Do we need to submit Special 510K for a Blood Glucose System?
P
paullarn
We have a 510K for blood glucose system. We are modifying Glucose meter by relocating meter's buttons and changing enclosure.
Do we need to submit a special 510K?
Regards,
Paul Larn
Ajit Basrur
Re: Do we need to submit for Special 510K?
Hello Paul,
Yes .... but have a look here and see if you meet all requirements - http://www.fda.gov/MedicalDevices/D...sions/PremarketNotification510k/ucm134573.htm
Product modifications that could significantly affect safety and effectiveness are subject to 510(k) submission requirements under 21 CFR 807 as well as design control requirements under the Quality System (QS) regulation. Under the QS regulation, all Class II and III devices and certain Class I devices are required to be designed in conformance to 21 CFR 820.30 Design Controls.
The "Special 510(k): Device Modification" utilizes the design control requirement of the Quality System Regulation (21 CFR 820) and may be submitted for a modification to a device that has been cleared under the 510(k) process. The Special 510(k) allows the manufacturer to declare conformance to design controls without providing the data. While the basic content requirements of the 510(k) (21 CFR 807.87) remain the same, this type of submission should also reference the cleared 510(k) number and contain a "Declaration of Conformity" with design control requirements. Manufacturers of Class I devices requiring 510(k) may elect to comply with the design control provision of the QS regulation and submit Special 510(k)s.
Ronen E
Problem Solver
Moderator
Regards,
Paul Larn
Could be, but not necessarily. Check yourself against FDA's guidance:
http://www.fda.gov/MedicalDevices/DeviceRegulationandGuidance/GuidanceDocuments/ucm080235.htm
For a brief moment we had an updated guidance, but thanks to politics it was withdrawn until further notice.
Given that you intend to modify the meter's exterior, I strongly recommend that you take a good look at this letter (if you don't already know it by heart):
http://www.fda.gov/MedicalDevices/ProductsandMedicalProcedures/InVitroDiagnostics/ucm227935.htm
All the best,
Ronen.
P
paullarn
Hi Ronen,
Thanks for prompt reply. Can you believe it we had no issues preparing documents for 510K but unable to figure out what they mean by following:
A Design Control Activities Summary which includes:
a) Identification of Risk Analysis method(s) used to assess the impact of the modification on
the device and its components, and the results of the analysis
b) Based on the Risk Analysis, an identification of the verification and/or validation activities
required, including methods or tests used and acceptance criteria to be applied
c) A declaration of conformity with design controls. The declaration of conformity should
include:
i) A statement signed by the individual responsible, that, as required by the risk
analysis, all verification and validation activities were performed by the designated
individual(s) and the results demonstrated that the predetermined acceptance criteria
were met, and
ii) A statement signed by the individual responsible, that the manufacturing facility is in
conformance with design control procedure requirements as specified in 21 CFR
820.30 and the records are available for review.
IS FDA looking for "I agree" statements here or are they looking for detailed analysis.
Any example template or example documents will be really appreciated.
Ronen E
Problem Solver
Moderator
a) Identification of Risk Analysis method(s) used to assess the impact of the modification on the device and its components, and the results of the analysis
E.g. ISO 14971:2007. Submit the risk analysis results, i.e. the list of identified risks, their estimates and evaluations.
b) Based on the Risk Analysis, an identification of the verification and/or validation activities required, including methods or tests used and acceptance criteria to be applied
Submit your detailed verification and/or validation plan(s), aimed at any mitigated risks.
c) A declaration of conformity with design controls. The declaration of conformity should include:
i) A statement signed by the individual responsible, that, as required by the risk analysis, all verification and validation activities were performed by the designated individual(s) and the results demonstrated that the predetermined acceptance criteria were met, and
ii) A statement signed by the individual responsible, that the manufacturing facility is in conformance with design control procedure requirements as specified in 21 CFR 820.30 and the records are available for review.
