Document Control Stamps - Does anyone still stamp their documents?
CindyG
#11
The best way to handle this (IMO, of course) is to differentiate between pre-production drawings and drawings that have been released for production. One way to do this is to use numeric revision levels for one and alphabetic for the other. For example, the first pre-production drawing might be revision 0 (zero), while the initial released-to-production drawing might be "A." This should hold true even if the final pre-production drawing is identical to the released version. No need for the troublesome "reference only" designation so long as it's understood that pre-production drawings might differ from the released version.
Thank you, Thank you!
indubioush
#12
These documents that were calling "Controlled Copy", I'm assuming this would mean they are a copy of the current master on file?
Yes, they are a copy of the most current version/revision (e.g., Revision B). If the document were to revise to Revision C, Document Control would, upon the release of Revision C, replace the controlled copy of Revision B with the controlled copy of Revision C. Hope that makes sense. In addition, you would have to have a system in which the Document Control person tracks the location of controlled copies.
CindyG
#13
If the user is responsible for using only the current verision, what purpose does "reference only" serve? As I said, all documents are for reference.
The original issue is not a revision, as it has not been revised. In order for a revision to exist, there must be an original antecedent.
Correct. Remember that you have to keep track of locations of controlled versions so that they can be retrieved expeditiously when changes occur.
If we sent the (external) machine shop the dwg. rev. mstr. controlled "A", I would then stamp it "controlled." And when an external customer sends a dwg. w/specs. to be used in our build, what stamp do I use in this case?
indubioush
#14
No. This is not a controlled copy because you would not be able to retrieve it. You will not be able to control how the external machine shop uses it. Therefore, not a controlled copy. Controlled copies are only in the facility in which you are able to distribute and retrieve them.
#15
You have to be able to recall/replace drawings when they're superseded no matter where they are. I don't know that stamping them facilitates this or not, but they are controlled.
CindyG
#16
Yes, I am trying t
Thanks for pointing this out! Therefore, since I will not be able to retrieve the "controlled" dwg copy from the external machine shop, I will not stamp it "controlled" as you said but then, what will I stamp it?
indubioush
#17
If you are providing a paper copy of a drawing to an external person or organization, you can't really control what happens to that paper. Usually, you provide the copy because you are ordering that item. Supplier and purchasing controls fit in here, including receiving inspection. Often, the paper copy is associated with a purchase order, which becomes a record. It is up to you if and how you want to stamp the copy.
When you receive a drawing from a customer, you should have a process for protecting that customer property. You can stamp the documents as you see fit. However, the stamping process needs to fit in with a larger set of controls.
For every stamp that you use, you need to define what that stamp means. Employees then train to the document that explains what the stamps mean. Since you won't be training external entities to your documents, using stamps on documents sent to your suppliers may not be useful.
I agree with Jim regarding the revisions numbers and letters. In my experience, when a drawing is in the R&D phase, the revisions are numeric, and the approval consists of one engineering signature. When the drawing is transferred to production, it revises to an alpha level revision. This conversion to alpha takes place even if the dimensions and tolerances are the same. The alpha revision indicates that the drawing is ready for production and has had a cross-functional approval. (Something that did not occur during the R&D phase.)
Candi1024
#18
Why must it have a stamp?
How about if you add in the footer or somewhere "Printed versions are uncontrolled unless stamped "Controlled" - This printed document may not be the latest revision.
indubioush
#19
Yes, this works as well. For many organization, a statement of confidentiality may also be present.
Sidney Vianna
Post Responsibly
#20
Does anyone still stamp their documents with, Uncontrolled, Controlled, Obsolete, Reference, etc. anymore?
Stamping documents is as archaic as it gets. We live in a digital world now. There are million different ways to ensure that the APPLICABLE version of a document is available for use.
K Document and Data Control Stamps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Control of various Ink Stamps such as Acceptance, Document Status, etc. Document Control Systems, Procedures, Forms and Templates 3
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
T Control of downloaded document copies by employees Document Control Systems, Procedures, Forms and Templates 3
T Document control ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
O Vendor vs Engineering Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A ISO9001:2015 Document control and training aids ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Document Control Software Needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
I First Time Implementing Document Control for ISO-9001 - how far back do you go? Document Control Systems, Procedures, Forms and Templates 15
I Document Control Workflow Document Control Systems, Procedures, Forms and Templates 2
D ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions Document Control Systems, Procedures, Forms and Templates 51
R Changing Document Control software. Must I transfer EVERYTHING? Document Control Systems, Procedures, Forms and Templates 3
B Referencing to Supplier Outputs within our Document Control System 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Sidney Vianna IAF Mandatory Document #23 - Control of CB Franchisees and Agents Registrars and Notified Bodies 3
C Document Control - old revision vs new revision Document Control Systems, Procedures, Forms and Templates 22
D Software for advancing with Document Control Quality Assurance and Compliance Software Tools and Solutions 4
L IATF 16949 Cl. 7.1 - Lotus Notes for Document Control IATF 16949 - Automotive Quality Systems Standard 0
A Removing purchase order form from document control - should it be done? Document Control Systems, Procedures, Forms and Templates 9
I Video under Document Control SOP ISO 13485:2016 - Medical Device Quality Management Systems 2
S Change Control Form vs. Document Change Notification ISO 13485:2016 - Medical Device Quality Management Systems 3
S Document control for tooling drawings (Document control clause 7.5.3) IATF 16949 - Automotive Quality Systems Standard 5
J Document Control Newbie - Control of Nonconforming / Returns Log AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
P Document Control - Do hard copies of documents need to be signed? Document Control Systems, Procedures, Forms and Templates 3
R External Standards List (Document Control) Document Control Systems, Procedures, Forms and Templates 3
M Retiring documents in Document Control Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Managing Level 3 Production Documents - Document Control System Help Document Control Systems, Procedures, Forms and Templates 6
M Cross Function Process Map for Document Control Process Maps, Process Mapping and Turtle Diagrams 3
0 How to deal with resistance to GDP Document Control Discipline Document Control Systems, Procedures, Forms and Templates 7
dubrizo Restructuring Document Control Numbering System Document Control Systems, Procedures, Forms and Templates 3
G Migrating to an ISO 13485:2016 Compliant Document Control System ISO 13485:2016 - Medical Device Quality Management Systems 6
E Document Control MS Access Database Document Control Systems, Procedures, Forms and Templates 42
S Looking for Document Control Templates Document Control Systems, Procedures, Forms and Templates 1
S Document Control Guidelines in Engineering Projects - Excel sheets with VBA coding Document Control Systems, Procedures, Forms and Templates 3
E Challenges in document control, revisional control, and change control Document Control Systems, Procedures, Forms and Templates 8
tony s Performance Indicators for Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
M Document Control Management - External documents flowed down from customers Document Control Systems, Procedures, Forms and Templates 2
T Document Control of FMEAs and Control Plans FMEA and Control Plans 5
T Is there a difference between form control and document control ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
x-files Proper Document Control Requests Document Control Systems, Procedures, Forms and Templates 1
D Nonconformance on document control - Unapproved document on production server Document Control Systems, Procedures, Forms and Templates 4
M Where does Document Revision Control Start? Rev 0 or Rev 1 Document Control Systems, Procedures, Forms and Templates 19
