Do Work Instructions need to be approved by someone other than the author?
sunflower613
Hi All,
This is my first post, though I've been lurking in the shadows for a few months now and have found this forum immensely helpful. So thank you!
We have an enormous amount (probably hundreds) of work instructions and manuals. They are all stored in a Document Management System, so Document Control from that point of view is all good. My issue is with the approval of the documents for issue. Typically this hasn't been done in the past, and I'm trying to work out the most efficient way to get this happening.
Someone has suggested that work instructions can just be approved for use by the document author, not by a manager. The reason being that the higher level process should have inspections built in, and if a work instruction was wrong it would be picked up in the inspection process. We therefore only need document approval by a manager at the higher process level.
Thoughts? Would this make it past an Auditor for ISO 9001?
Pancho
wikineer
Hi Sunflower, and welcome!
ISO 9001 does not require a particular approval procedure. It does require your organization "to define the controls needed (a) to approve documents for adequacy prior to issue", and "(b) to review and update as necessary and re-approve documents".
Thus, it is your organization, not the standard, that defines who approves. It may be the same person as the author, or it could be a different person. It could be an operator, the process owner or the big kahuna. But whoever your company gives authority to a approve documents, that person should be able and capable to ascertain that the document is adequate for issue.
The documented procedure required by §4.2.3 must define these controls. Your auditor will verify that it does, and that your team follows what your procedure says.
Cheers!
Pancho
somashekar
Hi All,
The one who approves must be the one who knows about it based on his past work experience and knowledge, and has the authority to approve such level of document. You identify within your organization what positions can approve them.
The word author, I take it as one who writes or drafts a document. (S)he could be the one who could approve as mentioned above OR authoring on behalf of an other person who has the authority. If you can see this clearly, approval of document becomes clear as well ~~~
Good luck and welcome to the Cove ...
sagai
Actually in this context, you "only" have to have a procedure documented for the document management and for the record management, so you should comply with your own internal QM SOP in ISO9001 world.
br
Sz.
G
gregqc
One suggestion: Watchout for a single signoff. Ours requires that the areas affected by the work instruction, procedure, etc, has a say in the approval. I speak from experience where one department had approval and gave task to other departments that did not know and were not consulted on the procedure. I got caught in the middle.
Everyone who has a part in carrying out the work show have approval authority.:bonk:
H
Hodgepodge
Good point. Your example highlights the reason the process approach is a requisite for quality management systems.
samsung
:yes::agree1:Good point. All the users of the document or those affected by it should be the prime candidates in the approval process since the document is a compilation of their needs and if they are not involved in approval process, it's likely that they will not use it.
Tom W
Not to hijack this thread but what about an actual signature or signatures on the document. Is it neccessary to have actual signatures on the work instruction or is it enough to say if released in the system they are approved...and then maintain an approval page somewhere else (not in the actual document)?
I am having old school thoughts that a signature is required just because it looks right....but is it really neccessary?
treesei
I don't think it's necessary. We document the approval, but whether it is in the form of a signature depends. I would imagine small companies with relatively simple document system/usage may go the old world way, but keeping a separate approval record will not hurt. Furthermore, in the automated document control system, the approval could be simply a click on an "Approve" buttom. The system records the person and the time the bottom was clicked; however there is never a "signature".
