Document Approval Signature Order
For medical devices, is there a standard or guidance that dictates the order of approval of a document?
For example, must the Author approve before the Reviewers, and only then can the Approvers sign?
It seems that that would be an ideal order. But a situation where all parties are geographically (and time zone) separated can generally make this take longer than a process where, once everyone has agreed (verbally, etc) to the final version, it is signed as early as possible by the signatories. This might mean that an Approver would sign before the Author.
Any signatory could apply their own judgement on pre-conditions; e.g. they're not going to sign until they've seen particular other signatures. But, that would be above-and-beyond the
As far as I see, ISO 13486 and the QSR only require that records be signed by the appropriate authorities - the do not impose any requirements or expectations on the order/dates of the signatures.
Am I missing something in regulations or guidance that prescribe a particular order? Or, is there some inherent danger in allowing approvals to happen in any order?
Thanks!
John Broomfield
If the document has to be signed by more than one person then it usually ordered by their rank in the organization or the technical folk before a manager.
yodon
No order is imposed nor are any particular roles required. You mention the author signing like it was a requirement; it's not. Your organization needs to determine what roles are required to approve (presuming, as @John Broomfield points out, IF the document has to be signed)
outdoorsNW
When I worked in medical a while back, the author signed first, then anyone else could sign in any order. I faintly remember there was one set of conditions (uncommon) where one person/role always signed last.
In theory at least, if there are multiple people signing (indicating approval), all it takes is one who objects and refuses to sign to send the thing back to the drawing board, so the order is mostly irrelevant. I also don't see a need for the author to sign at all, as it should be safely assumed that when the author completes the document and passes it on for approval that she has tacitly approved it. Remember that the "author" could be a person who has no authority in the matter whatsoever, and is writing because he's the only one who's not a crappy writer.
What's the point of having a reviewer? spelling, grammar, etc.?
When a document sets out process requirements, it's usually necessary that more than one person reviews the requirements to ensure that what's been specified is (a) doable and (b) correct as to technical aspects. Of course, it's good to make sure that spelling, grammar and word usage are correct as well.
Ninja
Looking for Reality
In my experience (non-medical), we had four signatories per document:
1. The person who wrote it ('cause none of the managers were going to take time doing it) that it was what they wrote after editing by the below.
2. Production manager - affirming that production could actually understand and do what was written...and that it made sense.
3. R&D manager - affirming that R&D could actually do what was written, since they would do it a while before Xfer to production.
4. Quality - because none of the above had any sense about grammar, spelling, etc. and that it was clear enough for an internal audit later.
Didn't have to be that way...it could have been one if it worked...four is what worked for us. HTH
Ninja
Looking for Reality
Silly me, I assumed the Approver would verify everything...
LOL...I'm the CEO...you think I have a clue what those R&D folks are doing, let alone why? If I knew that, I wouldn't pay them so much.
I look at R&D Spend, 3yr average revenue from products launched less than 18mnths and calculate ROI.
You want me to approve whether or not the SiO2 should be added all at once, or added in stages throughout the mixing process?
You want me to approve whether a 3000cP nominal viscosity is adequate to avoid streaks in the coating?
...and THATS why multiple approvers is not so bad a thing...we're all good at some things, very few are good at it all...and those who are good at it all are too busy to read docs.
(and typically the absolutely WORST person to review a document is the person who wrote it...exceedingly smart folks (spikes) tend to be horrible writers).
