Document Control Stamps - Does anyone still stamp their documents?
CindyG
Hello All!
I was looking through the threads for "Document stamping" recommendations and it looks as though these conversations are definitely "of the past." The last post on this was in 2011.
Does anyone still stamp their documents with, Uncontrolled, Controlled, Obsolete, Reference, etc. anymore? If so, I would like to add this to our document control procedure but was looking for guidance in the definition and use/example for each stamp so that each stamps purpose/identification use would be easily understood in the document control procedure.
Thank you everyone, your the best! :)
indubioush
Hope this helps.
The master/original document revision is stamped with "Master" or "Released" or "Original."
When a document revises, the previous revision is stamped "Old Revision" or "History" or "Obsolete" and signed, dated.
When a document is inactivated, it is stamped "Obsolete" or "Inactive" and signed, dated.
Copies of documents that are in controlled or tracked locations are stamped "Controlled Copy."
Copies of documents that are not controlled or tracked are stamped "Reference Only" or "Uncontrolled Copy."
Copies of documents provided to external individuals or entities are stamped "Confidential."
Hope this helps.
The original is not a revision.
What does "reference only" mean? Aren't all QMS documents intended for reference?
Do you define what "confidential" means to the receiving party?
Hello All!
I don't know how widespread the practice is these days, but I don't think it's done as much as it used to be. Controlling paper documents can be a real pain and hardly ever works very well. If you've looked through older threads you've seen some of the answers you're looking for--they haven't changed. Be careful about "for reference only" because it's a pretty meaningless phrase and suggests that this part of control hasn't really been figured out. All documents are for reference only--what else would they be for?
indubioush
"Reference Only" means that the document is not a controlled copy, and the user is responsible for ensuring they have the most current revision of that document.
Also, the original is a revision. Every document is a revision. I should have been more clear. What I mean to say is that in the chronological order of the process, you stamp the master copy of the initial revision as "Master." When this document revises to a new revision (like rev B) you stamp it "Old Revision."
I'm just sharing the typical stamps used in my experience. Stamps are by no means required.
If the user is responsible for using only the current verision, what purpose does "reference only" serve? As I said, all documents are for reference.
The original issue is not a revision, as it has not been revised. In order for a revision to exist, there must be an original antecedent.
CindyG
Hello Jim, Thank you for taking the time to address my question.
Re: "Copies of documents provided to external individuals or entities are stamped "Confidential." My question re: "external" documents is, our company owns another company, separate location in which we send our mfg. parts to for machining only. Our design engineers send the maching dwg./spec. and this is where we get in trouble. Our design engineers often send the machining guys a rough draft w/dimensions and the Rev before the dwg. is approved. What happens is the dwg. gets approved after and often the "master dwg." will have the same rev. as the rough draft did but different tolerances and this is where the mistake is made. So, should the "rough" draft be sent at "ref. only" and the master sent as "ref. only" also or, the "master dwg" should be stamped with ???
Thank you!
CindyG
Hope this helps.
Good afternoon,
Thank you for clarifying the mentioned stamps! :)
I do have a question re: Copies of documents that are in controlled or tracked locations are stamped "Controlled Copy."
These documents that were calling "Controlled Copy", I'm assuming this would mean they are a copy of the current master on file?
Thank you!
The best way to handle this (IMO, of course) is to differentiate between pre-production drawings and drawings that have been released for production. One way to do this is to use numeric revision levels for one and alphabetic for the other. For example, the first pre-production drawing might be revision 0 (zero), while the initial released-to-production drawing might be "A." This should hold true even if the final pre-production drawing is identical to the released version. No need for the troublesome "reference only" designation so long as it's understood that pre-production drawings might differ from the released version.
Good afternoon,
Correct. Remember that you have to keep track of locations of controlled versions so that they can be retrieved expeditiously when changes occur.
K Document and Data Control Stamps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Control of various Ink Stamps such as Acceptance, Document Status, etc. Document Control Systems, Procedures, Forms and Templates 3
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
T Control of downloaded document copies by employees Document Control Systems, Procedures, Forms and Templates 3
T Document control ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
O Vendor vs Engineering Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A ISO9001:2015 Document control and training aids ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Document Control Software Needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
I First Time Implementing Document Control for ISO-9001 - how far back do you go? Document Control Systems, Procedures, Forms and Templates 15
I Document Control Workflow Document Control Systems, Procedures, Forms and Templates 2
D ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions Document Control Systems, Procedures, Forms and Templates 51
R Changing Document Control software. Must I transfer EVERYTHING? Document Control Systems, Procedures, Forms and Templates 3
B Referencing to Supplier Outputs within our Document Control System 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Sidney Vianna IAF Mandatory Document #23 - Control of CB Franchisees and Agents Registrars and Notified Bodies 3
C Document Control - old revision vs new revision Document Control Systems, Procedures, Forms and Templates 22
D Software for advancing with Document Control Quality Assurance and Compliance Software Tools and Solutions 4
L IATF 16949 Cl. 7.1 - Lotus Notes for Document Control IATF 16949 - Automotive Quality Systems Standard 0
A Removing purchase order form from document control - should it be done? Document Control Systems, Procedures, Forms and Templates 9
I Video under Document Control SOP ISO 13485:2016 - Medical Device Quality Management Systems 2
S Change Control Form vs. Document Change Notification ISO 13485:2016 - Medical Device Quality Management Systems 3
S Document control for tooling drawings (Document control clause 7.5.3) IATF 16949 - Automotive Quality Systems Standard 5
J Document Control Newbie - Control of Nonconforming / Returns Log AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
P Document Control - Do hard copies of documents need to be signed? Document Control Systems, Procedures, Forms and Templates 3
R External Standards List (Document Control) Document Control Systems, Procedures, Forms and Templates 3
M Retiring documents in Document Control Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Managing Level 3 Production Documents - Document Control System Help Document Control Systems, Procedures, Forms and Templates 6
M Cross Function Process Map for Document Control Process Maps, Process Mapping and Turtle Diagrams 3
0 How to deal with resistance to GDP Document Control Discipline Document Control Systems, Procedures, Forms and Templates 7
dubrizo Restructuring Document Control Numbering System Document Control Systems, Procedures, Forms and Templates 3
G Migrating to an ISO 13485:2016 Compliant Document Control System ISO 13485:2016 - Medical Device Quality Management Systems 6
E Document Control MS Access Database Document Control Systems, Procedures, Forms and Templates 42
S Looking for Document Control Templates Document Control Systems, Procedures, Forms and Templates 1
S Document Control Guidelines in Engineering Projects - Excel sheets with VBA coding Document Control Systems, Procedures, Forms and Templates 3
E Challenges in document control, revisional control, and change control Document Control Systems, Procedures, Forms and Templates 8
tony s Performance Indicators for Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
M Document Control Management - External documents flowed down from customers Document Control Systems, Procedures, Forms and Templates 2
T Document Control of FMEAs and Control Plans FMEA and Control Plans 5
T Is there a difference between form control and document control ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
x-files Proper Document Control Requests Document Control Systems, Procedures, Forms and Templates 1
D Nonconformance on document control - Unapproved document on production server Document Control Systems, Procedures, Forms and Templates 4
M Where does Document Revision Control Start? Rev 0 or Rev 1 Document Control Systems, Procedures, Forms and Templates 19
