Document Control - Control of external documents
mcervantes
#11
Re: Control of external documents
Here is a question I have regarding ISO 13485 and the requirement for controlling of external documents in Section 4.2.3, (f):
4.2.3 Control of documents
Documents required by the quality management system shall be controlled. Records are a special type of document
and shall be controlled according to the requirements given in 4.2.4.
A documented procedure shall be established to define the controls needed
a) to review and approve documents for adequacy prior to issue,
b) to review and update as necessary and re-approve documents,
c) to ensure that changes and the current revision status of documents are identified,
d) to ensure that relevant versions of applicable documents are available at points of use,
e) to ensure that documents remain legible and readily identifiable,
f) to ensure that documents of external origin are identified and their distribution controlled, and
How detailed is the control? My company has 100's of standards but they are not controlled right now. They live in a spreadsheet and they are not in Doc Control. Help or any suggestions?
G
gmdfharr
#12
Although these documents are not controlled, you as an organization must keep a list of such documents, how many copies, where are they located. You are controlling where they are and what you have. such as: IPC 610, Military Defense Standard 2167, if your drawings call for this standard or a standard, you must list them.
G
gmdfharr
#13
take your spread sheet, ensure it has number of copies, where located, latest rev. and call the spread sheet, "Documents of External Origin", give the spreadsheet a number/rev. and put it in Doc Control. now except for a 1 page process doc for how you handle these, your done. Sounds like you have most of the work already done.
External documents, such as international and domestic standards, customer drawings and such items are maintained as documents of external origin. These are the documents you need to at least show control by listing them along with the rev. of the doc and location to be found, that's how you control "external document". Nothing to do with safety. The only control is that you know what they are, the rev. and where they are located.
I stand corrected on the 1 page doc, just put my first statement above in your QMS as a paragraph in 4.2.3. This with the list will satisfy the requirement. No other 'control' is necessary.
G
Geoff Withnell
#14
Even if the guidelines weren't a reference document, it wouldn't still be required by the 'QMS' since the document pertains to Safety and according to many experts here, anything related to EHS shouldn't form part of the Quality Management System conforming to the requirements of ISO 9001.
The issue has already been discussed in various threads under different thread titles.
It is amazing to me how many people miss the point. It is not whether it is "required" by the QMS to control the document. The issue should be "Do we care if the user has the correct information provided by this document?" If the answer is yes, then the document should be controlled. Since most organizations don't want to have more than one document control system, it will be in the QMS Document Control. If you don't care, why have the document?
Geoff Withnell
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
T Control of downloaded document copies by employees Document Control Systems, Procedures, Forms and Templates 3
T Document control ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
O Vendor vs Engineering Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A ISO9001:2015 Document control and training aids ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Document Control Software Needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
I First Time Implementing Document Control for ISO-9001 - how far back do you go? Document Control Systems, Procedures, Forms and Templates 15
I Document Control Workflow Document Control Systems, Procedures, Forms and Templates 2
D ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions Document Control Systems, Procedures, Forms and Templates 51
R Changing Document Control software. Must I transfer EVERYTHING? Document Control Systems, Procedures, Forms and Templates 3
B Referencing to Supplier Outputs within our Document Control System 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Sidney Vianna IAF Mandatory Document #23 - Control of CB Franchisees and Agents Registrars and Notified Bodies 3
C Document Control - old revision vs new revision Document Control Systems, Procedures, Forms and Templates 22
D Software for advancing with Document Control Quality Assurance and Compliance Software Tools and Solutions 4
L IATF 16949 Cl. 7.1 - Lotus Notes for Document Control IATF 16949 - Automotive Quality Systems Standard 0
A Removing purchase order form from document control - should it be done? Document Control Systems, Procedures, Forms and Templates 9
I Video under Document Control SOP ISO 13485:2016 - Medical Device Quality Management Systems 2
S Change Control Form vs. Document Change Notification ISO 13485:2016 - Medical Device Quality Management Systems 3
S Document control for tooling drawings (Document control clause 7.5.3) IATF 16949 - Automotive Quality Systems Standard 5
J Document Control Newbie - Control of Nonconforming / Returns Log AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
P Document Control - Do hard copies of documents need to be signed? Document Control Systems, Procedures, Forms and Templates 3
R External Standards List (Document Control) Document Control Systems, Procedures, Forms and Templates 3
M Retiring documents in Document Control Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Managing Level 3 Production Documents - Document Control System Help Document Control Systems, Procedures, Forms and Templates 6
M Cross Function Process Map for Document Control Process Maps, Process Mapping and Turtle Diagrams 3
0 How to deal with resistance to GDP Document Control Discipline Document Control Systems, Procedures, Forms and Templates 7
dubrizo Restructuring Document Control Numbering System Document Control Systems, Procedures, Forms and Templates 3
G Migrating to an ISO 13485:2016 Compliant Document Control System ISO 13485:2016 - Medical Device Quality Management Systems 6
E Document Control MS Access Database Document Control Systems, Procedures, Forms and Templates 42
S Looking for Document Control Templates Document Control Systems, Procedures, Forms and Templates 1
S Document Control Guidelines in Engineering Projects - Excel sheets with VBA coding Document Control Systems, Procedures, Forms and Templates 3
E Challenges in document control, revisional control, and change control Document Control Systems, Procedures, Forms and Templates 8
tony s Performance Indicators for Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
M Document Control Management - External documents flowed down from customers Document Control Systems, Procedures, Forms and Templates 2
T Document Control of FMEAs and Control Plans FMEA and Control Plans 5
T Is there a difference between form control and document control ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
x-files Proper Document Control Requests Document Control Systems, Procedures, Forms and Templates 1
D Nonconformance on document control - Unapproved document on production server Document Control Systems, Procedures, Forms and Templates 4
M Where does Document Revision Control Start? Rev 0 or Rev 1 Document Control Systems, Procedures, Forms and Templates 19
I How to build a Microsoft Access MDB Database for Document Control Document Control Systems, Procedures, Forms and Templates 6
