Document Control Defined? Determining what documents must be controlled
ScottK
Not out of the crisis
#11
My rules of thumb:
when it comes to work instructions or procedures if it's worth documenting it's worth controlling.
As far as records - if you or your customers or a regulatory body require you maintain the record, it must be controlled.
Defining how you "control" is another ball of wax...
JoAnne W
#12
I have worked in multiple type of Manufacturing and what I teach the organizations is "if the absence of instruction, procedure etc... adversely affects product quality or the company. then it should be controlled".
Randy
#13
Are you talking about documents in a 9001 based system? If so the answer has already been supplied to you and you're failing to recognize it. The answer to your question is very clearly defined and documented in clause 4.2.1., it's up to you to figure out how to apply it to meet your needs. All this other stuff being previously told to you is nice and cool and neat, but the standard itself has the answer you need.
Now if you're wanting the specific names of "all" the documents you have to control, the task of counting the stars in the sky would be more easily accomplished.
#14
If only everything were as clear-cut as you seem to think it is, 75% of this forum would be unnecessary. Perhaps the OP is looking for advice on "how to apply it to [her] needs."
How about an example question: I have a form that's used to record final inspection results. Does the form need to be controlled? Please look in 4.2.1 and give us the "clearly defined" answer.
JaneB
#15
We are currently putting together a team to "DEFINE" what criteria to use to determine what documents should be controlled and what doesn't need to be controlled. So if it meets this....controlled, if it doesn't meet this...doesn't need to be controlled. My personal opinion is that if an organization has a process that is critical to the end result customer (building something, contracts etc) it should be documented. Thoughts?
I feel for you Hillary. Best of luck in trying to come up with such criteria, but as you've perhaps seen from the range of answers, it's a ticklish question.
The broad criteria for things that DO require control have already been given along the lines of a document being one that has a bearing on the quality of your product or service, and where people need to have the correct information. But that, of course, is very broad! And you'll also have seen that many people will speak (not unsurprisingly) from their own context, be that aerospace, manufacturing, or whatever.
It really will vary, depending upon the nature of your organisaton and the types of documents it deals with. It would be helpful if you provided some background information that gives me some idea of these. Then I can can give you some examples of the types of documents that typically need control in such an organisation.
But I still doubt you will be able to get the criteria beyond anything necessarily broad.
K
kgott
#16
I can appreciate the dilema JaneB articulates here and as I see it, its get even more complex when one tries to determine if, and if so, to what extent, does a given document impact on "the effective planning, operation and control of (its) processes." (4.2.1)
A previous employer of mine was given an NC by the certification body because the results of an electrical device (a light bulb in a circuit) test that only determines if electrical current flows or does not flow, were not recorded. If current did not flow the circuit was inspected to the find the reason why and fixed and retested.
They argued that the results were integral to the manufacture of the component and therefore the results were part of the quality records of manufacture. (The strength of current in the completed product circuit was measured at a later stage and recorded.)
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
T Control of downloaded document copies by employees Document Control Systems, Procedures, Forms and Templates 3
T Document control ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
O Vendor vs Engineering Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A ISO9001:2015 Document control and training aids ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Document Control Software Needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
I First Time Implementing Document Control for ISO-9001 - how far back do you go? Document Control Systems, Procedures, Forms and Templates 15
I Document Control Workflow Document Control Systems, Procedures, Forms and Templates 2
D ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions Document Control Systems, Procedures, Forms and Templates 51
R Changing Document Control software. Must I transfer EVERYTHING? Document Control Systems, Procedures, Forms and Templates 3
B Referencing to Supplier Outputs within our Document Control System 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Sidney Vianna IAF Mandatory Document #23 - Control of CB Franchisees and Agents Registrars and Notified Bodies 3
C Document Control - old revision vs new revision Document Control Systems, Procedures, Forms and Templates 22
D Software for advancing with Document Control Quality Assurance and Compliance Software Tools and Solutions 4
L IATF 16949 Cl. 7.1 - Lotus Notes for Document Control IATF 16949 - Automotive Quality Systems Standard 0
A Removing purchase order form from document control - should it be done? Document Control Systems, Procedures, Forms and Templates 9
I Video under Document Control SOP ISO 13485:2016 - Medical Device Quality Management Systems 2
S Change Control Form vs. Document Change Notification ISO 13485:2016 - Medical Device Quality Management Systems 3
S Document control for tooling drawings (Document control clause 7.5.3) IATF 16949 - Automotive Quality Systems Standard 5
J Document Control Newbie - Control of Nonconforming / Returns Log AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
P Document Control - Do hard copies of documents need to be signed? Document Control Systems, Procedures, Forms and Templates 3
R External Standards List (Document Control) Document Control Systems, Procedures, Forms and Templates 3
M Retiring documents in Document Control Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Managing Level 3 Production Documents - Document Control System Help Document Control Systems, Procedures, Forms and Templates 6
M Cross Function Process Map for Document Control Process Maps, Process Mapping and Turtle Diagrams 3
0 How to deal with resistance to GDP Document Control Discipline Document Control Systems, Procedures, Forms and Templates 7
dubrizo Restructuring Document Control Numbering System Document Control Systems, Procedures, Forms and Templates 3
G Migrating to an ISO 13485:2016 Compliant Document Control System ISO 13485:2016 - Medical Device Quality Management Systems 6
E Document Control MS Access Database Document Control Systems, Procedures, Forms and Templates 42
S Looking for Document Control Templates Document Control Systems, Procedures, Forms and Templates 1
S Document Control Guidelines in Engineering Projects - Excel sheets with VBA coding Document Control Systems, Procedures, Forms and Templates 3
E Challenges in document control, revisional control, and change control Document Control Systems, Procedures, Forms and Templates 8
tony s Performance Indicators for Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
M Document Control Management - External documents flowed down from customers Document Control Systems, Procedures, Forms and Templates 2
T Document Control of FMEAs and Control Plans FMEA and Control Plans 5
T Is there a difference between form control and document control ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
x-files Proper Document Control Requests Document Control Systems, Procedures, Forms and Templates 1
D Nonconformance on document control - Unapproved document on production server Document Control Systems, Procedures, Forms and Templates 4
M Where does Document Revision Control Start? Rev 0 or Rev 1 Document Control Systems, Procedures, Forms and Templates 19
I How to build a Microsoft Access MDB Database for Document Control Document Control Systems, Procedures, Forms and Templates 6
