Do you have to perform an full internal prior to IATF 16949 audit?
hngrad1977
My auditor is writing me a major non-conformance because we did not perform a full internal audit to the new standard before the registration audit. I do not see in the standard where it says I have too. Has anyone else ran into this? My auditor is here now,
Al Rosen
I believe you have to at least audit the areas affected by the changed requirements.
AndyN
Moved On
They are wrong (unless it's in your CB agreement) Ask them to point to the requirement...
Golfman25
Auditing doesn't happen in a vacuum. You're auditing, revising, auditing, revising, etc. You simply should ensure you have audited any changes before the third party audit. Is this an IAFT 16949 audit?
Cari Spears
hi, hngrad -
I checked out your other posts and see that you mention you're working on IAFT 16949 - so I moved your thread to this forum to help get more responses. Let me know if I presumed incorrectly.
AndyN
Moved On
The requirements for audits have changed, but not dramatically, unless you were not meeting the TS requirements. What I mean by that is, if you had an internal audit program and were already doing internal audits, checking on the various processes, looking at document control, records (maybe even using turtles) you DO NOT have to do everything all over just the meet IATF requirements, because you ALREADY were!
All that's required - trust me - is to audit the new and changed requirements to establish the system as a whole now meets IATF. It's certainly NOT justifiable as a major maybe a minor at best. Don't argue with the audit, don't agree to the finding and tell them you will be appealing it with the CB management and requesting a change of auditor - pure and simple.
hngrad1977
The auditor is firm in saying IATF Global Oversight board requires it and it is our responsibility to go out to the site and verify these requirements. I have the rules and guidelines but have never heard of this
Stijloor
From the IATF 16949:2016 Transition Strategy Revision 5:
Are organizations required to conduct a full internal system audit
against IATF 16949 prior to the start of the transition audit?
The organization is required to demonstrate compliance to IATF 16949:2016 through a complete internal system audit against the requirements of IATF 16949:2016 prior to the transition audit conducted by an IATF-recognized certification body. This should be demonstrated through a complete full system audit against IATF 16949:2016. However at the time of the transition audit this may be accomplished through the combination of a previous system audits with the ISO/TS 16949:2009 requirements and a supplemental system audits in compliance with the additional requirements of IATF 16949:2016.
Here is a link to the entire document.
http://www.iatfglobaloversight.org/...ransition-Strategy-and-Requirements_REV05.pdf
hngrad1977
I follow the IATF 16949 standard, APQP, FMEA and all of the other blue books, but have never been told I had to go to the IATF Global Oversight.org and look for that information. If that is the case I find it hard to believe hardly anyone would know this. It may make good business sense to do it but in reality why a major?
F Defining the need to perform the Proximity magnetic fields immunity tests (IEC 61000-4-39) according to the IEC 60601-1-2 ed.4.1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
B Run at Rate - when to perform / is it mandatory? IATF 16949 - Automotive Quality Systems Standard 19
F Should I perform several Gage R&R for every caliper to cover all specs range of use? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
J ISO 10993-1:2018 Format to Perform Risk Management Process US Food and Drug Administration (FDA) 1
K Looking for a tape to perform cross hatch test on powder coating parts Reliability Analysis - Predictions, Testing and Standards 3
X Looking for 17025 auditor to perform internal audit on IT software testing laboratory ISO 17025 related Discussions 3
M Must a company be 17025 accredited to perform internal calibrations? ISO 17025 related Discussions 10
S How to perform verification of the Statistical Analysis Software? Qualification and Validation (including 21 CFR Part 11) 7
J Starting a Weibull Analysis: Source on how to perform Weibull Reliability Analysis - Predictions, Testing and Standards 2
E When to perform accelerated aging studies and transport test(OQ or PQ) Qualification and Validation (including 21 CFR Part 11) 4
F Who can sit in/perform an API audit? Oil and Gas Industry Standards and Regulations 2
V Supplier wants to perform pre-qualifications prior to every run instead of locking in parameters. Supplier Quality Assurance and other Supplier Issues 7
M MDR requires the NB to perform "tests in order to check that the quality management system" EU Medical Device Regulations 11
M Define voltage and frequency to perform tests 61010-1 and 61326-1 for CE certification CE Marking (Conformité Européene) / CB Scheme 4
M Informational How to perform a clinical evaluation of medical devices – Part 2 – Level of clinical evidence and what sufficient clinical evidence means Medical Device and FDA Regulations and Standards News 9
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
M Informational How to perform a clinical evaluation of medical devices – Part 1 – Overview and sample of activities Medical Device and FDA Regulations and Standards News 0
blackholequasar Internal Auditing Inspiration - Getting volunteers to perform internal audits. Internal Auditing 22
E Input to ANOVA 1-WAY - How can I perform this analysis in minitab? Using Minitab Software 2
B AS9102 FAI & Lower Level Drawings - How should we perform the FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M Perform a coating weight test within 3 hours of processing the parts Manufacturing and Related Processes 2
D How to ensure independence and authority necessary to perform QM tasks ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q How to perform Process Capability for true position Statistical Analysis Tools, Techniques and SPC 11
J Internal Audit clarification - How to perform the audits IATF 16949 - Automotive Quality Systems Standard 6
S When will notified bodies be ready to perform audit to the MDR? EU Medical Device Regulations 1
chris1price Is there a regulatory (MDD, MDR, FDA, ISO, etc) requirement to perform a mock recall? CE Marking (Conformité Européene) / CB Scheme 5
P Can CEO perform internal audit Internal Auditing 11
B How to perform a MSA - GRR (Gage R&R) A&R/ANOVA Vs GUM/VDA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
W DCMA and AS9100C - Dedicating a week and 5 auditors to perform a AS9100C audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
W How to perform validation for an epoxy curing station Manufacturing and Related Processes 3
C How to perform Gauge R & R on Automated Test & Measurement Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
E How do you perform a GR&R for system software generated values? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B Do I need to perform Gage R&R on a Digital Temperature & Humidity Gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
G Plant Relocation - Is it necessary to perform FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
L Who can perform ISO 9001:2008 Internal Audit prior to our Registration Audit? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
R Registrars offering to perform Second Party Audits - Have they failed their role? Registrars and Notified Bodies 112
M How to perform Chelex DNA Method Verification in the lab General Measurement Device and Calibration Topics 2
V Is it required to perform Process Validation for food or dietary supplements? Food Safety - ISO 22000, HACCP (21 CFR 120) 4
E Should companies that perform calibration services be ISO 17025 accredited? ISO 17025 related Discussions 13
R How do you perform verification of a NCR (Nonconformance)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
W Hiring an External Auditor to perform our AS9100 Compliance Audits AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
E How to perform Discrimination check for Dial Indicator? General Measurement Device and Calibration Topics 3
A Do we need to perform Qualification and Validation? ISO 13485:2016 - Medical Device Quality Management Systems 3
A Does ISO/TS 16949:2009 require us to perform Final/Pre-dispatch Inspection? IATF 16949 - Automotive Quality Systems Standard 5
N Example of how to perform a Visual Attribute Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
J How do you perform a S3 Stability Study for a Non-Replicable Measurement System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
K Do we need to perform Analytical Method Validation upon Relocation? General Measurement Device and Calibration Topics 5
K How to perform Verification for a Gage that is used in Destructive Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R Looking for service provider to perform residual dirt test, GME7061 General Measurement Device and Calibration Topics 2
