Do you monitor both 0.5 and 5 micron in ISO Class 8 cleanrooms?
Ajit Basrur
I have a question on the nonviable particle monitoring for ISO Class 8 cleanrooms. The particle monitoring is done for both 0.5 and 5 microns but the new ISO 14644-1:2015 recommends using one channel, and heard that most companies are planning to monitor the cleanrooms at 0.5 microns only.
I still prefer the old way of monitoring at both 0.5 and 5 microns to have a good distribution of the particulate contaminants.
Can I know what is your practice - do you monitor only at 0.5 or 5 micron or both?
Ninja
Looking for Reality
I operate a 100K (ISO8-ish) and a 10K (ISO7-ish) room.
We monitor only 0.5um...though I scan the other sizes since they are right there on the standard report anyway.
It is pretty difficult to "fix" one size channel without improving the others anyway...so monitoring one channel makes sense to me unless there is a specific outside influence like a particularly specific customer requirement.
We tend to 'pass' by such a large margin on every test that we have not gone into the nitty gritty of the test details.
AgnieszkaSz
We monitor 0,5, 1 and 5 micron particles for ISO-8 and ISO-7 cleanrooms. But I doubt there is any reason for this other than "it has always been so".
somashekar
Is there not another condition that the cumulative of all particle count should not exceed a certain number for each class ... ?
Ninja
Looking for Reality
Each particle size is "this size or larger"...so in effect each of the particle size measurements in themselves is cumulative.
The 0.5um particle size count will always be larger than the 1um particle count since all of the 1um particles are included in the 0.5um particle count.
RCH2016
Out of curiosity, what instrument are you using to measure particle size? In the industry I am in, the Sedigraph is the standard, but I have had reason in the distant past to explore other instruments and test methods and have found the results from the various approaches to vary to an eye popping degree.
Ninja
Looking for Reality
Howdy,
I use Sedigraph too...but for wildly different things.
Air sampling and Sedigraph particle size measurement are like apples and warm. Nothing at all to do with each other.
Air sampling typically uses a suction port running through a laser PS measurement grid whereas Sedigraph typically has discrete particles in fluid suspension.
Do an image search for "cleanroom air sampling machine" and the difference will jump right out at you (I can't figure out how to put a pic in here).
Morlock
But what particle size is the specification actually for (which I feel is a different question than "what micron size is being monitored"? 0.5 micron? 1 micron? 5 micron? Any of them? All of them? I've reviewed the reference table for maximum values of each particle size for each rating, but the table I reviewed was unclear regarding my question.
For example, say a clean room passes the 0.5 micron specification, but fails the 5 micron specification? Is the clean room certified? What about the reverse?
I found one reference that says "Class 6, 7, and 8 are based on the number 0.5 micron particles. " and "Federal 209B Standards: Class 10,000: Particle count not to exceed a total or 10,000 particles per cubic foot of a size 0.5 micron and larger or 65 particles per cubic foot of a size 5.0 micron and larger." (I added the emphasis). (Source: Cleanroom Classification Comparison Specifications Defined )
Thanks all.
Tata347
have any of you "validated" the room for medical devices? there seems to be some discussion here about exactly needs to be monitored on a daily basis. taking 30 readings a day is going to be too time consuming and not cost effective.. your thought?
