Document Control - old revision vs new revision
chita
Hi all
I am looking for some ideas how to control the documents on the floor. The issue is that people making copy of forms and hiding somewhere. Then, we always seeing the old revision here and there. It doesn't matter, if we took everything out off the floor when we do the revision change. It will appear someday.
Anyone have idea how we can fix this?
We think
1) No copy, only print but then they will print more and hiding it anyway.
2) Provide the print copy and they can only pick up at the designate area. but then they can pickup more and hiding it.
3) Supervisor print for them at the time they need. but supervisor won't have time to do so as they will need every 2 or 3 hours x 3 shifts.
I would really appreciated your idea(s) or even share the system/method you are having now.
Thank you so much.
Ninja
Looking for Reality
Howdy,
There are a number of techniques described on various threads...have a search around the cove...
What we did was have controlled copies stamped with "Controlled Document" in red...and only those stamped red were considered official.
Photocopies turned the stamp black.
No matter how you handle doc control, it looks like your root issue is behavior.
It sounds like your most effective path is going to be to meet with management and supervisors to come up with a facility wide plan to change culture...
Without that, pretty much any technique will fail at some point.
The last approach I used was a pdf database with access privileges to see only current revs...and printing was locked out altogether.
Screen capture and powerpoint failed that approach too. If people want to break the system...it will break. Work on the culture change to stop people intentionally trying to break it.
:2cents:, HTH
chita
I agreed,
I was thinking of the " Controlled Document" stamp as well. May be this will be the only method we can do along with try to change the behavior as well.
Your help is appreciated.
Wes Bucey
Prophet of Profit
I agreed,
Howdy,
:2cents:, HTH
My consulting career is built on the premise "you can't idiot proof anything!" My solution is "change the idiots into smart people!" Essentially, this is Ninja's best suggestion: CHANGE THE CULTURE! Workers need to be brought into the fold to understand the damage to the company and, ultimately, their jobs if time, material, and labor is wasted on making products to obsolete documents. In short, the company needs a System of Profound Knowledge (SoPK)
Sounds kinda like this.
As far as controlling forms is concerned, there is a simple solution: Stop doing it. Rather than controlling forms, create a controlled document that specifies the data that must be recorded. You can still create a form, but you don't have to worry about controlling it or obsolete copies being used.
Golfman25
A couple of things. First, your people are hoarding forms likely because access to them is more difficult than ti should be. Figure out why and fix it.
Second, if you make changes to a form and people can still use the old form without being flagged, then what was the purpose of the change? Make sure you flag improper use of old forms early in the implementation of the new form.
Wes Bucey
Prophet of Profit
Ah yes, I remember that bit. The devil is in the DETAILS. Consultants get PAID to provide details. The big picture stuff is just the free bait. Of course, Deming's SoPK is studied and written about extensively. So anyone looking to do things on the cheap can take a few years off to read, study, and aggregate all the various writings and comments on SoPK to avoid paying a good consultant.
I believe the topic is DOCUMENTS (probably the working documents that forms become after data is filled in) So we really only care about the data which may be obsolete on any of those documents squirreled away. (workers do NOT like to take time away from a job that may be paying by piecework to traipse around for a new set of documents on a workpiece they've been making for years UNLESS management makes them aware the data has changed and following the old document leads to scrap [I think the "s" in that word is redundant.])
What some organizations have done is issue new, dated documents with each work order, so workers do not have to make a decision about fetching the proper revision for prints or specs. The inefficiency of issuing separate work orders and letting workers obtain prints, specs, materials only works in a highly expert craft shop making small quantities where the craftsman's skill is more valuable than a standard work procedure.
From the OP: The issue is that people making copy of forms and hiding somewhere. I can't think of an instance where a completed form would become a "working document." Recorded data becomes a record and as such never becomes obsolete.
Wes Bucey
Prophet of Profit
So it is up to the OP to tell us what he REALLY means, since we have at least two different interpretations. (I believe with you, Jim, about recorded data from operations, which should be turned back for record keeping, not squirreled away in a worker's tool kit. I was thinking more of data like prints and specs which many workers performing "routine" operations will assume stay the same unless they are specifically alerted of a change.
