Document Control - Do hard copies of documents need to be signed?
P
Printerman
Hi
i have a question regarding the above. Do hard copies of documents actually need to be signed?
My old employer never did this and i was never pulled up about it by an auditor.
My new employer does do this but its a pain with signing, scanning etc...
I'm thinking if i am the approved issuer of the document and control the issue number distribution then that is review enough?
Ninja
Looking for Reality
It's up to the company.
The document must be controlled...how you control is pretty much up to you...as long as the way you choose prevents use of old versions.
Signatures are a way to track that everyone (the signers) agrees that this is the version that should be in play. We use hardcopy signatures and electronic signatures, and in some cases a dbase button click.
If the document is re how to test a certain parameter...how will you verify that quality and production both agree on the test procedure?
Signing is one way...there are plenty of others...
Randy
The answer is simple...
What does the standard say?
What does your document control procedure say?
If either one says a signature is needed then sign the silly things. (I'll guarantee the standard doesn't)
If neither one requires a signature, it doesn't really matter what the auditor says....Not one bit, as long as you can demonstrate effective control.
All I do is audit, nothing more, just audit and in the end it doesn't matter what I say, feel, or want, only that requirements are effectively met.
Sebastian
Signing document is common way how companies address ISO requirements related to approval for adequacy. Problem is, it is not intention of standard to have signatures on documents. It is to verify if e.g. activities described by documents are feasible to implement, specifications stated are compliant to input data used during documents creation, etc.
Currently we use "hybrid" system, where all hard copies have pen signatures. Some soft copies are distributed in pdf, straight as they come from MS Office using "Save as pdf" function. In cells where pen signatures are located in hard copy, soft copy have written names and surnames of issuing and approving persons, e.g. John Smith.
Other related subject. Personally I found two-stage approval system with "check" and "approve" stages as highly ineffective. "Checker" does not care as approving person definitely will check it later, and "approver" does not care as definitely checking person had checked it before.
G Document Control - Are hard copies required in addition to soft copies maintained? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
V Hard copies from 10-20 years ago - Document Control and Retention Times question Document Control Systems, Procedures, Forms and Templates 19
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
T Control of downloaded document copies by employees Document Control Systems, Procedures, Forms and Templates 3
T Document control ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
O Vendor vs Engineering Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A ISO9001:2015 Document control and training aids ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Document Control Software Needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
I First Time Implementing Document Control for ISO-9001 - how far back do you go? Document Control Systems, Procedures, Forms and Templates 15
I Document Control Workflow Document Control Systems, Procedures, Forms and Templates 2
D ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions Document Control Systems, Procedures, Forms and Templates 51
R Changing Document Control software. Must I transfer EVERYTHING? Document Control Systems, Procedures, Forms and Templates 3
B Referencing to Supplier Outputs within our Document Control System 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Sidney Vianna IAF Mandatory Document #23 - Control of CB Franchisees and Agents Registrars and Notified Bodies 3
C Document Control - old revision vs new revision Document Control Systems, Procedures, Forms and Templates 22
D Software for advancing with Document Control Quality Assurance and Compliance Software Tools and Solutions 4
L IATF 16949 Cl. 7.1 - Lotus Notes for Document Control IATF 16949 - Automotive Quality Systems Standard 0
A Removing purchase order form from document control - should it be done? Document Control Systems, Procedures, Forms and Templates 9
I Video under Document Control SOP ISO 13485:2016 - Medical Device Quality Management Systems 2
S Change Control Form vs. Document Change Notification ISO 13485:2016 - Medical Device Quality Management Systems 3
S Document control for tooling drawings (Document control clause 7.5.3) IATF 16949 - Automotive Quality Systems Standard 5
J Document Control Newbie - Control of Nonconforming / Returns Log AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
R External Standards List (Document Control) Document Control Systems, Procedures, Forms and Templates 3
M Retiring documents in Document Control Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Managing Level 3 Production Documents - Document Control System Help Document Control Systems, Procedures, Forms and Templates 6
M Cross Function Process Map for Document Control Process Maps, Process Mapping and Turtle Diagrams 3
0 How to deal with resistance to GDP Document Control Discipline Document Control Systems, Procedures, Forms and Templates 7
dubrizo Restructuring Document Control Numbering System Document Control Systems, Procedures, Forms and Templates 3
G Migrating to an ISO 13485:2016 Compliant Document Control System ISO 13485:2016 - Medical Device Quality Management Systems 6
E Document Control MS Access Database Document Control Systems, Procedures, Forms and Templates 42
S Looking for Document Control Templates Document Control Systems, Procedures, Forms and Templates 1
S Document Control Guidelines in Engineering Projects - Excel sheets with VBA coding Document Control Systems, Procedures, Forms and Templates 3
E Challenges in document control, revisional control, and change control Document Control Systems, Procedures, Forms and Templates 8
tony s Performance Indicators for Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
M Document Control Management - External documents flowed down from customers Document Control Systems, Procedures, Forms and Templates 2
T Document Control of FMEAs and Control Plans FMEA and Control Plans 5
T Is there a difference between form control and document control ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
x-files Proper Document Control Requests Document Control Systems, Procedures, Forms and Templates 1
D Nonconformance on document control - Unapproved document on production server Document Control Systems, Procedures, Forms and Templates 4
M Where does Document Revision Control Start? Rev 0 or Rev 1 Document Control Systems, Procedures, Forms and Templates 19
