Document Control - Changing Company Logo
N
newtoallthis
I apologise if this sounds like a sill question but I am a little unsure about something.
We have recently changed our company logo and are in the process of changing the headers of our controlled documents (such as booking forms, customer satisfaction forms etc) to display the new logo. This is the only change we are making and these documents - and all documents with the previous logo will be withdrawn from use.
In the eyes of 9001, 14001, 18001 Do we still need to issue a new revision status for this, and add it to the register and amendment history? Or do documented changes only apply when the integrity of the document is changed? For example - adding another question to a customer satisfaction form
Thank you in advance for any help
TPMB4
Is an amendment history a requirement in those standards? What is needed is revision control where you can control that the latest issue is out there being used but do you need to record in a record each and every change? Is an up-issue of the revision number and a date issued enough but a list of all the changes ever made to the document not needed by the standards? Of course if you have written it into your system then you have to follow your system I guess.
Just asking the question as I think I have read about this elsewhere and recently.
harry
We have recently changed our company logo and are in the process of changing the headers of our controlled documents (such as booking forms, customer satisfaction forms etc) to display the new logo. This is the only change we are making and these documents - and all documents with the previous logo will be withdrawn from use. ............
The last time when the same issue cropped up with us, top management just issued a memo to inform of the change and with the following instructions:
1. Any new document created with immediate effect shall carry the new logo
2. All changes to the logo shall be completed by the next QMS document revision
3. In the interim, both logos are as good
N
newtoallthis
The use of the document amendment history form is used to evidence accountability for changes made to the controlled documents.
Although 30 new entries into this form is just a waste of time.
From what I have now read I believe that maybe one entry to say that all controlled documents now bare the new logo, together with an e-mail/memo to all those concerned, informing them of the change will be enough.
After all it doesn't change the purpose or information given within the documents - it just makes it look nicer
P
PaulJSmith
I could see this going both ways. If at some point the use of documents with the old logo becomes unacceptable, then you have what amounts to a controlled document change. On the flip side, though, I cannot imagine an an auditor really hammering you for not using revision control on what is just a cosmetic change that does nothing to alter the integrity or intent of the document.
Ajit Basrur
newtoallthis,
You could have a management meeting to document that the company logo and company name (if it has changed) has been changed and all the documents will be changed in a phased manner.
And as harry mentioned, thats the right approach :)
insect warfare
QA=Question Authority
We currently state this in our document control procedure under the section of "Revisions and Re-Approvals":
The following types of document changes will not require the use of a change request form and will be made only by the Document Controller, as appropriate, provided they are standalone changes:
  • Logo changes that are global in scope (and supported by a memorandum)
  • Typos or grammatical errors (which do not alter the meaning or intentions of the controlled document's contents)
This provides us the flexibility we need to ensure that requirements are clearly stated or met, and stay that way. We also view this as part of meeting ISO 9001 paragraph 4.2.3(e), which requires that documents remain "legible", defined in the ISO 9000 Introduction and Support Package: Guidance on the Terminology used in ISO 9001 and 9004 document as "possible to be read by a person or machine for intended use".
We also apply the same methodology to meeting 14001 and 18001 requirements with no issues.
Brian :rolleyes:
dsheaffe
Agree with Brian completely. I think occasionally we get caught up in the minute detail and end up making our lives way too difficult.
Our Doc Control procedure is along the same lines as Brian's example, but extend that concept to a degree: "Documents will not normally be changed and re-issued for insignificant corrections, such as minor spelling errors, changes to position titles, document formats, etc., where these have no impact on the content or context of the document. These corrections will be made to the document during its next normal review, or if it is submitted for other significant changes beforehand. Because of the minor nature of these changes, they would not warrant mention in the “Revision Reason” section of the document."
We have never had a problem with staff getting confused where something like a persons title is not exactly the same in a procedure as it is the Org Chart - and it has never been a problem in any external audit.
Randy
Ask yourself this question "Will the change effect product conformity, cause customer dissatisfaction, effect environmental performance or increase health & safety risk?"
If the answer is no, then concern yourself with something more important and move on.
