Document Control - Need to control EVERYTHING?
somashekar
#11
The charts and graphs reviewed included our defect account totals spreadsheet, sales figures, number of units we produced in a given week, and number of defective units in our WIP product checks, and how we did in our "5S auditing" (i.e. how clean and organized work spaces were). I would not say these charts are necessary to ensure product conformity per se, but are mainly used to track our internal performance. Hope that helps.
Make sure that the records you stated are required by you to demonstrate some evidence of product or process requirement being met.
How ?
List them in your control of records procedure.
In there you will say how identification, storage, protection, retrieval, retention, disposition is done.
If these stated records need to have a date, signature, etc., ensure they are present on all records.
If the formats are predetermined for any of your stated records, and you wish to have them consistently across, the formats can be controlled within your document control procedure.
Revisit your procedures for both 4.2.3 and 4.2.4 objectively and see if you have opportunities to improve them.
Finally, You need not control EVERYTHING, but EVERYTHING that you state as required for your effective QMS operations must be under control.
Take a good step further, and good luck.
Big Jim
#14
So, these are RECORDS. Your auditor seems to be way off course. Appeal the non-conformity ASAP. If an auditor does not understand the difference between document and record control, s/he is not competent to perform QMS audits. Call your new Registrar and appeal the nonconformity and tell them, in no uncertain terms, not to send this individual to your business ever again.
These are both Documents and Records.
There are many such examples in a quality management system. A blank form, such as an inspection sheet, is a document and needs to be controlled as such. Once entries are made on that blank form, that is that you record on it, it becomes a record and needs to be controlled as such.
It is clear that at least some of what the OP listed are documents that are critical to the quality management system and should be controlled as documents. I'm not sure that a major was warranted, but this is a legitimate nonconformance.
At least that's the way I see it.
Wes Bucey
Prophet of Profit
#15
What exactly do YOU mean by "control?" Some folks are obsessive in "control" and think EVERY sheet of paper or electronic record needs the same security as a top secret "eyes only" document in a spy agency. In most organizations, however, control is merely a routine to assure documents are "managed" to assure they are
  1. created,
  2. approved (primarily to check for accuracy and applicability),
  3. held safely (to keep from loss or destruction, primarily, and secondarily, that those which require extra security, like trade secrets, are kept from unauthorized view.)
  4. "held safely" also implies measures to prevent unauthorized changes to the documents (records are merely a subset of all documents)
  5. stored in a manner which facilitates retrieval when required, which includes a method to assure only the most recent or most pertinent version of versioned documents is retrieved - some call this "Configuration Management"
  6. given a retention period (which is reviewed at the expiration to determine whether the document should be retained in an active file, moved to an archive file, or destroyed (not to be confused with "disposed" - a whole other argument))
In the list provided by the OP, some items "might" be considered trade secrets in one organization (sales figures, number of defective units in WIP) and touted publicly in another , depending on the mindset of the managers and owners. Certainly NOT a decision by a third party auditor.
Sidney Vianna
Post Responsibly
#16
Absolutely NOT. While there are documents that can be deemed both as a record and an instruction, it is clearly not the case here. The OP stated
We have always controlled our forms and procedures
No, it isn't. The documents as described
are clearly RECORDS. They are capturing data from activities. So, they must be controlled as records. That's all. Any auditor who expects those completed charts (not the forms) to be "signed and rev. controlled" because
"If more than 2 people see a document, it needs to be controlled" and have a rev level and revision date to boot.
are seriously misguided. At least, the way I see it. :popcorn:
#17
An example of a form that doesn't need control:
"The organization" receives new-part qualification documentation (PPAP, e.g.) from suppliers. There is a documented procedure that describes the review and acceptance requirements. Review is done by a supplier quality person, and the results are given to the purchasing and engineering people responsible for approval. The documented procedure describes the information the reviewer must provide.
The reviewer creates a form to capture the information. Based on the requirements in the review/approval procedure, the reviewer could just as well provide results in a Word document or even an e-mail message, so long as all of the required information is present and in some medium that can be stored as a record of the review. The form created by the reviewer doesn't need to be controlled.
The point here is that there might be lots of situations where forms don't need to be controlled, but the resulting records do. In some instances a form is just a container and not the thing contained.
In other instances, where a need is perceived to closely control the format and continuity of information, control might be necessary, but to aver that every form created must be subject to document control is misguided.
Big Jim
#18
  1. created,
For the definition of "control" as far as documents are concerned, lets look at the standard.
Documents REQUIRED by the quality management system shall be controlled.
Simple enough?
Then the standard goes on to say that the organization must have a documented procedure on how they will control documents.
a) to approve for adequancy prior to issue,
b) to review and update as necessary and re-approve documents,
c) to ensure that changes and the CURRENT REVISION STATUS of documents is identified,
d) to ensure that relevant versions of applicable documents are AVAILABLE AT POINTS OF USE,
e) to ensure that documents remain legible and readily identifiable,
f) to ensure documents of external origin determined by the organization to be necessary for the planning and operation of the quality management system are identified and their distribution controlled, and
g) to prevent the UNINTENDED USE of OBSOLETE documents, and to apply suitable identification to them if they are retained for any purpose.
