Document control - ISO 13485:2003 - Obsolete controlled documents shall be retained?
jdipira7
The standard states that the organization needs to define the period for which at least one copy of obsolete controlled documents shall be retained. Is this applicable to all quality management system documents or only those documents contained in the DMR and DHR?
DannyK
My interpretation is that it applies to all documents; not only those that are referenced in the DMR and DHR.
If you change your purchasing procedure, the obsolete copy should be retained for a period that you must define
Danny
Wes Bucey
It also seems pretty clear that different documents or classes of documents can have different retention periods. The key seems to be in meeting customer and regulatory requirements as well as the "business purpose" requirements of the organization.
V
Vincnet
During our last gap audit last week (sorry to put that in all my replies but I am proud of the result we got :eek: ) we had a remark (which would have been a NC in real life) because we did not stated clearly for each controlled document the retention period for obsolete documents (we were giving a duration in some SOPs but not in all of them). So not only the DMH and DHR
We agreed with the auditor on maintaining a matrix stating for each type of controlled ducument for how long we were keeping them. Simple easy and efficient.
If it works for a french auditor it might work for any (well I expect !)
V
W
wrodnigg
Vincnet said:
If it works for a french auditor it might work for any (well I expect !)V
It would also work for an austrian auditor... ;)
I would say, there is no need to state a retention period for each (separate) document, but for all quality-related documents. It could be useful to divide them into groups and define the retention period for each group.
HTH,HAND~ghw
L
Linda W
When I first started in QA I got a tip about using the matrix from an auditor and have used the matrix for years as my document that shows all records that are required by ISO-13485 (4.2.4) and FDA 820.180. The matrix lists is comprised of columns with these headings:
1 - records required for compliance,
2 - where they are stored,
3 - how they are protected,
4 - how they can be retrieved,
5 - retention time and disposition.
The document is titled "Control of Records." All those required records must be maintained at least equivalent to the lifetime of the medical device but not less than two years. MDD in Europe I believe requires minimum of 6 years.
Linda
Al Rosen
liuyy said:
MDD requires minimum of 6 years,NOT 6 years.
liuyy
That's a minimum of 5 years after the manufacture of the last device. In the Medical Device Directive, annex II, it is specified in 6.1.
T Document control ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
I First Time Implementing Document Control for ISO-9001 - how far back do you go? Document Control Systems, Procedures, Forms and Templates 15
D ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions Document Control Systems, Procedures, Forms and Templates 51
G Migrating to an ISO 13485:2016 Compliant Document Control System ISO 13485:2016 - Medical Device Quality Management Systems 6
L ISO 13485 Document Control - Document Changes - Needing Suggestions ISO 13485:2016 - Medical Device Quality Management Systems 1
K Simple ISO 9001 Compliant Document Control Quality Manager and Management Related Issues 24
H ISO 9001 Document Control Requirements - Design and Development Department Checklists Document Control Systems, Procedures, Forms and Templates 3
smryan Satisfying the ISO 9001:2008 4.3.2.f External Document Control requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K ISO 9001 vs AS9100 Gap Analysis on Delivery Performance and Document Control AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Z Revision Number vs. Issue Number - Document Control in ISO 17025:2005 ISO 17025 related Discussions 8
A ISO 13485, Document Control and Software Validation ISO 13485:2016 - Medical Device Quality Management Systems 9
K HACCP Document Control vs. ISO 9001 Document Control Requirements Food Safety - ISO 22000, HACCP (21 CFR 120) 20
D ISO 9001 Document Control for a Paper Mill ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Software for ISO Document Control - Recommendations Wanted Quality Assurance and Compliance Software Tools and Solutions 7
P Required Documents and Document Control in Human Resources for ISO 9001:2000 Document Control Systems, Procedures, Forms and Templates 5
N Document Control - Is this in compliance with ISO 9001:2000? Document Control Systems, Procedures, Forms and Templates 31
S Document Control (Need an Approval Form) - ISO 9001 clause 4.2.3 Document Control Systems, Procedures, Forms and Templates 35
G ISO 9000:2000 Document Control Procedure P423 Document Control Systems, Procedures, Forms and Templates 7
J ISO 9001:2000 - 4.2.3 Control of Documents - Used to be document and data control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Y Which ISO 9001:2000 Document Control System software? Your opinions / experience? Document Control Systems, Procedures, Forms and Templates 7
C ISO 14001 Document and Data Control Corrective Action Request Miscellaneous Environmental Standards and EMS Related Discussions 31
A The basic requirements of ISO 9000:2000 in terms of document control? Document Control Systems, Procedures, Forms and Templates 4
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
T Control of downloaded document copies by employees Document Control Systems, Procedures, Forms and Templates 3
O Vendor vs Engineering Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A ISO9001:2015 Document control and training aids ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J Document Control Software Needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
I Document Control Workflow Document Control Systems, Procedures, Forms and Templates 2
R Changing Document Control software. Must I transfer EVERYTHING? Document Control Systems, Procedures, Forms and Templates 3
B Referencing to Supplier Outputs within our Document Control System 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Sidney Vianna IAF Mandatory Document #23 - Control of CB Franchisees and Agents Registrars and Notified Bodies 3
C Document Control - old revision vs new revision Document Control Systems, Procedures, Forms and Templates 22
D Software for advancing with Document Control Quality Assurance and Compliance Software Tools and Solutions 4
L IATF 16949 Cl. 7.1 - Lotus Notes for Document Control IATF 16949 - Automotive Quality Systems Standard 0
A Removing purchase order form from document control - should it be done? Document Control Systems, Procedures, Forms and Templates 9
I Video under Document Control SOP ISO 13485:2016 - Medical Device Quality Management Systems 2
S Change Control Form vs. Document Change Notification ISO 13485:2016 - Medical Device Quality Management Systems 3
S Document control for tooling drawings (Document control clause 7.5.3) IATF 16949 - Automotive Quality Systems Standard 5
J Document Control Newbie - Control of Nonconforming / Returns Log AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
P Document Control - Do hard copies of documents need to be signed? Document Control Systems, Procedures, Forms and Templates 3
