Document Control Advice for a Materials Testing Laboratory
Benjamin28
I am searching for some advice on document control. I have thumbed through the related threads, procedure attachments, etc...yet I think some advice on my specific situation would be more helpful.
So, here it is...we are a materials testing laboratory, as such we maintain a vast library of technical specifications ASTMs, Client Specs, Material specs, MIL stds, FED, etc...Suffice it to say we have thousands of technical specifications in hardcopies. The trick is keeping these updated to their most current revision levels. Some, we get notifications on, such as the ASTMs whenever a revision occurs, others (specifically client specs) we have to review the revision level to assure we have the correct level.
What's worse, is this is compounded, since each spec is digested for core requirements (particular to our testing) and is placed into a master lab test document, so additionally we have to ensure these master documents are also correct to the most current revision level.
This process, when you factor in how many specs were talking about, is prone to errors. Additionally, upkeep of the specifications is beyond cumbersome. I wonder if anyone has experience managing a document control system like this. I'm looking for any advice on how to simplify this process, minimize the likelyhood that any outdated specifications will be utilized.
Currently we somewhat rely on the customer to dictate what spec and revision level needs to be used, verifying that the master lab sheet is current, proceeding if it is, and updating the document/spec if it's not. However, the majority of clients do not list revision levels, or they list revision levels that are outdated without their knowledge. Relying on the customer for this is not an acceptable form of control.
Hoping to find a better way to proceed without throwing gobs of manpower at the documents control program...
:frust:
Duke Okes
Have you looked at a document management system? e.g., scan documents, stuff them into folders, have a cross-reference of applications (e.g., contract, relevant procedures) vs. each appropriate standard & level of it.
ScottK
Not out of the crisis
Re: Document Control Advice
There are services out there that will "manage" your standards for you as far as letting you know when updates are available.
Here's one I know of:
http://engineers.ihs.com/products/standards/webquote/quote-collections.htm?mid=W102
(I'm not endorsing them as I don't use the service, I just buy my standards one by one from them. Just posting an example)
Of course this won't be much good for customer authored standards.
The digesting and creating another document is really tough....
Have you thought about putting them all on a network drive as .pdf files and getting rid of the paper? That's what we do with ours. I buy them in pdf form and keep them on the server rather than buying paper copies.
Then everyone with a computer can access what they need at their desks and print out working copies as needed (but that's probably against copyright :notme: )
You could even invest in a document management system
Just some thoughts.
andygr
Here is the structure I see that you have
Internal Lab document
Industry Spec
Customer specs
Now what you want to try and do is be able to tell when an industry or customer spec changes what Internal lab documents will need to be reviewed and updated.
This drives me to a personnel preference that if something is stated in a controlling document I do not repeat it in another document (except as a reference). As we all know this is how things get out of sync. And is the heart of your problem.
A relational data base ( pick your favorite even excel would work) would identify what internal document uses what outside document at what revision.
You could then create listings of similar documents and verify the latest revisions on line on some cycle such as quarterly . You may not be able to see the actual document but there are free services out there that will show the latest revision level( such as IHS mentioned above)
For those documents from your customers I would deal with it contractually by not just accepting their PO’s if they do not have the spec revision # indicated on the po ( I would not accept latest revision wording unless they gave me a quick way to verify it) but sending back an exclusion clause that you will work to the latest revision you have on file if they do not provide online access ( if they do this the person accepting the PO can check to see if you are working to the latest. This is important as you could find new requirements that increase the cost of your work performed) and that you will every six months send them a listing of documents and revisions you have on file for their review and update.
:2cents:
Tim Butler
Hello.
Here is a program, a company I work with utilizes to manage thousands of standards and it keeps them up to date - including rev levels. We are a testing house as well, and use the program with great success, ensuring the engineers are conducting tests against the latest revisions of each standard. I don't know much more about it than that.
It is an EMC product, and one of the managers at the company, thinks it works very well.
It is called: Documentum
Search the web under this name and its' website should come up.
I hope that helps.
Tim
:frust:
al40
:frust:
I would reccommend you take a look at Qualtrax, it's a cofiguration management system that can handle all of your needs. We use it and we have just about every ANSI, Mil, SAE specification you can think of in it. The implementation was easy and they provided excellent cusotmer support and on-site support when we started the system up.
Best Regards,
al40
Tim Butler
Al,
Thanks, I do not get involved in the mgt of the docs. CSA seems quite happy with the EMC - Documentum, but I will pass it along. ( QUALTRAX )
Thanks,
Tim
Best Regards,
al40
T MS Access Document Control Database advice and database wanted Document Control Systems, Procedures, Forms and Templates 2
T Document Control System and Procedure Advice wanted Document Control Systems, Procedures, Forms and Templates 3
M Advice on Document Register and Control Document Control Systems, Procedures, Forms and Templates 26
M Medical Device Website Document Control - Clinical Advice or Performance Claims Document Control Systems, Procedures, Forms and Templates 2
H External Document Control Procedure advice wanted ISO 13485:2016 - Medical Device Quality Management Systems 9
T Document Approver System AS9100 Doc Control AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
T Terms & Conditions Document Control AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
A Introducing a document control system benefits Document Control Systems, Procedures, Forms and Templates 5
A Digital Document Control - Revision ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
A Document control system for QMS in Google Drive? Document Control Systems, Procedures, Forms and Templates 6
E Do anyone have document of automotive production risk and control of risk? Lean in Manufacturing and Service Industries 1
J Document Control of Online Management Software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
W Document control Document Control Systems, Procedures, Forms and Templates 10
A ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
qualprod Sheets into a spreadsheet document control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Document Control - Applying Suitable Identification to Obsolete Documents ISO 13485:2016 - Medical Device Quality Management Systems 7
D Document Control Question involving DocuSign US Food and Drug Administration (FDA) 6
M Document Control ISO and FDA ISO 13485:2016 - Medical Device Quality Management Systems 7
R Does anyone use iQMS for their ISO based document control? Manufacturing and Related Processes 5
dpenbert AS9100 7.5.3 - Manual Document Control AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S Help in document control procedure Document Control Systems, Procedures, Forms and Templates 14
J Training on the importance of Document Control Document Control Systems, Procedures, Forms and Templates 3
M ISO 13485 and document control for programs ISO 13485:2016 - Medical Device Quality Management Systems 6
K ASME, ANSI, ASTM and similar specifications and their requirements for document control. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 4
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
T Control of downloaded document copies by employees Document Control Systems, Procedures, Forms and Templates 3
T Document control ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
O Vendor vs Engineering Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A ISO9001:2015 Document control and training aids ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Document Control Software Needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
I First Time Implementing Document Control for ISO-9001 - how far back do you go? Document Control Systems, Procedures, Forms and Templates 15
I Document Control Workflow Document Control Systems, Procedures, Forms and Templates 2
D ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions Document Control Systems, Procedures, Forms and Templates 51
R Changing Document Control software. Must I transfer EVERYTHING? Document Control Systems, Procedures, Forms and Templates 3
B Referencing to Supplier Outputs within our Document Control System 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Sidney Vianna IAF Mandatory Document #23 - Control of CB Franchisees and Agents Registrars and Notified Bodies 3
C Document Control - old revision vs new revision Document Control Systems, Procedures, Forms and Templates 22
D Software for advancing with Document Control Quality Assurance and Compliance Software Tools and Solutions 4
L IATF 16949 Cl. 7.1 - Lotus Notes for Document Control IATF 16949 - Automotive Quality Systems Standard 0
A Removing purchase order form from document control - should it be done? Document Control Systems, Procedures, Forms and Templates 9