Back to that opening line "Documents REQUIRED by the quality management system shall be controlled".
If it is found in use, and it pertains to the quality management system, isn't that prima facia evidence that they have determined that it is needed?
Most of the things listed by the OP look like they are likely in that catagory.
Big Jim
#19
Agreed, but not all fit that catagory.
Big Jim
#20
Absolutely NOT. While there are documents that can be deemed both as a record and an instruction, it is clearly not the case here. The OP stated No, it isn't. The documents as described are clearly RECORDS. They are capturing data from activities. So, they must be controlled as records. That's all. Any auditor who expects those completed charts (not the forms) to be "signed and rev. controlled" because are seriously misguided. At least, the way I see it. :popcorn:
I believe that the OP no doubt believes that he is controlling all his forms. It appears that the auditor believes that he did not recognize and thusly did not control some of them. Without seeing the actual situation I cannot answer with full certainty, but it appears highly likely that this is the case. The OP simply missed some.
At least some of the things listed appear to be BOTH documents and records. As docments, the template or form must be controlled. The data collected on them are records and need to be controlled as records. The blank form probably needs to be on the Master List of Documents, or however their procedures says they control documents. The populated or completed forms must be controlled as records, and again within whatever their procedeures says, properly filed so they are retreivable and are protected and stored according to whatever retention times are specified.
May I emphasize that some things are BOTH documents and records.
P Document Control - Do hard copies of documents need to be signed? Document Control Systems, Procedures, Forms and Templates 3
S Need an example of Master Document Control Register ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Document Control - Does the Intranet Copy need to be Stamped "CONTROL COPY". ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Document Control File - Identifying all documents which need to be controlled Document Control Systems, Procedures, Forms and Templates 11
F Document Control For Dummies - Need opinions Document Control Systems, Procedures, Forms and Templates 5
S Correct Document Control - Does each Document need its own Unique Numbering? Document Control Systems, Procedures, Forms and Templates 13
T Changes to document control procedure - need review Document Control Systems, Procedures, Forms and Templates 4
C Document Control Software - ROI - Need Help Document Control Systems, Procedures, Forms and Templates 4
S Document Control (Need an Approval Form) - ISO 9001 clause 4.2.3 Document Control Systems, Procedures, Forms and Templates 35
J 4.5 Document Control and Shop Aids - Do shop aids need to be controlled? Document Control Systems, Procedures, Forms and Templates 3
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
T Control of downloaded document copies by employees Document Control Systems, Procedures, Forms and Templates 3
T Document control ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
O Vendor vs Engineering Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A ISO9001:2015 Document control and training aids ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Document Control Software Needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
I First Time Implementing Document Control for ISO-9001 - how far back do you go? Document Control Systems, Procedures, Forms and Templates 15
I Document Control Workflow Document Control Systems, Procedures, Forms and Templates 2
D ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions Document Control Systems, Procedures, Forms and Templates 51
R Changing Document Control software. Must I transfer EVERYTHING? Document Control Systems, Procedures, Forms and Templates 3
B Referencing to Supplier Outputs within our Document Control System 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Sidney Vianna IAF Mandatory Document #23 - Control of CB Franchisees and Agents Registrars and Notified Bodies 3
C Document Control - old revision vs new revision Document Control Systems, Procedures, Forms and Templates 22
D Software for advancing with Document Control Quality Assurance and Compliance Software Tools and Solutions 4
L IATF 16949 Cl. 7.1 - Lotus Notes for Document Control IATF 16949 - Automotive Quality Systems Standard 0
A Removing purchase order form from document control - should it be done? Document Control Systems, Procedures, Forms and Templates 9
I Video under Document Control SOP ISO 13485:2016 - Medical Device Quality Management Systems 2
S Change Control Form vs. Document Change Notification ISO 13485:2016 - Medical Device Quality Management Systems 3
S Document control for tooling drawings (Document control clause 7.5.3) IATF 16949 - Automotive Quality Systems Standard 5
J Document Control Newbie - Control of Nonconforming / Returns Log AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
R External Standards List (Document Control) Document Control Systems, Procedures, Forms and Templates 3
M Retiring documents in Document Control Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Managing Level 3 Production Documents - Document Control System Help Document Control Systems, Procedures, Forms and Templates 6
M Cross Function Process Map for Document Control Process Maps, Process Mapping and Turtle Diagrams 3
0 How to deal with resistance to GDP Document Control Discipline Document Control Systems, Procedures, Forms and Templates 7
dubrizo Restructuring Document Control Numbering System Document Control Systems, Procedures, Forms and Templates 3
G Migrating to an ISO 13485:2016 Compliant Document Control System ISO 13485:2016 - Medical Device Quality Management Systems 6
E Document Control MS Access Database Document Control Systems, Procedures, Forms and Templates 42
S Looking for Document Control Templates Document Control Systems, Procedures, Forms and Templates 1
S Document Control Guidelines in Engineering Projects - Excel sheets with VBA coding Document Control Systems, Procedures, Forms and Templates 3