"I agree" statements (in your terms) would do for this item.
gunnyshore Adding a new facility - do I need to submit an amendment to the MDL or MDEL, or both? Canada Medical Device Regulations 3
L 510k exemption process - Do you still need to submit technical dossier? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
P Part Submission Form - Need to submit PSW only once? APQP and PPAP 5
M If I update a DFMEA do I need to submit to my Customer? FMEA and Control Plans 7
P Does our company need to be certified in order to submit a 510k Other US Medical Device Regulations 4
E Do I need submit a traditional 510(k) or Abbreviated 510(k) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
C Only appearance and PCB are changed - Do we need to submit a new 510(k)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S Do we need to submit our memory foam oxygen mask gasket for FDA approval? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
B Need to submit level 3 PPAP - New or Multiple Presses - Injection Molding QS-9000 - American Automotive Manufacturers Standard 4
B PPAP and the need to re-submit - Engineering change to a single component part QS-9000 - American Automotive Manufacturers Standard 1
S Need ISO 15189:2012 Documentation toolkit. Document Control Systems, Procedures, Forms and Templates 0
J Need a contract monitoring Tool General Information Resources 0
P UDI-PI requirements on reusable surgical device, do we need serialisation? ISO 13485:2016 - Medical Device Quality Management Systems 0
W 17025 and NIST handbook relationship (need advice) ISO 17025 related Discussions 8
K Need procedure for D&D inputs? ISO 13485:2016 - Medical Device Quality Management Systems 4
S Need help on "Country of Origin" Medical Device and FDA Regulations and Standards News 0
Ed Panek Immediate need for 80601-2-56 Consulting expert. PM me for details Career and Occupation Discussions 0
Tagin You're Gonna Need a Bigger Root Cause Coffee Break and Water Cooler Discussions 12
M PSA Suppliers - CSR matrix and need the quality manual of PSA APQP and PPAP 2
K "World Class Product" based QM. I need advice. Quality Management System (QMS) Manuals 14
I Do I need to sign off my annual audit calendar? Internal Auditing 2
P Do we need to retrospectively use the "MD" symbol (indicating device is a medical device) on labels, e.g. finished devices within expiration date? EU Medical Device Regulations 2
M Do I need separation in my circuit with a medical charger? IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
V Certified Auditor - Need of additional certification specific to industry ( GMPs) ASQ vs ECA vs others Professional Certifications and Degrees 1
D Low risk IVD study in the UK, do I need MHRA approval? UK Medical Device Regulations 1
J Do Software Subcontractors need to be ISO13485 compliant in the EU? EU Medical Device Regulations 3
K Do I need a "State of the art" plan? CE Marking (Conformité Européene) / CB Scheme 1
S Need advice for schooling Quality Manager and Management Related Issues 5
R What information do i need to get from the device manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
S Need guidance on project ISO 13485:2016 - Medical Device Quality Management Systems 2
J Need Change Control Yes/No Decision Tree Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Does an accessory need an IFU if it use is discussed in the Parent device IFU? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
B Countries with no need for FSC (Free sales certificate) Other Medical Device Regulations World-Wide 0
R The term "Benefit Risk Ratio" in EU MDR, do I need to present benefit risk analysis as a RATIO Risk Management Principles and Generic Guidelines 4
A Brexit When does the UK responsible person need to be in place? UK Medical Device Regulations 10
N IPC-A-630 - Is this free or do i really need to pay for it? Manufacturing and Related Processes 4
P Need a programmer for QVI's VMS software for optical inspection machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
silentmonkey How to decide what characteristics need to be verified during incoming inspection? ISO 13485:2016 - Medical Device Quality Management Systems 5
T Do I need a qualified compiler for class B software? IEC 62304 - Medical Device Software Life Cycle Processes 3
E 13485:2016, Sections 4.1.6, 7.5.6 and 7.6 - Validation of Software - Need some Advice please ISO 13485:2016 - Medical Device Quality Management Systems 3