As you are aware, we have numerous threads discussing change processes to assure ALL pertinent parties are aware of the change and have acknowledged adoption of the change and disposal of obsolete documents.
John C. Abnet
Teacher, sensei, kennari
I will agree with @golfman25. Associates are not malicious by nature. I would assume that "...making copies and hiding somewhere..." is actually their effort to help and make the method more efficient (i.e. stop the need to find and print additional every time?). Once we understand what the associates need then we can usually find a solution that will satisfy them and the intent of the system.
Be well.
K ASME, ANSI, ASTM and similar specifications and their requirements for document control. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
T Control of downloaded document copies by employees Document Control Systems, Procedures, Forms and Templates 3
T Document control ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
O Vendor vs Engineering Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A ISO9001:2015 Document control and training aids ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Document Control Software Needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
I First Time Implementing Document Control for ISO-9001 - how far back do you go? Document Control Systems, Procedures, Forms and Templates 15
I Document Control Workflow Document Control Systems, Procedures, Forms and Templates 2
D ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions Document Control Systems, Procedures, Forms and Templates 51
R Changing Document Control software. Must I transfer EVERYTHING? Document Control Systems, Procedures, Forms and Templates 3
B Referencing to Supplier Outputs within our Document Control System 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Sidney Vianna IAF Mandatory Document #23 - Control of CB Franchisees and Agents Registrars and Notified Bodies 3
D Software for advancing with Document Control Quality Assurance and Compliance Software Tools and Solutions 4
L IATF 16949 Cl. 7.1 - Lotus Notes for Document Control IATF 16949 - Automotive Quality Systems Standard 0
A Removing purchase order form from document control - should it be done? Document Control Systems, Procedures, Forms and Templates 9
I Video under Document Control SOP ISO 13485:2016 - Medical Device Quality Management Systems 2
S Change Control Form vs. Document Change Notification ISO 13485:2016 - Medical Device Quality Management Systems 3
S Document control for tooling drawings (Document control clause 7.5.3) IATF 16949 - Automotive Quality Systems Standard 5
J Document Control Newbie - Control of Nonconforming / Returns Log AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
P Document Control - Do hard copies of documents need to be signed? Document Control Systems, Procedures, Forms and Templates 3
R External Standards List (Document Control) Document Control Systems, Procedures, Forms and Templates 3
M Retiring documents in Document Control Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Managing Level 3 Production Documents - Document Control System Help Document Control Systems, Procedures, Forms and Templates 6
M Cross Function Process Map for Document Control Process Maps, Process Mapping and Turtle Diagrams 3
0 How to deal with resistance to GDP Document Control Discipline Document Control Systems, Procedures, Forms and Templates 7
dubrizo Restructuring Document Control Numbering System Document Control Systems, Procedures, Forms and Templates 3
G Migrating to an ISO 13485:2016 Compliant Document Control System ISO 13485:2016 - Medical Device Quality Management Systems 6
E Document Control MS Access Database Document Control Systems, Procedures, Forms and Templates 46
S Looking for Document Control Templates Document Control Systems, Procedures, Forms and Templates 1
S Document Control Guidelines in Engineering Projects - Excel sheets with VBA coding Document Control Systems, Procedures, Forms and Templates 3
E Challenges in document control, revisional control, and change control Document Control Systems, Procedures, Forms and Templates 8
tony s Performance Indicators for Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
M Document Control Management - External documents flowed down from customers Document Control Systems, Procedures, Forms and Templates 2
T Document Control of FMEAs and Control Plans FMEA and Control Plans 5
T Is there a difference between form control and document control ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
x-files Proper Document Control Requests Document Control Systems, Procedures, Forms and Templates 1
D Nonconformance on document control - Unapproved document on production server Document Control Systems, Procedures, Forms and Templates 4
M Where does Document Revision Control Start? Rev 0 or Rev 1 Document Control Systems, Procedures, Forms and Templates 19
I How to build a Microsoft Access MDB Database for Document Control Document Control Systems, Procedures, Forms and Templates 6
