Do you implement real SPC not just a paper work?
cqt18060180
i am chinese guy as QE, but for my experience and my saw, SPC just a tool for customer audit only, so i am curiouse to know the implement from your work experience, since the SPC is hard to acchive if real implement
Al Dyer
Re: Do you implement the real SPC not just a paper work?
SPC is a tool. A good tool that reflects how the process performs and ultimately one of the best cost monitors implemented. Sure, many people submit false data but that is only a reflection of the true morals of the company.
Sample: If a company, or individual "supervisor" requires the submission of false data what could they do to your employment records, performance reviews, promotion possibilities?
In reality an organization as well as an individual have morals.
:bigwave:
Al... "on his high horse!"
andreww
Hi, SPC is very useful tool. I used it in dimensional control, and it works very well.
cqt18060180
but it means we have more times for linestop, it will hard to ship product
amanbhai
If you like to see SPC implementation you have to go to auto manufacturers. They are the people who implement this tool very widely and with true letter and sprit. While I admist that there are other industries which are implementing these tools successfully.
N
NumberCruncher
Hi cqt
SPC covers a very wide range of things. It's not just monitoring your output. You also monitor the things that affect what you make.
Suppose you have 3 machines making a part, a CNC lathe cutting a part to a particular diameter. You have a problem with the diameters. They are not all 50mm +/-0.05mm.
If you look at the output of each lathe individually, you might find the following:
Lathe 1- 50mm +/- 0.03mm
Lathe 2- 50mm +/- 0.02mm
Lathe 3- 50mm +/- 0.09mm
In this case, the problem is lathe 3. Now you know what the problem is, you can do something about it. Once you have fixed the problem, you need to stop the line less often.
NC
I've implemented SPC in many organizations and have always found it quite useful as part of a suite of tools to improve quality reduce cost and decrease cycle time.
As a Customer when I audit my suppliers (many in automotive) I always look to see if the supplier is really using SPC or if the charts are just eye candy for auditors.
Yes, in the beginning you will stop the line - but you will get better results.
If you have many processes that are out of control you may need to prioritze which ones you will focus on improving and use acceptance sampling only on the other processes. you don't need to put SPC on all processes at once...
bobdoering
Stop X-bar/R Madness!!
I always say you can process without SPC - just as you can drive a car without a gas gage. But....having a gas gage - or actually knowing what your process is doing - sure seems like it would be more helpful in the long run. It keeps bad things from happening that you could have avoided.
Hello. :bigwave:
I have a question for you.
What is the qualification for a Quality Engineer in China?
I hope you don't mind me asking.
Thank you.
cqt18060180
I believe some bigger orgnization have the ability and resource to do this, eg. GM, Ford
But some tier 1 or tier 2 supplier present to you the SPC and GRR may not be real even you get the coutinuous chart
i am curious for the analysis when the trend chart is going bad, but point is under control also, i think you should call a meeting to solve this trend right? so if like this , if you were one OEM company with some many assembly lines how to do
Q AS9100:2016 D - Intent of 8.4.3 (K) - Implement QMS AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Y When will Notified Bodies require MedDev manufacturers to fully implement ISO 14971:2019? ISO 14971 - Medical Device Risk Management 1
S How to Implement COSO 2017 Framework Various Other Specifications, Standards, and related Requirements 0
M How to implement the 4M Change Management System Lean in Manufacturing and Service Industries 3
M Can I audit processes I've established but do not implement or maintain? Internal Auditing 6
S How to address and implement OH&S opportunities in ISO 45001:2018? Occupational Health & Safety Management Standards 12
J ISO 9001:2015 Cl. 8.1 - 'and to implement the actions determined in clause 6' ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
I How to implement ISO 9001:2015 for Construction Field ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q Is it worth the effort to implement ISO 31000 Risk based on ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A How do we implement a Process Approach ISO 13485:2016 - Existing GMP QMS Other ISO and International Standards and European Regulations 2
Crusader Can I Implement AS9100 in 1 Department only? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
L How many working hours to required to implement ISO 14001 ? ISO 14001:2015 Specific Discussions 6
A Do we have to implement customer specific requirements? Customer and Company Specific Requirements 13
L Roadmap to implement Business Excellence by department Misc. Quality Assurance and Business Systems Related Topics 11
B How to implement a Nonconformance System in a Service Industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Does "establish, implement and maintain a procedure" require a Document - OHSAS 18001 Occupational Health & Safety Management Standards 1
W Working in a company where we try to implement ISO 27001 IEC 27001 - Information Security Management Systems (ISMS) 9
T What type of industries or companies that should implement PAS 55? Other ISO and International Standards and European Regulations 2
A What is QSB? How do you implement? What are your documents? IATF 16949 - Automotive Quality Systems Standard 4
B How to implement 4.2.4 - Disposition of Records in Electronic Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T Metrics and Statistics for Improvement - Easy to implement Statistical Analysis Tools, Techniques and SPC 4
S How to implement protection for multi-winding transformer? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M My company wants me to implement ISO 17025 in our laboratory ISO 17025 related Discussions 7
C Which of these 2 ways would you implement a Quality System? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B How to define and implement Configuration Management Document Control Systems, Procedures, Forms and Templates 5
K How Can I Implement the Process Approach in AS9100C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
D Implement ISO 22000 or E-Cristal System. Food Safety - ISO 22000, HACCP (21 CFR 120) 2
R How to implement Six Sigma within an IT-driven organisation? Six Sigma 14
A How to Develop and Implement 5S +1 Program Lean in Manufacturing and Service Industries 3
L Time Required to Implement ISO 27001 if ISO 9001 certified & SOX compliant? IEC 27001 - Information Security Management Systems (ISMS) 3
R What I have to do to implement ISO 9001:2008 till Registration and Certification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M How to Implement QMS for an Information Solutions company Quality Management System (QMS) Manuals 2
S Planning and Costs to Implement ISO / IEC 27000 - Where to start? IEC 27001 - Information Security Management Systems (ISMS) 2
K How to start Implement SPC for Injection Molding Process? Statistical Analysis Tools, Techniques and SPC 24
2 Trying to Implement a Manufacturing Engineer Concept to my Company Manufacturing and Related Processes 5
R How does my firm implement hybrid system? ISO 13485:2016 - Medical Device Quality Management Systems 5
M How to implement ISO/TS 16949:2009 when customers do not require PPAP? IATF 16949 - Automotive Quality Systems Standard 7
E Why to Implement or Not to Implement ISO 26000 (Social Responsibility) Other ISO and International Standards and European Regulations 14
bobdoering The CORRECT steps to implement an SPC chart Imported Legacy Blogs 16
J When to implement the Development and Design Clause 7.3? Design and Development of Products and Processes 18
M Want Help to Implement IMS (Integrated Management System)? Occupational Health & Safety Management Standards 7
M How to Implement the QHSE Integrated Management System Easy Steps? Occupational Health & Safety Management Standards 1
E Should FDA implement 3rd party (PMAs) reviews? What are the pros and cons of doing so Other US Medical Device Regulations 2
N Implement the Best Format and Set of Tools for Design For Six Sigma Six Sigma 7
K Which Australian Standard will help me implement OH&S in my business ? Occupational Health & Safety Management Standards 8
D How to implement Control of Employee Access to Client Data IEC 27001 - Information Security Management Systems (ISMS) 2
K How to Implement ISO 14001 - Construction Industry - Completed examples ISO 14001:2015 Specific Discussions 3
K How to Implement ISO 9001 - Construction Industry - Completed examples ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S What % of CA you implement are Effective? How do you determine Effectiveness? Nonconformance and Corrective Action 14
