Document Control of ERP Report Format from Software
tekno9000
We are using ERP software and we get all the data we require for smooth functioning. To revamp our documents, I have following questions:
1. Can we use the soft copies of reports that are computer generated for data like “Approved Supplier List” and “Late deliveries by Suppliers”?
2. Do we need to document control these reports? (The software does not provide the flexibility to change the format of the report, so the question of changing the format of the report does not arise – we don’t have the programming capability and knowledge anyway).
3. If we need to document control these reports, do we just make a master form which is similar to ERP report and hand write the control number after printing it?
I will highly appreciate your advice, comments and critique on the subject matter.
ScottK
Not out of the crisis
Re: Document control of ERP reports from software
A controlled supplier list can be controlled by the software. Just write it into your procedure and say that any printout of the list - whether it's a screenshot or printed report - is an uncontrolled document and that anyone needing to consult the Approved Supplier List to see if a supplier is current must look it up on the system.
Late Deliveries? That's simply a report. I've never controlled that. But if you must - same thing as above.
Golfman25
IMO, I wouldn't control the printed "document" but rather the data the creates it. To print data out in a report and "control" it only adds complexity to your system. Your ERP system should have all the latest and greatest information -- how that gets into the system, maintained and updated is what is important. Not the printed report. Good luck.
tekno9000
Thanks Scott and Golfman.
Just a clarification..........
The question was that do I need to control the format of the document of these records?
Sorry if my wordings was confusing.
ScottK
Sounds to me that it's already controlled if you can't change it.
samsung
What I understand from the above is that before switching over to ERP, you had some forms with all the information such as Doc.#, version, date etc. Now, the ERP software can't duplicate the same format and make it look like your old records. Right?
Still the ERP must assign a unique identity to each kind of report it generates. Normally it's the Transaction Code (T Code) which is as unique as your conventional doc. No. One way to control your docs. is to allot the same document number as generated by the ERP (e.g. the T Code) to your master formats so that it exactly matches with the printed formats. Else it's very difficult to hand write the doc.# to every report each time it's printed.
tekno9000
Samsung,
You are exactly right about switching over from manual method to ERP.
But that leads to another question, do we need to keep hard copies of these reports? Since the reports can always be accessed via a computer, does this violate any ISO documentation clause?
tekno9000
So do I need to bring it under document control and maintain in master file or..............
samsung
Samsung,
No it isn't necessary to keep the hard copies unless absolutely required. You may specify it in your Record control procedure that reports will be printed as and when needed, else they would be stored in soft form in the ERP and also the printed reports will have the same Id. as that assigned to the respective master forms (controlled).
However, the printed reports/ soft copies (RECORDS) need to be controlled in line with 4.2.4. (Record control)
ScottK
No.
Just put a sentence in your puchasing procedure that says approved suppliers are entered into the ERP system and an uncontrolled report may be printed as needed. And keep your supplier evaluation records in a safe location as quality records.
As long as your supplier evaluation process is solid you don't need a template, or form, or anything of the sort for a controlled "approved supplier list". This info is in the ERP system and controlled.
I don't know what standards you're acting under but I can tell you that ISO9001 and ISO13485 do not require an "approved supplier list". They require a process for evaluating suppliers but a list is not required no matter what an auditor may tell you. All an approved supplier list does is make auditing easier.
R Document Control when an ERP System Produces most Forms and other Paperwork Document Control Systems, Procedures, Forms and Templates 7
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
T Control of downloaded document copies by employees Document Control Systems, Procedures, Forms and Templates 3
T Document control ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
O Vendor vs Engineering Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A ISO9001:2015 Document control and training aids ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Document Control Software Needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
I First Time Implementing Document Control for ISO-9001 - how far back do you go? Document Control Systems, Procedures, Forms and Templates 15
I Document Control Workflow Document Control Systems, Procedures, Forms and Templates 2
D ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions Document Control Systems, Procedures, Forms and Templates 51
R Changing Document Control software. Must I transfer EVERYTHING? Document Control Systems, Procedures, Forms and Templates 3
B Referencing to Supplier Outputs within our Document Control System 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Sidney Vianna IAF Mandatory Document #23 - Control of CB Franchisees and Agents Registrars and Notified Bodies 3
C Document Control - old revision vs new revision Document Control Systems, Procedures, Forms and Templates 22
D Software for advancing with Document Control Quality Assurance and Compliance Software Tools and Solutions 4
L IATF 16949 Cl. 7.1 - Lotus Notes for Document Control IATF 16949 - Automotive Quality Systems Standard 0
A Removing purchase order form from document control - should it be done? Document Control Systems, Procedures, Forms and Templates 9
I Video under Document Control SOP ISO 13485:2016 - Medical Device Quality Management Systems 2
S Change Control Form vs. Document Change Notification ISO 13485:2016 - Medical Device Quality Management Systems 3
S Document control for tooling drawings (Document control clause 7.5.3) IATF 16949 - Automotive Quality Systems Standard 5
J Document Control Newbie - Control of Nonconforming / Returns Log AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
P Document Control - Do hard copies of documents need to be signed? Document Control Systems, Procedures, Forms and Templates 3
R External Standards List (Document Control) Document Control Systems, Procedures, Forms and Templates 3
M Retiring documents in Document Control Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Managing Level 3 Production Documents - Document Control System Help Document Control Systems, Procedures, Forms and Templates 6
M Cross Function Process Map for Document Control Process Maps, Process Mapping and Turtle Diagrams 3
0 How to deal with resistance to GDP Document Control Discipline Document Control Systems, Procedures, Forms and Templates 7
dubrizo Restructuring Document Control Numbering System Document Control Systems, Procedures, Forms and Templates 3
G Migrating to an ISO 13485:2016 Compliant Document Control System ISO 13485:2016 - Medical Device Quality Management Systems 6
E Document Control MS Access Database Document Control Systems, Procedures, Forms and Templates 42
S Looking for Document Control Templates Document Control Systems, Procedures, Forms and Templates 1
S Document Control Guidelines in Engineering Projects - Excel sheets with VBA coding Document Control Systems, Procedures, Forms and Templates 3
E Challenges in document control, revisional control, and change control Document Control Systems, Procedures, Forms and Templates 8
tony s Performance Indicators for Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
M Document Control Management - External documents flowed down from customers Document Control Systems, Procedures, Forms and Templates 2
T Document Control of FMEAs and Control Plans FMEA and Control Plans 5
T Is there a difference between form control and document control ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
x-files Proper Document Control Requests Document Control Systems, Procedures, Forms and Templates 1
D Nonconformance on document control - Unapproved document on production server Document Control Systems, Procedures, Forms and Templates 4
M Where does Document Revision Control Start? Rev 0 or Rev 1 Document Control Systems, Procedures, Forms and Templates 19