Q Document approval through SharePoint (without signature) Records and Data - Quality, Legal and Other Evidence 4
A Document Review and Document Approval --- 2 Signatures needed acc. §820.40? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
B Document Approval Matrix Benchmarking Document Control Systems, Procedures, Forms and Templates 3
U Document Approval - Software company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
I Can a document (form) approval record be separate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
I Document levels and approval requirements for lower level documents like work instructions, forms etc. Document Control Systems, Procedures, Forms and Templates 18
Q Does ISO 9001 Requirement for Document Approval (a service organization) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
B Supplier Approval of electronic document storage service ISO 13485:2016 - Medical Device Quality Management Systems 8
C Document Management Solution for Routing Documents for Approval Manually Document Control Systems, Procedures, Forms and Templates 18
M How to document approval of Organization Charts Records and Data - Quality, Legal and Other Evidence 6
I Electronic vs. Paper Copy Document Approval Process Document Control Systems, Procedures, Forms and Templates 9
C ISO27001 - Document Creation and Approval Requirements IEC 27001 - Information Security Management Systems (ISMS) 4
V How do you manage the Review Comments post to Approval of a Document Document Control Systems, Procedures, Forms and Templates 3
A Document Approval Requirements in an ISO 13485 and FDA System Document Control Systems, Procedures, Forms and Templates 7
L ISO 9001 Document Review and Approval Form Requirements Document Control Systems, Procedures, Forms and Templates 6
somashekar Document Approval per Sec. 820.40 (a) of 21 CFR part 820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
Q Evidence of Approval in an Electronic Document Management System ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V Considering a Time Limit for Document Approval Document Control Systems, Procedures, Forms and Templates 22
T Document Approval Process for Company Documents Document Control Systems, Procedures, Forms and Templates 20
K Can a document approval be in the form of password? Document Control Systems, Procedures, Forms and Templates 22
S Document Approval for Adequacy Prior to Use Document Control Systems, Procedures, Forms and Templates 10
J Evidence required for Document Approval? Document Control Systems, Procedures, Forms and Templates 10
B Document Approval when the responsible person leaves the company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
G Posting of Initials or Names on a Computer Document as Proof of Approval or Task Done Document Control Systems, Procedures, Forms and Templates 3
S Defining Document Review and Approval responsibilities - ISO 13485 - Medical Device Document Control Systems, Procedures, Forms and Templates 3
S Document Approval Matrix - What manager needs to sign what documents Document Control Systems, Procedures, Forms and Templates 11
T Document management software - Legacy document approval history Document Control Systems, Procedures, Forms and Templates 3
Ajit Basrur FDA Requirements for Document Approval by Quality Department US Food and Drug Administration (FDA) 6
S Document Control (Need an Approval Form) - ISO 9001 clause 4.2.3 Document Control Systems, Procedures, Forms and Templates 35
A Document validation / authority - E-mail based approval system - Ideally MS Outlook ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T Document Review and Approval Form - Examples Attached Document Control Systems, Procedures, Forms and Templates 11
W Approval of Electronic Documents - How do we indicate "document approval"? Document Control Systems, Procedures, Forms and Templates 9
D Approval of a Single Electronic Document for Multiple Locations? Document Control Systems, Procedures, Forms and Templates 6
N API Q1, Management of Change & Document Change Request Oil and Gas Industry Standards and Regulations 3
J Project management Document. IATF 16949 - Automotive Quality Systems Standard 4
S Master Document Register Document Control Systems, Procedures, Forms and Templates 2
M Preparing a document for Raw Material of Medical Device EU Medical Device Regulations 1
R Regulations on Controlled Document Size (Paper Size) Document Control Systems, Procedures, Forms and Templates 4
M Document Architecture ISO 13485:2016 - Medical Device Quality Management Systems 2
cgaro62 Using internal audits as part of document reviews Document Control Systems, Procedures, Forms and Templates 21
J Training on the importance of Document Control Document Control Systems, Procedures, Forms and Templates 3
Ed Panek External Standards List - Should this document include previously revised standards? ISO 13485:2016 - Medical Device Quality Management Systems 4
H Document retention period Canada Medical Device Regulations 2
S Document Notes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M ISO 13485 and document control for programs ISO 13485:2016 - Medical Device Quality Management Systems 6
Ed Panek MR Mandate Document EU Medical Device Regulations 1
C Document Index Document Control Systems, Procedures, Forms and Templates 5
K ASME, ANSI, ASTM and similar specifications and their requirements for document control. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
H If we use agile - do we still need to document TF as a waterfall just for the notified bodies need? IEC 62304 - Medical Device Software Life Cycle Processes 2
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 11
