Document approvers by role or by name
DocCtrller
My company requires document approvers to be assigned by a combination of role (e.g., regulatory, quality engineer) and document type (e.g., work instruction, validation protocol). How common is that approach?
I think approvers should be known subject matter experts. That would mean assigning approvers by their actual names. Would that cause problems with auditors/inspectors?
Thanks!
Ronen E
Problem Solver
Moderator
Hello and welcome to the Cove! :bigwave:
The first part means that specific functions in the organization are authorised to approve specific types of documents.
The second means that individuals are qualified to approve specific types of documents based on their qualifications, knowledge, experience etc.
Both arrangements are quite common through the industry, either together or alone. I think you shouldn't have any issues as long as your practice is captured in your QMS and you follow it consistently.
Usually personal qualifications are captured in the individula's training record or in a qualifications matrix.
Cheers,
Ronen.
somashekar
Thanks!
Competency is the key. Personnel identification is to keep a good track on long term as well as to meet certain regulatory requirements. Both are required to be on record. A good system I have seen is to have a log of signature to person that is established every year or as and when changes are made. This log is maintained. Your clarity of purpose is most important and from there the auditor / inspector would have no problem .....
Ronen E
Problem Solver
Moderator
A signature log is a useful thing, but what I find even more useful is supporting and promoting the habit of noting the full name of the individual wherever it's practical. Initials are a sort of compromise that I personally dislike due to potential ambiguity. It can be useful to include the person's initials as well (in their own handwriting) in the signature record.
DocCtrller
Thank you all for your replies!
I think our approach came from an internal audit finding from years ago, before I came on board. The approach we've been using (combination of roles and document types) is complicated by documents that don't fit into one of the predetermined types.
I haven't seen anything in the regulations requiring the approach we use. Thanks for confirming that FDA auditers don't seem to care either, as long as we follow our own documented procedures
Thanks again!
normzone
Using names requires you to update your documents whenever somebody leaves or joins the organization, or if duties change.
Using titles requires you to update your documents whenever your organizational structure changes.
I prefer the latter. It's not a panacea - we do mostly the second and some of the first.
Ronen E
Problem Solver
Moderator
Maybe I previously misunderstood your question.
In that sense, the regulatory expectation is - apart from not contradicting your own documented rules - that the person reviewing / approving a document has the relevant subject-matter expertise / knowledge / experience. In some cases it's obvious, for example an R&D manager signing off a verification protocol or a production line manager approving a work instruction within that line. Where the situation becomes more vague or sensitive, some orgs choose to formally qualify individulas for certain levels of "approval power".
Generally, the FDA expects that the approving individuals be competent. Whether such competence is demonstrated through the position they hold or otherwise is not a clear cut.
S 21 CFR Part 820.40(b) Clarification on Required Document Approvers 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
A Document Review and Document Approval --- 2 Signatures needed acc. §820.40? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
K 25-year lifetime of medical device - document storage period EU Medical Device Regulations 1
J UDI - Where to document it? EU Medical Device Regulations 8
S Changing revision status of a reviewed document Manufacturing and Related Processes 4
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
Q Document ownerships Document Control Systems, Procedures, Forms and Templates 14
E Document Change Request forms (or no forms)? ISO 13485:2016 - Medical Device Quality Management Systems 9
O Any info on release date of FDA “Computer Software Assurance for Manufacturing and Quality System Software” document? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
B Document Approval Matrix Benchmarking Document Control Systems, Procedures, Forms and Templates 3
J Document Approval Signature Order Document Control Systems, Procedures, Forms and Templates 10
M What is the proper way to document measurements Measurement Uncertainty (MU) 1
P Equipment 21 CFR 820.70(g) - User Requirements Document for Off the shelf equipment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
B Do IFU designs have to be document controlled under ISO 13485? Document Control Systems, Procedures, Forms and Templates 2
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Document "Correspondence IATF 16949 vs ISO13485" available? IATF 16949 - Automotive Quality Systems Standard 0
R Document Retention - Discard hard-copies after scanning? ISO 13485:2016 - Medical Device Quality Management Systems 2
P Mylar plot suppliers in accordance with D6-51991 document AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Document Change Notice vs complete System re-write Manufacturing and Related Processes 4
Q Document approval through SharePoint (without signature) Records and Data - Quality, Legal and Other Evidence 4
S What is considered a "core algorithm"? (From an FDA guidance document) Medical Information Technology, Medical Software and Health Informatics 4
U Document Approval - Software company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
O Please, help with document on ISO/ TS 17758 and (IDF 87: 1979). Thank you. Manufacturing and Related Processes 1
I Nitpicking on document released dates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Refusal to Document Complaints Customer Complaints 39
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
I Can a document (form) approval record be separate? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T Advice needed - Environmental MS - unwritten but customer requests policy document ISO 14001:2015 Specific Discussions 5
T Control of downloaded document copies by employees Document Control Systems, Procedures, Forms and Templates 3
T Document control ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
I Is highlighting on a printed document considered a change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C QMS Document Management Software Recommendations Quality Assurance and Compliance Software Tools and Solutions 14
E Part 11 Compliance, Excel living documents (i.e. document master list, equipment list, approved supplier list) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
Sidney Vianna Informational New IAQG Document - AS9100 Clarifications of Intent AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S How to determine & document Organizational Knowledge of a company Document Control Systems, Procedures, Forms and Templates 4
D Are medical device companies required to document every change made to their website? Document Control Systems, Procedures, Forms and Templates 2
M Informational IMDRF draft document – Principles and Practices for Medical Device Cybersecurity Medical Device and FDA Regulations and Standards News 0
M Nonconformity for missing form number on the job description document Nonconformance and Corrective Action 1
R Training Matrix for Document revisions ISO 13485:2016 - Medical Device Quality Management Systems 4
S Controlled Document Location Document Control Systems, Procedures, Forms and Templates 3
