Document Control of Pocket / Reference Guides?
davidkulwicki
Had a recent question that began as one of those, well if we control this, why don't we control that?
The question arose to deflect away from another issue but got me thinking. I did a quick search and can’t find this as a topic so everyone’s indolence is appreciated.
We have some pocket guides around. In this case they are for ASME Y14.5 (GD&T) and have some information from that standard. We recently had training and I brought these in as a supplement for the floor people to reference. Answers to unasked questions, yes we have the standard and it’s been issued in our system.
Here finally the question. Should these guides be controlled in my system? If so how? If not, what would be the reason not to?
Do I simply treat this as book, abet a small one and leave it at that?
Re: Document Control of Pocket / Reference Guides??
I don't think that word means what you think it means. :tg:
When trying to determine whether or not a document should be controlled, you have to consider what could happen if it weren't. In this case, a measure of control might be an helpful insofar as having records of who received the handbook, and you might also want to retrieve copies if changes to the underlying standard result in a need to change the handbooks. Nonetheless, a case could be made for not controlling them, so you just need to be able to provide your rationale if lack of control is questioned.
G
Geoff Withnell
Presumably, you have the standard under control as an external document. Think of all the good reasons for doing that. Now realize that the standard is not being used most of the time, but the pocket guides will be the documents most often used, because they are so much more convenient. So don't the same reasons apply to the pocket guides?
Geoff Withnell
davidkulwicki
Hi Geoff,
I appreciate your comments.
My original email indeed states the standard is under control meaning it has been received in and issued under the document control procedure.
Upon further examination, these guides are small books; they have a publishing date and edition number.
I can't speak for you but most of us have reference books we use in the course of our work (The Juran Book comes to mind as one).
To carry this thinking process forward, do I control the books in my library because I may use them on occasion in the course of my duties?
Sounds messy, anyone else have any thoughts?
Thanks.
Okay, let’s look at this. What does it mean to control documents? Well 4.2.3 a-g tells us that. So follow the standard:
a) Who approves the document (pocket guide)? Who chose it? Who made sure it was adequate?
b) Who makes sure it stays valid (re-approval)?
c) What about when a new version is available? Who checks out the changes and explains the changes to the folks that have the guides? How can someone tell the difference between the new guide and the old guide?
d) How do you make sure that the pocket guides are available where and when needed?
e) Who makes sure the guides are readable? How are the pocket guides identified?
Now, I’m confident that the pocket guides are not internally generated, so they would be treated as documents of external origin. However, you can see how easily ANY document can fit into the requirements.
And pass the documents past the requirements of 4.2.1 to see if they even need control. I might guess that 4.2.1 d) would be the applicable section, but does it? If folks can do their job without the pocket guide, and still maintain quality, then the guides might not need controlling.
James Gutherson
If the content of the reference guides affects the prodcution of your product (I suspect they do) then they need to be contolled.
They don't really compare to a book like Juran's. You would have to be using the book as an instruction for the approved way to do your job for it to need the same level of control.
Helmut Jilling
Auditor / Consultant
Hi Geoff,
Thanks.
If I can summarize a few of the recent comments:
1. They are being used as quasi-standards? That takes them a step above the Juran books.
2. They are just an interesting guide to simplify the standard (like the QMC pocket guides), then maybe they don't have to be controlled.
3. The simplest answer - they have a rev date. They are external docs. Put them on your external list of docs, show the rev date, and bam! You're done. Doc control does not have to be difficult.
davidkulwicki
Thanks to you and James G.
They are the clearest replies ( easiest understood by me :)) and direction.
Thanks to the rest as well for your input.
Cheers!
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
T Control of downloaded document copies by employees Document Control Systems, Procedures, Forms and Templates 3
T Document control ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
O Vendor vs Engineering Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A ISO9001:2015 Document control and training aids ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Document Control Software Needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
I First Time Implementing Document Control for ISO-9001 - how far back do you go? Document Control Systems, Procedures, Forms and Templates 15
I Document Control Workflow Document Control Systems, Procedures, Forms and Templates 2
D ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions Document Control Systems, Procedures, Forms and Templates 51
R Changing Document Control software. Must I transfer EVERYTHING? Document Control Systems, Procedures, Forms and Templates 3
B Referencing to Supplier Outputs within our Document Control System 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Sidney Vianna IAF Mandatory Document #23 - Control of CB Franchisees and Agents Registrars and Notified Bodies 3
C Document Control - old revision vs new revision Document Control Systems, Procedures, Forms and Templates 22
D Software for advancing with Document Control Quality Assurance and Compliance Software Tools and Solutions 4
L IATF 16949 Cl. 7.1 - Lotus Notes for Document Control IATF 16949 - Automotive Quality Systems Standard 0
A Removing purchase order form from document control - should it be done? Document Control Systems, Procedures, Forms and Templates 9
I Video under Document Control SOP ISO 13485:2016 - Medical Device Quality Management Systems 2
S Change Control Form vs. Document Change Notification ISO 13485:2016 - Medical Device Quality Management Systems 3
S Document control for tooling drawings (Document control clause 7.5.3) IATF 16949 - Automotive Quality Systems Standard 5
J Document Control Newbie - Control of Nonconforming / Returns Log AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
P Document Control - Do hard copies of documents need to be signed? Document Control Systems, Procedures, Forms and Templates 3
R External Standards List (Document Control) Document Control Systems, Procedures, Forms and Templates 3
M Retiring documents in Document Control Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Managing Level 3 Production Documents - Document Control System Help Document Control Systems, Procedures, Forms and Templates 6
M Cross Function Process Map for Document Control Process Maps, Process Mapping and Turtle Diagrams 3
0 How to deal with resistance to GDP Document Control Discipline Document Control Systems, Procedures, Forms and Templates 7
dubrizo Restructuring Document Control Numbering System Document Control Systems, Procedures, Forms and Templates 3
G Migrating to an ISO 13485:2016 Compliant Document Control System ISO 13485:2016 - Medical Device Quality Management Systems 6
E Document Control MS Access Database Document Control Systems, Procedures, Forms and Templates 42
S Looking for Document Control Templates Document Control Systems, Procedures, Forms and Templates 1
S Document Control Guidelines in Engineering Projects - Excel sheets with VBA coding Document Control Systems, Procedures, Forms and Templates 3
E Challenges in document control, revisional control, and change control Document Control Systems, Procedures, Forms and Templates 8
tony s Performance Indicators for Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
M Document Control Management - External documents flowed down from customers Document Control Systems, Procedures, Forms and Templates 2
T Document Control of FMEAs and Control Plans FMEA and Control Plans 5
T Is there a difference between form control and document control ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
x-files Proper Document Control Requests Document Control Systems, Procedures, Forms and Templates 1
D Nonconformance on document control - Unapproved document on production server Document Control Systems, Procedures, Forms and Templates 4
M Where does Document Revision Control Start? Rev 0 or Rev 1 Document Control Systems, Procedures, Forms and Templates 19
I How to build a Microsoft Access MDB Database for Document Control Document Control Systems, Procedures, Forms and Templates 6