S Risk analysis on patient monitor ISO 14971 - Medical Device Risk Management 5
M Display charts on separate monitor? Using SQCpack Software 1
A How to monitor new versions of external standards in your business Various Other Specifications, Standards, and related Requirements 2
R Monitor production quality - Internal KPIs Manufacturing and Related Processes 5
S A clinical performance evaluation study with an IVD product as Investagional Use product - Clinical Monitor requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
N How to monitor the effectiveness of the CAPA system ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
K A way to monitor our Internal Audits as a KPI AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
G ISO 17025 - Requirement to Monitor Environment ISO 17025 related Discussions 10
J IEC60601-2-18 - Endoscopic Surgical Monitor System Images IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D Kanomax MODEL 3443 DIGITAL DUST MONITOR Calibration and Metrology Software and Hardware 3
T Regulatory Standards & Certification Requirement - Headband to monitor mental health Other Medical Device Regulations World-Wide 4
Q Difference between Monitor & Measurement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D How to Monitor Suppliers for Human Trafficking AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A EMC Emission Issues - Communication between PC and Monitor IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
L Procedure for Comparing the Monitor Reading with Laboratory Result Statistical Analysis Tools, Techniques and SPC 4
M Kaye Instrument 373 RTD Monitor Resistance Curve General Measurement Device and Calibration Topics 2
K How can I monitor customer satisfaction? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
S How to Monitor Training Effectiveness Training - Internal, External, Online and Distance Learning 13
A How to Calibrate Laser Beam Tester & Radiation Monitor General Measurement Device and Calibration Topics 3
E How do you monitor Medical Device Off-Label use by Customers & Medical Professionals EU Medical Device Regulations 5
M How to monitor performance of AAS (Atomic Absorption Spectrometer) Equipment General Measurement Device and Calibration Topics 2
C What would be the Device Classification for a Blood Pressure Monitor in EU ? EU Medical Device Regulations 3
K Autoclave Log - Do we have to monitor the usage for every load? General Measurement Device and Calibration Topics 3
M MCOSMOS - Monitor your CMM load time Quality Assurance and Compliance Software Tools and Solutions 3
A Measureables to Monitor an Integrated Management System Capability IATF 16949 - Automotive Quality Systems Standard 3
T How to Monitor Service Suppliers Service Industry Specific Topics 6
M NIST Standard for CO2 Monitor Calibration General Measurement Device and Calibration Topics 5
J Using P-Charts for Glass Manufacturing to Monitor and Control Attributes Statistical Analysis Tools, Techniques and SPC 2
AnaMariaVR2 FDA OKs Bluetooth-enabled blood glucose monitor from LifeScan US Food and Drug Administration (FDA) 5
T What tools are there to monitor a Manufacturing Process or Operation? Quality Tools, Improvement and Analysis 2
G Cpk, Subgrouping, and Can Attribute Charts Monitor Ongoing? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
L How do you Monitor Customer Perception? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
L Patient Monitor Viewing Distance Usability Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 11
I Blood Glucose Monitor & its Logbook Website - Do I need to get 510k for the Website? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
V How do you monitor the Responsiveness, Agility, Efficiency of Quality Systems? Quality Tools, Improvement and Analysis 3
K Using Excel to Monitor Workflow and Productivity Excel .xls Spreadsheet Templates and Tools 3
6 Maintenance Spreadsheet to Monitor the Maintenance Process of a Fleet wanted IATF 16949 - Automotive Quality Systems Standard 8
M AS9100 4.1 How can I know/monitor applicable regulatory/statutory requirements? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M IEC EN 60601-1-8: Battery monitor considered an alarm? IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
J Weld Current Monitor Calibration Laboratory in North America General Measurement Device and Calibration Topics 6
A As a Vendor, how to Monitor and Assure Latex Free for all Components? US Food and Drug Administration (FDA) 2
Marc Using an HD TV as a Computer Monitor After Work and Weekend Discussion Topics 17
N Can a Calibrated Digital Thermometer be used to monitor my oven? General Measurement Device and Calibration Topics 12
P Can we use Control Charting to monitor Rejection Rate? Statistical Analysis Tools, Techniques and SPC 3
Q How to monitor Engineering Change Requests? Document Control Systems, Procedures, Forms and Templates 7
W Applying for 510(k) Submission for Blood Glucose Monitor System 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
P Blood Glucose Monitor - Sample 510(k) submission application 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
K Outgoing QA SPC monitor to replace Inspection Gate Statistical Analysis Tools, Techniques and SPC 1
C Establishment Register Question - Subcontracting - Blood Glucose Monitor System 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
somashekar Lexan 9330 PC FR Grade Processing Problem - Patient Monitor Housing Manufacturing and Related Processes 3
