Document Control - How to handle the current documents with respect to training
mshell
I recently started a new job as the ISO Coordinator for a small company. This company has been using a form of document control for several years and we are now in the process of building a QMS based on the requirements of ISO 9001:2000. I need some advice on how to handle the current documents with respect to training. Some of the documents are at version 3 or 4 and the company has no record of training on the previous versions. If we reset the version to 0 our record control will be affected. If we do not reset the version, we will not be able to provide proof of training on all versions.
Any advice is appreciated. :)
David Hartman
Why do you have to provide "proof of training on all versions"? Why not provide the "proof" on just the current version? One of the nice things about ISO 9001 is that you can choose to do what is right for your particular situation. Choose to begin implementing controls from this day forward, and don't look back. If we all attempted to go back and fix our "past" errors, it would be a never ending costly process (and one that would be of NO benefit to our organizations).
Do it now, but do it right. :thedeal:
Mike S.
Happy to be Alive
Are you ISO certified now to 9001-1994? If so, you found a NC internally, lack of training, so do a CA and fix it. If not, just do the training. You do not need to prove you were perfect in the past to get a 9001-2000 cert or else no one would get one. In either case I would not change the doc revision levels.
Hope this helps -- if not write back. :bigwave:
RoxaneB
Change Agent and Data Storyteller
I agree with David...train only what you currently have. Make ISO work for you...you don't work for ISO. At the same time, I would also think about "grandfathering" people in on training. If the documentation is valid and everyone follows it and there is no evidence that nonconforming product is due to lack of training, I'd consider the "grandfathering" route, as well.
Cathy
I agree with all the above. When I started in this company, just over a year ago, I 'Grandfathered' all the procedures and work instructions to see if they were currant etc. (by the way, its the first time I have heard that term used!!) I ended up scraping all the procedures! -about 2 years since last revision and a little behind the actual practice- I broke the system down into departments and only created proceures and work instructions for areas where the work was very specific and needed a standardised approach. Like RcB - I made ISO work for me. This gave the staff an opportunity to 'bite-back' and we managed to improve on some processes. No-one has ever been specifically trained in a written procedure because I make them responsible for writting their own departments procedures. they are training in their functions and are assessed on the basis of competance (9001-2000) Before, it was documented that they were trained, regardless of wheaher they could the job or not!
Randy Stewart
I guess I'm a little confused over what you are asking.
Do you require (within your system) that everyone is trained on "all" procedures? If so why? There is no requirement for this.
IMO the grandfathering is a big waste of time, like Dave said, start now and don't look back. If someone has been at the same job for 2 years why worry about finding out how or if they were trained?
Another point, where is the benefit in training to old levels? That would be like writing your procedure to match QS:1994. train your people. Make changes for QS:1996, train your people. Make changes QS:1998, etc., etc. Waste of time and no benefit, probably cause more confusion.
Plus, if your procedure reflect your day to day operation, personnel are basically trained OJT. They should have had a hand in the procedural changes by bringing up improvements, etc.
Hope this has helped. :bigwave:
RoxaneB
My turn to be confused. When we grandfathered people on documentation developed for a process they had been following, I didn't go back and find out how long ago or anything like that. They were here when the process was documented, therefore they are grandfathered on the release date of the document.
Any training will occur on future modifications.
RoxaneB
Randy Stewart said:
May have gotten my threads mixed up when I mentioned the grandfather act. :eek:
Good to know that *you're* the confused one and not me! ;) Didn't you eat your Wheaties for breakfast? J/K!
Randy Stewart
No, I had a pop tart and a cup of coffee! It's time to go home, I've been here since 5 this morning thinking I was on my way to Toronto!
M The importance of Document Control? How do you handle your Document Control? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T How to Handle Email Document Control Document Control Systems, Procedures, Forms and Templates 2
I Electronic Document Control - How do we handle document signoffs? Document Control Systems, Procedures, Forms and Templates 8
A Document control system for QMS in Google Drive? Document Control Systems, Procedures, Forms and Templates 6
E Do anyone have document of automotive production risk and control of risk? Lean in Manufacturing and Service Industries 1
J Document Control of Online Management Software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
W Document control Document Control Systems, Procedures, Forms and Templates 10
A ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
qualprod Sheets into a spreadsheet document control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Document Control - Applying Suitable Identification to Obsolete Documents ISO 13485:2016 - Medical Device Quality Management Systems 5
D Document Control Question involving DocuSign US Food and Drug Administration (FDA) 6
M Document Control ISO and FDA ISO 13485:2016 - Medical Device Quality Management Systems 7
R Does anyone use iQMS for their ISO based document control? Manufacturing and Related Processes 1
dpenbert AS9100 7.5.3 - Manual Document Control AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S Help in document control procedure Document Control Systems, Procedures, Forms and Templates 14
J Training on the importance of Document Control Document Control Systems, Procedures, Forms and Templates 3
M ISO 13485 and document control for programs ISO 13485:2016 - Medical Device Quality Management Systems 6
K ASME, ANSI, ASTM and similar specifications and their requirements for document control. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 4
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
T Control of downloaded document copies by employees Document Control Systems, Procedures, Forms and Templates 3
T Document control ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
O Vendor vs Engineering Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A ISO9001:2015 Document control and training aids ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Document Control Software Needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
I First Time Implementing Document Control for ISO-9001 - how far back do you go? Document Control Systems, Procedures, Forms and Templates 15
I Document Control Workflow Document Control Systems, Procedures, Forms and Templates 2
D ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions Document Control Systems, Procedures, Forms and Templates 51
R Changing Document Control software. Must I transfer EVERYTHING? Document Control Systems, Procedures, Forms and Templates 3
B Referencing to Supplier Outputs within our Document Control System 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Sidney Vianna IAF Mandatory Document #23 - Control of CB Franchisees and Agents Registrars and Notified Bodies 3
C Document Control - old revision vs new revision Document Control Systems, Procedures, Forms and Templates 22
D Software for advancing with Document Control Quality Assurance and Compliance Software Tools and Solutions 4
L IATF 16949 Cl. 7.1 - Lotus Notes for Document Control IATF 16949 - Automotive Quality Systems Standard 0
A Removing purchase order form from document control - should it be done? Document Control Systems, Procedures, Forms and Templates 9
I Video under Document Control SOP ISO 13485:2016 - Medical Device Quality Management Systems 2
S Change Control Form vs. Document Change Notification ISO 13485:2016 - Medical Device Quality Management Systems 3
S Document control for tooling drawings (Document control clause 7.5.3) IATF 16949 - Automotive Quality Systems Standard 5
J Document Control Newbie - Control of Nonconforming / Returns Log AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
P Document Control - Do hard copies of documents need to be signed? Document Control Systems, Procedures, Forms and Templates 3
R External Standards List (Document Control) Document Control Systems, Procedures, Forms and Templates 3
