Do we need to reference Standards in our Procedures?
GStough
#11
Re: Do we need to reference Standards into our procedures?
If you are making it a requirement of your system to follow some standard (whatever that standard may be...ISO, ASTM, SAE, whatever) then you should reference it in the Quality system somewhere, and you should have a current copy available...
We do reference standards in our quality manual and if it is necessary to reference these standards in any of our procedures, we word it something like this: "...as per standards as listed in the quality manual..." or something to that effect...
So, by identifying the standards once in the quality manual, this eliminates repetitive referencing of standards in various procedures, which would be a nightmare :mg: to update every time a revision was made to any of the standards.
#12
You don't have to update individual procedures every time a standard changes if you don't reference the revision level of the standard in the procedure. That's the prime reason not to reference change levels. If you want to put something in the QM, just say that standards used must be the current ones.
sardonyx
#13
Thanks all for you inputs.
Right now, I'm trying to update the standards that our consultant used as reference in their procedure, product specs & requirements. Actually most of the documents we have that have reference standards are software docs (not manufacturing/testprocedures and not quality procedures) such as SRS (software requirements specs) SCMP (software control management plan), SDP (software development plan), software design description, software development procedure, etc.
Thanks again for enlightening me on how to start controlling these documents and standards. And maybe for new releases I'll make sure that they don't reference the standards in their documents if it's applicable.:thanx:or better to reference it from the QA manual (this is a good idea!).
cywork
#14
Hello, didn't mean to bring up an old post but this one is closest to what I am going to ask so here it goes:
Regarding referencing standards, if a standard has been cancelled but still used in the same drawing that has not been changed since before the cancellation is it ok to reference our procedures to this standard?
Per cancelled standards, replacement standards shall be used for future requirements so does that mean an outdated standard that is still being referenced by our customers is still considered ok? And do I need to reference the new standards at all?
We do adopt certain national standard procedures into our process in order to be compliant with customer requirements.
Thanks!
#15
Thanks!
When two or more parties agree to use a given set of requirements, it's a standard whether or not it's been canceled by its publisher. Many companies still use MIL-STD-105x for acceptance sampling even though it was canceled many years ago.
In a similar vein, sometimes a mistake is made in calling out a specific version or edition of a standard on a drawing, which technically means that only the specified revision is valid even after it has been superseded. If there are substantive changes in a new revision in such a case, it's best to check with the customer for guidance. Unless there's a reason to specify a specific revision, it's best to state that it's expected that the latest version should be used.
Richard Pike
#16
Two part Answer: (1) If in your Policy (or other documentation)you state that you will comply to certain standards then most certainly you would be expected to have the latest revisions of those standards. (2) Whilst never advocating that we do something "simply because the standard says so" it is sometimes useful to know against what basis your procedures or instructions were written. If you are asking do you "always" have to cross refer then i agree with the moderator of this forum. Emphatically NO!
John Martinez
#17
Thanks!
There are many time, military especially, when they want a specific standard AND revision for a specific part. So, even though the standard has been canceled or revised, you can still work to the old standard if agreed.
Many times dealing with government buyers, it's easier to just provide the part to the older standard (if possible) than going through the head banging process of trying to educate them. :frust::frust::frust::frust:
B Need to convert Reference Only M&TE to a calibration schedule General Measurement Device and Calibration Topics 3
L Calibration of Dial Thickness Gauge - What reference standard need I follow? General Measurement Device and Calibration Topics 5
I Is there a need to reference Documented Procedures - 4.2.2 b) ISO 13485:2016 - Medical Device Quality Management Systems 4
Bev D Need Reference for Alarming "Across Phases" Statistical Analysis Tools, Techniques and SPC 7
C Need reference in order to audit batch record Quality Tools, Improvement and Analysis 3
R ISO 17025 Procedures - Need to reference them to published procedures else where ISO 17025 related Discussions 7
G Titles for Visual Control Systems (graphs) - I need some reference data Manufacturing and Related Processes 2
W Controlled vs. For Reference Only - Forms which don't need control? Document Control Systems, Procedures, Forms and Templates 6
L I need a reference for selecting a notified body. Can anyone make a recommendation? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 21
I Need to reference forms and ensuing records? Records and Data - Quality, Legal and Other Evidence 6
J Need a contract monitoring Tool General Information Resources 0
P UDI-PI requirements on reusable surgical device, do we need serialisation? ISO 13485:2016 - Medical Device Quality Management Systems 0
W 17025 and NIST handbook relationship (need advice) ISO 17025 related Discussions 8
K Need procedure for D&D inputs? ISO 13485:2016 - Medical Device Quality Management Systems 4
S Need help on "Country of Origin" Medical Device and FDA Regulations and Standards News 0
Ed Panek Immediate need for 80601-2-56 Consulting expert. PM me for details Career and Occupation Discussions 0
Tagin You're Gonna Need a Bigger Root Cause Coffee Break and Water Cooler Discussions 12
M PSA Suppliers - CSR matrix and need the quality manual of PSA APQP and PPAP 2
K "World Class Product" based QM. I need advice. Quality Management System (QMS) Manuals 14
I Do I need to sign off my annual audit calendar? Internal Auditing 2
P Do we need to retrospectively use the "MD" symbol (indicating device is a medical device) on labels, e.g. finished devices within expiration date? EU Medical Device Regulations 2
M Do I need separation in my circuit with a medical charger? IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
V Certified Auditor - Need of additional certification specific to industry ( GMPs) ASQ vs ECA vs others Professional Certifications and Degrees 1
D Low risk IVD study in the UK, do I need MHRA approval? UK Medical Device Regulations 1
J Do Software Subcontractors need to be ISO13485 compliant in the EU? EU Medical Device Regulations 3
K Do I need a "State of the art" plan? CE Marking (Conformité Européene) / CB Scheme 1
S Need advice for schooling Quality Manager and Management Related Issues 5
R What information do i need to get from the device manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
S Need guidance on project ISO 13485:2016 - Medical Device Quality Management Systems 2
J Need Change Control Yes/No Decision Tree Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Does an accessory need an IFU if it use is discussed in the Parent device IFU? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
B Countries with no need for FSC (Free sales certificate) Other Medical Device Regulations World-Wide 0
R The term "Benefit Risk Ratio" in EU MDR, do I need to present benefit risk analysis as a RATIO Risk Management Principles and Generic Guidelines 4
A Brexit When does the UK responsible person need to be in place? UK Medical Device Regulations 10
N IPC-A-630 - Is this free or do i really need to pay for it? Manufacturing and Related Processes 4
P Need a programmer for QVI's VMS software for optical inspection machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
silentmonkey How to decide what characteristics need to be verified during incoming inspection? ISO 13485:2016 - Medical Device Quality Management Systems 5
T Do I need a qualified compiler for class B software? IEC 62304 - Medical Device Software Life Cycle Processes 3
E 13485:2016, Sections 4.1.6, 7.5.6 and 7.6 - Validation of Software - Need some Advice please ISO 13485:2016 - Medical Device Quality Management Systems 3
C ISO 13485 :2016 - CAPA - Does every CAPA need to be checked by regulations? ISO 13485:2016 - Medical Device Quality Management Systems 9
