterized by itching, scaling, reddening, or,
occasionally, blistering.
Potential Chronic Health Effects:
Hazardous in case of skin contact (irritant), of ingestion, of inhalation. CARCINOGENIC EFFECTS: Not available.
MUTAGENIC EFFECTS: Mutagenic for mammalian somatic cells. Mutagenic for bacteria and/or yeast. TERATOGENIC
EFFECTS: Not available. DEVELOPMENTAL TOXICITY: Not available. The substance may be toxic to kidneys, mucous
membranes, skin, teeth. Repeated or prolonged exposure to the substance can produce target organs damage. Repeatedor prolonged contact with spray mist may produce chronic eye irritation and severe skin irritation. Repeated or prolonged
exposure to spray mist may produce respiratory tract irritation leading to frequent attacks of bronchial infection.
Flammability of the Product: Flammable.
Auto-Ignition Temperature: 463°C (865.4°F)
Flash Points: CLOSED CUP: 39°C (102.2°F). OPEN CUP: 43°C (109.4°F).
Flammable Limits: LOWER: 4% UPPER: 19.9%
Products of Combustion: These products are carbon oxides (CO, CO2).
Fire Hazards in Presence of Various Substances:
Flammable in presence of open flames and sparks, of heat. Slightly flammable to flammable in presence of oxidizing
materials, of metals.
Explosion Hazards in Presence of Various Substances:
Risks of explosion of the product in presence of mechanical impact: Not available. Risks of explosion of the product in
presence of static discharge: Not available. Slightly explosive in presence of oxidizing materials.
Fire Fighting Media and Instructions:
Flammable liquid, soluble or dispersed in water. SMALL FIRE: Use DRY chemical powder. LARGE FIRE: Use alcohol foam,
water spray or fog. Cool containing vessels with water jet in order to prevent pressure build-up, autoignition or explosion.
Special Remarks on Fire Hazards:
Reacts with metals to produces flammable hydrogen gas. It will ignite on contact with potassium-tert-butoxide. A mixture of
ammonium nitrate and acetic acid ignites when warmed, especially if warmed.
C Need opinion to keep alive candidacy - Position hiring placed on Hold Career and Occupation Discussions 12
C APQP Meeting Agenda - Need Example and How to keep the meetings focused & on track APQP and PPAP 7
P Production Traceability - Need to Keep Grip On Manufacturing and Related Processes 4
B Does FDA Registration QSR need to cover non-medical devices for contract repackager? US Food and Drug Administration (FDA) 0
S Need ISO 15189:2012 Documentation toolkit. Document Control Systems, Procedures, Forms and Templates 0
J Need a contract monitoring Tool General Information Resources 0
P UDI-PI requirements on reusable surgical device, do we need serialisation? ISO 13485:2016 - Medical Device Quality Management Systems 0
W 17025 and NIST handbook relationship (need advice) ISO 17025 related Discussions 8
K Need procedure for D&D inputs? ISO 13485:2016 - Medical Device Quality Management Systems 4
S Need help on "Country of Origin" Medical Device and FDA Regulations and Standards News 0
Ed Panek Immediate need for 80601-2-56 Consulting expert. PM me for details Career and Occupation Discussions 0
Tagin You're Gonna Need a Bigger Root Cause Coffee Break and Water Cooler Discussions 12
M PSA Suppliers - CSR matrix and need the quality manual of PSA APQP and PPAP 2
K "World Class Product" based QM. I need advice. Quality Management System (QMS) Manuals 14
I Do I need to sign off my annual audit calendar? Internal Auditing 2
P Do we need to retrospectively use the "MD" symbol (indicating device is a medical device) on labels, e.g. finished devices within expiration date? EU Medical Device Regulations 2
M Do I need separation in my circuit with a medical charger? IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
V Certified Auditor - Need of additional certification specific to industry ( GMPs) ASQ vs ECA vs others Professional Certifications and Degrees 1
D Low risk IVD study in the UK, do I need MHRA approval? UK Medical Device Regulations 1
J Do Software Subcontractors need to be ISO13485 compliant in the EU? EU Medical Device Regulations 3
K Do I need a "State of the art" plan? CE Marking (Conformité Européene) / CB Scheme 1
S Need advice for schooling Quality Manager and Management Related Issues 5
R What information do i need to get from the device manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
S Need guidance on project ISO 13485:2016 - Medical Device Quality Management Systems 2
J Need Change Control Yes/No Decision Tree Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Does an accessory need an IFU if it use is discussed in the Parent device IFU? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
B Countries with no need for FSC (Free sales certificate) Other Medical Device Regulations World-Wide 0
R The term "Benefit Risk Ratio" in EU MDR, do I need to present benefit risk analysis as a RATIO Risk Management Principles and Generic Guidelines 4
A Brexit When does the UK responsible person need to be in place? UK Medical Device Regulations 10
N IPC-A-630 - Is this free or do i really need to pay for it? Manufacturing and Related Processes 4
P Need a programmer for QVI's VMS software for optical inspection machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
silentmonkey How to decide what characteristics need to be verified during incoming inspection? ISO 13485:2016 - Medical Device Quality Management Systems 5
T Do I need a qualified compiler for class B software? IEC 62304 - Medical Device Software Life Cycle Processes 3
E 13485:2016, Sections 4.1.6, 7.5.6 and 7.6 - Validation of Software - Need some Advice please ISO 13485:2016 - Medical Device Quality Management Systems 3
C ISO 13485 :2016 - CAPA - Does every CAPA need to be checked by regulations? ISO 13485:2016 - Medical Device Quality Management Systems 9
L Proof of Concept Studies - Do we need to comply with SAE reporting? Medical Device and FDA Regulations and Standards News 3
gunnyshore Adding a new facility - do I need to submit an amendment to the MDL or MDEL, or both? Canada Medical Device Regulations 3
N FDA UDI - Label vs. Labeling - Does the insert need to include UDI? Other US Medical Device Regulations 1
SocalSurfer AS9100 new certificate, but need QMS software, help Quality Assurance and Compliance Software Tools and Solutions 2
A Demonstration of Equivalence - Need for comparing biological characteristics for an SamD EU Medical Device Regulations 1
