Document Control Procedure - Too much detail?
Q
QAMTY
Hi everyone
I´m in charge of creating the procedure for the control of docs.
But have some doubts in this regard, I´ll appreciate your help
My doubt is how much detail should I include in the procedure?
For example, I´ve seen some samples procedures on the net and they are very simple, for example for the approval just say"
The department X should approve the documents before the issuing, and "Documents of department Y, have to be removed from point of use"
and so on.
I´ve seen some other that describe the steps in high detail
" First the responsible sends an email..."
" Then wait for the approval using xxx documents"
" Then the document is apporved, and saved in the server xxx and in the folder xxx"
Should it be more in detail? it is practical and useful ?
and should I give the details only for docs of quality or also on those product of the Realization process (e.g. Engineering, construction)?
is It recommended one document for all the departments, or separated?
Please advice me on it
Re: Document control too much detailed?
The key question you ask is "Is it practical and useful?" That's what it needs to be, so long as the requirements of 4.2 are covered. There should be no more detail than what's required to describe the requirements and how they "shall" be fulfilled.
samsung
Hi everyone
and so on.
In general and in my opinion, your doc. control procedure should clearly define all the requirements specified in 4.2.3 (a to g) and in doing so, I don't think your procedure would be rendered over-detailed.
Clause 4.2.1 says
documents, including records, determined by the organization to be necessary to ensure the effective planning, operation and control of its processes.
Is It recommended one document for all the departments, or separated?
If the activities of all the departments is similar/ identical, one document for all the departments will suffice, else not.
treesei
Re: Document Control Procdure - Too much detail?
QAMTY,
As the previous responders pointed out, your procedure should cover all necessary elements required by the standard.
Leave the very technical details (step 1 xxx, step 2 xxx and so on) to a lower level document (a technical document, an aid document, a work instruction document, a handbook etc) which is the child of your procedure.
H
Hodgepodge
and so on.
It depends. It is possible to create one method of document approval for all departments. I don't know how happy everyone in your company will be with it though. Depending on the size and complexity of your company, you may want to have all docs controlled the same way except for engineering docs (or whatever department).
Perhaps there isn't a single person in a particular department has the mindset to be good at organizing and controlling documents. I wouldn't let them create a method for controlling documents.
Is it recommended one document for all the departments, or separated?
I will say this, the more people involved in the approval, control, and distribution of documents, the more detail you will need in your procedure. Also, you must contol all the documents your company uses.
AliInMo
I wrote an SOP to cover the entire document control process since it is a process which spans across all departments. I also wrote specific work instructions for document control which were referenced in the Document Control SOP. In a way, I was fortunate because I was preparing for maternity leave at the time and was already writing detailed instructions for the new girl in the department to use while I was out. So the work instructions were very specific, step by step documents.
Randy
When you write a procedure you paint yourself into a corner, the greater the detail the tighter the corner and the paint dries real, real slow.
Procedures are like trying to play Russian Roullette with a loaded single shot pistol...In the end, it will go off and the wound is self inflicted with only yourself to blame for the injury
QAMTY,
This is what I was going to say as well.
Define the process in a general way in your high level document. If there is need for greater detail, of or to cover variations in different departments, save that for lower level documents.
There are many variables in this such as the size of your company, the number of departments and documents to be controlled, level of training and how the departments are set up etc...
Randy brings in a good point to about "painting yourself in to a corner". The more "Documented" your process, the more opportunities there are for "failure to follow the process" and a resulting NC.
So, as others have already said, look for the simplest and most practical approach then go for it. :agree1:
Bunny
I like to leave enough wiggle room in the procedure that we won't get bogged down in the minor details and won't get an AR written on us from an auditor. BUT, I put in enough detail that ambiguity is removed.
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
M I Attached My first Document Control Procedure for your Review ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Gman2 My Attached Document Control Procedure for your Review ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C How to document many document control systems with one Document Control Procedure? Document Control Systems, Procedures, Forms and Templates 6
L Document Control Procedure - Revision Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
B Document Control Procedure - Please Critique Document Control Systems, Procedures, Forms and Templates 5
J Document Control Procedure for the Construction Industry - Help Document Control Systems, Procedures, Forms and Templates 4
B Document Control Procedure - Critique Wanted Document Control Systems, Procedures, Forms and Templates 5
D Converting to Electronic Document Control - Procedure Content ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
A Document Control Procedure Change 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
W Please review and critique our new Document Control Procedure ISO 13485:2016 - Medical Device Quality Management Systems 4
Crusader Local Control Document procedure....define it or not? Document Control Systems, Procedures, Forms and Templates 24
J Document Control Procedure - Review and Feedback Needed Document Control Systems, Procedures, Forms and Templates 9
J Are these things really required in a document control procedure? Document Control Systems, Procedures, Forms and Templates 17
T Document Control System and Procedure Advice wanted Document Control Systems, Procedures, Forms and Templates 3
S Outdated Document Control Procedure & Upcoming Audit Document Control Systems, Procedures, Forms and Templates 7
J Feedback on Document Control Procedure Document Control Systems, Procedures, Forms and Templates 20
P Feedback on Document Control procedure please ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S Document Control Procedure Please Review Document Control Systems, Procedures, Forms and Templates 37
H External Document Control Procedure advice wanted ISO 13485:2016 - Medical Device Quality Management Systems 9
L Sample of Control of Document Procedure and Control of External Documents Document Control Systems, Procedures, Forms and Templates 2
T Changes to document control procedure - need review Document Control Systems, Procedures, Forms and Templates 4
J Document and Record Control - One Procedure or Two? TS 16949 Document Control Systems, Procedures, Forms and Templates 9
A Document Control Procedure needed Document Control Systems, Procedures, Forms and Templates 1
J Document Control Procedure Examples Document Control Systems, Procedures, Forms and Templates 11
J Corporate Procedures and document management/control procedure IATF 16949 - Automotive Quality Systems Standard 6
T Please Comment on my Document Control Procedure Document Control Systems, Procedures, Forms and Templates 8
W Why is a Document Control Procedure necessary? Small 2 Person Business Document Control Systems, Procedures, Forms and Templates 14
G ISO 9000:2000 Document Control Procedure P423 Document Control Systems, Procedures, Forms and Templates 7
D Document Control Procedure - Ideas - Examples Attached Document Control Systems, Procedures, Forms and Templates 40
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T Control of downloaded document copies by employees Document Control Systems, Procedures, Forms and Templates 3
T Document control ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
O Vendor vs Engineering Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A ISO9001:2015 Document control and training aids ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Document Control Software Needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
I First Time Implementing Document Control for ISO-9001 - how far back do you go? Document Control Systems, Procedures, Forms and Templates 15
I Document Control Workflow Document Control Systems, Procedures, Forms and Templates 2
D ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions Document Control Systems, Procedures, Forms and Templates 51
R Changing Document Control software. Must I transfer EVERYTHING? Document Control Systems, Procedures, Forms and Templates 3
B Referencing to Supplier Outputs within our Document Control System 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