J Documentation structure - Do I need Work Instructions? Document Control Systems, Procedures, Forms and Templates 23
B New to PPAP - Need help with Work Instructions APQP and PPAP 1
M Work instructions inaccurate - Need to update and improve documentation system ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
H When do you need ISO 9001 Controlled Work Instructions? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
R Work Instructions - Processes - Does all machinery need to have work instructions? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Randy The Need to Update / Revise Work Instructions and Procedures Miscellaneous Environmental Standards and EMS Related Discussions 5
J Work Instructions - How detailed do work instructions need to be? QS-9000 - American Automotive Manufacturers Standard 6
J Instructions for use for Class I devices under MDR EU Medical Device Regulations 1
T ISO 13485 - Assembly instructions written vs. online ISO 13485:2016 - Medical Device Quality Management Systems 5
U Intended Users in IFU (Instructions for Use) EU Medical Device Regulations 5
was named killer AS 9100D - Calibration Instructions - Controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
K EU MDR Annex 1 Chapter III: Information in the Instructions for Use-23.4 (e) the performance characteristics of the device; EU Medical Device Regulations 1
C Work Instructions; Controlled/Uncontrolled? Document Control Systems, Procedures, Forms and Templates 5
M User manual / instructions for use for class II device always required? Medical Device and FDA Regulations and Standards News 3
L MDR - Information in the instructions for use - clausole 23.4.(z) EU Medical Device Regulations 2
S ISO 18223-2 Temperature symbol in the Legend table in the Instructions for Use Other ISO and International Standards and European Regulations 4
S Providing IFU (Instructions for Use) in multiple languages EU Medical Device Regulations 0
M Informational The USFDA Continues to Remind Facilities of the Importance of Following Duodenoscope Reprocessing Instructions: FDA Safety Communication Medical Device and FDA Regulations and Standards News 0
Z IFU (Instructions for Use) Symbol - 7010:M002 - can it be in black? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
I Document levels and approval requirements for lower level documents like work instructions, forms etc. Document Control Systems, Procedures, Forms and Templates 18
N Electronic Instructions for use (eIFU) EU Medical Device Regulations 2
Marc Elsmar Xenforo Software Instructions #2 - 9/2018 Elsmar Xenforo Forum Software Instructions and Help 0
Marc Elsmar Xenforo Software Instructions #1 - 9/2018 Elsmar Xenforo Forum Software Instructions and Help 0
M Batch record supersedes all other instructions 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
N Updating class I device IFU with instructions to use class II cleared device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
H SPC Work Instructions (WI) Statistical Analysis Tools, Techniques and SPC 2
S Are 2 Hard Copies of Procedures and Instructions Required? ISO 13485:2016 - Medical Device Quality Management Systems 6
K IATF 16949 Cl. 8.5.1.2 - Requirements of Work Instructions and Documents IATF 16949 - Automotive Quality Systems Standard 2
J Work Instructions - We have approx 1,000 work instructions from over the years Document Control Systems, Procedures, Forms and Templates 8
Ajit Basrur Incoming Inspection for Instructions for Use (IFU) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T Product Instructions (IFU) - Placement Requirements - ISO 13485:2003/2016 Other ISO and International Standards and European Regulations 2
C Manufacturing Process Work Instructions - Format Manufacturing and Related Processes 4
D 207/2012 Update for MDR (?) - Instructions for Use (IFU) EU Medical Device Regulations 9
R How to Control Videos as part of the QMS Documented Procedures and Instructions Document Control Systems, Procedures, Forms and Templates 2
D eQMS/ERP System Admin Work Instructions - Where do they fit? Misc. Quality Assurance and Business Systems Related Topics 5
R ISO 50001 - Manual and instructions Sustainability, Green Initiatives and Ecology 8
C Following Order of Work Instructions ISO 13485:2016 - Medical Device Quality Management Systems 23
M CAPA due to Consumer not following Maintenance Instructions... Nonconformance and Corrective Action 9
V Suggest Packing Instructions for Electrical Control panel Document Control Systems, Procedures, Forms and Templates 4
Q Allowed no manuals, technical instructions traceability in products ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Video Screencasts for Work Instructions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Process Changes, but Work Instructions/Process Maps are not updated ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
O Regulatory Notification for IVD IFU Instructions Revision ISO 13485:2016 - Medical Device Quality Management Systems 3
Q Help sections in Software Programs as Work Instructions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Should we have Work Instructions for HR or not Document Control Systems, Procedures, Forms and Templates 5
M Who should write Departmental Work Instructions Document Control Systems, Procedures, Forms and Templates 6
S Informational Please help this newbie understand ISO 9001 Work Instructions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 44
T Work Instructions for Assembly vs. Disassembly Misc. Quality Assurance and Business Systems Related Topics 11
S Do Work Instructions have to be in harmony with the related Control Plan? Document Control Systems, Procedures, Forms and Templates 1