Just keep it simple and don't let it drive you crazy
insect warfare
Seeing as my document control procedure could use a slight wordsmithing, I have just updated the same section (see my previous post) as follows:
The following situations will not require the use of a change request form and will be made as appropriate by the Document Controller, provided these are standalone changes:
  • Additions, deletions or changes to referenced documents
  • Updating position titles (which have been re-named only)
  • Changes to typos or grammatical errors (which will not impact the context of a controlled document)
I had a couple of minutes so I felt, why not? You may notice that I used a little bit of your verbiage, dsheaffe, so I thank you for providing it here.
Brian :rolleyes:
R Changing Document Control software. Must I transfer EVERYTHING? Document Control Systems, Procedures, Forms and Templates 3
C Changing Document Names/Control Numbers and Obsoleting Document Control Systems, Procedures, Forms and Templates 5
N Changing Document Control Identification of Job Descriptions Document Control Systems, Procedures, Forms and Templates 5
J Control of Obsolete Documents - Changing document control software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
T Control of downloaded document copies by employees Document Control Systems, Procedures, Forms and Templates 3
T Document control ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
O Vendor vs Engineering Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A ISO9001:2015 Document control and training aids ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Document Control Software Needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
I First Time Implementing Document Control for ISO-9001 - how far back do you go? Document Control Systems, Procedures, Forms and Templates 15
I Document Control Workflow Document Control Systems, Procedures, Forms and Templates 2
D ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions Document Control Systems, Procedures, Forms and Templates 51
B Referencing to Supplier Outputs within our Document Control System 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Sidney Vianna IAF Mandatory Document #23 - Control of CB Franchisees and Agents Registrars and Notified Bodies 3
C Document Control - old revision vs new revision Document Control Systems, Procedures, Forms and Templates 22
D Software for advancing with Document Control Quality Assurance and Compliance Software Tools and Solutions 4
L IATF 16949 Cl. 7.1 - Lotus Notes for Document Control IATF 16949 - Automotive Quality Systems Standard 0
A Removing purchase order form from document control - should it be done? Document Control Systems, Procedures, Forms and Templates 9
I Video under Document Control SOP ISO 13485:2016 - Medical Device Quality Management Systems 2
S Change Control Form vs. Document Change Notification ISO 13485:2016 - Medical Device Quality Management Systems 3
S Document control for tooling drawings (Document control clause 7.5.3) IATF 16949 - Automotive Quality Systems Standard 5
J Document Control Newbie - Control of Nonconforming / Returns Log AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
P Document Control - Do hard copies of documents need to be signed? Document Control Systems, Procedures, Forms and Templates 3
R External Standards List (Document Control) Document Control Systems, Procedures, Forms and Templates 3
M Retiring documents in Document Control Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Managing Level 3 Production Documents - Document Control System Help Document Control Systems, Procedures, Forms and Templates 6
M Cross Function Process Map for Document Control Process Maps, Process Mapping and Turtle Diagrams 3
0 How to deal with resistance to GDP Document Control Discipline Document Control Systems, Procedures, Forms and Templates 7
dubrizo Restructuring Document Control Numbering System Document Control Systems, Procedures, Forms and Templates 3
G Migrating to an ISO 13485:2016 Compliant Document Control System ISO 13485:2016 - Medical Device Quality Management Systems 6
E Document Control MS Access Database Document Control Systems, Procedures, Forms and Templates 39
S Looking for Document Control Templates Document Control Systems, Procedures, Forms and Templates 1
S Document Control Guidelines in Engineering Projects - Excel sheets with VBA coding Document Control Systems, Procedures, Forms and Templates 3
E Challenges in document control, revisional control, and change control Document Control Systems, Procedures, Forms and Templates 8
tony s Performance Indicators for Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
M Document Control Management - External documents flowed down from customers Document Control Systems, Procedures, Forms and Templates 2
T Document Control of FMEAs and Control Plans FMEA and Control Plans 5
T Is there a difference between form control and document control ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
x-files Proper Document Control Requests Document Control Systems, Procedures, Forms and Templates 1
D Nonconformance on document control - Unapproved document on production server Document Control Systems, Procedures, Forms and Templates 4
M Where does Document Revision Control Start? Rev 0 or Rev 1 Document Control Systems, Procedures, Forms and Templates 19
I How to build a Microsoft Access MDB Database for Document Control Document Control Systems, Procedures, Forms and Templates 6
I Document Control - Document Revision History Question Document Control Systems, Procedures, Forms and Templates 16
M I Attached My first Document Control Procedure for your Review ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
