Document Control - 'Valid Only on Print Date' in Footer (Opinions Requested)
K
Valid only on Print Date (Opinions Requested)
All hard copy procedures at this company have a statement in the footer, "This Paper Copy Valid Only on Print Date". This has given me a problem since I've been here (9 months). The explaination is that the user of the procedure "verifies" on the intranet that his/her copy is the latest revision before using it on other than the print date.
Recently I conducted an audit and found two procedures being used that had been printed on a previous day. I found no documentation that they were indeed "verified", neither operator even claimed to have done so and one didn't even know where to find the procedures on the net. I considered this a pretty serious finding and for the umpteenth time suggested that perhaps this method of document control should be done away with. I believe that if this is used there must be some documentation of the "verification", initials, stamp, drops of blood etc. Needless to say, the Corporate VP of Quality (his system) disagrees.
Opinions Please
JodiB
not that it's worth much...
But here is my opinion.
I considered adding a watermark to our printed documents that would say that it was valid for two days. And adding an autodate print to each document. But had problems with it, and decided fudge it, I would simply say in my doc control procedure that only printed documents distributed through the doc control procedure would be considered valid. (because we do have some operational manuals that are hard copy by neccessity and they are controlled). And I further said that the procedure was to prevent the "unintended" use of obsolete documents.
Then I put in the footer of the procedure template "verify that this is the current revision before use".:smokin:
This puts the onus on the user and does not disallow a printed copy from being used- as a reference, whatever- but that the user needs to verify the revision. They can easily do that by referring to the Master List online.
Now in your case, it is a lack of training that the users didn't know where to find the current version.
Ooops, they're locking up the office on me! Gotta run!
gpainter
Controlled documents are basically documents that will be replaced/changed as changes occur. So once you print one out it is usually uncontrolled and will not be updated. At one place I worked the document control manager would stamp printed documents "uncontrolled -valid for 2 days" there was a space for the print date. Since you have an intranet based system, then add the watermark, disable the print function or add more monitors. One of the benefits of a computer based system is no printed copies. It is obvious from the audit there is a problem. What was said in response to the Corrective Action? If the CA is not solving the problem do not close it, send it back. Did the users of the procedures know they were supposed to check if the procedure was current or how to do that?
dpenbert AS9100 7.5.3 - Manual Document Control AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S Help in document control procedure Document Control Systems, Procedures, Forms and Templates 8
J Training on the importance of Document Control Document Control Systems, Procedures, Forms and Templates 3
M ISO 13485 and document control for programs ISO 13485:2016 - Medical Device Quality Management Systems 6
K ASME, ANSI, ASTM and similar specifications and their requirements for document control. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 4
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
T Control of downloaded document copies by employees Document Control Systems, Procedures, Forms and Templates 3
T Document control ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
O Vendor vs Engineering Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A ISO9001:2015 Document control and training aids ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Document Control Software Needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
I First Time Implementing Document Control for ISO-9001 - how far back do you go? Document Control Systems, Procedures, Forms and Templates 15
I Document Control Workflow Document Control Systems, Procedures, Forms and Templates 2
D ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions Document Control Systems, Procedures, Forms and Templates 51
R Changing Document Control software. Must I transfer EVERYTHING? Document Control Systems, Procedures, Forms and Templates 3
B Referencing to Supplier Outputs within our Document Control System 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Sidney Vianna IAF Mandatory Document #23 - Control of CB Franchisees and Agents Registrars and Notified Bodies 3
C Document Control - old revision vs new revision Document Control Systems, Procedures, Forms and Templates 22
D Software for advancing with Document Control Quality Assurance and Compliance Software Tools and Solutions 4
L IATF 16949 Cl. 7.1 - Lotus Notes for Document Control IATF 16949 - Automotive Quality Systems Standard 0
A Removing purchase order form from document control - should it be done? Document Control Systems, Procedures, Forms and Templates 9
I Video under Document Control SOP ISO 13485:2016 - Medical Device Quality Management Systems 2
S Change Control Form vs. Document Change Notification ISO 13485:2016 - Medical Device Quality Management Systems 3
S Document control for tooling drawings (Document control clause 7.5.3) IATF 16949 - Automotive Quality Systems Standard 5
J Document Control Newbie - Control of Nonconforming / Returns Log AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
P Document Control - Do hard copies of documents need to be signed? Document Control Systems, Procedures, Forms and Templates 3
R External Standards List (Document Control) Document Control Systems, Procedures, Forms and Templates 3
M Retiring documents in Document Control Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Managing Level 3 Production Documents - Document Control System Help Document Control Systems, Procedures, Forms and Templates 6
M Cross Function Process Map for Document Control Process Maps, Process Mapping and Turtle Diagrams 3
0 How to deal with resistance to GDP Document Control Discipline Document Control Systems, Procedures, Forms and Templates 7
dubrizo Restructuring Document Control Numbering System Document Control Systems, Procedures, Forms and Templates 3
G Migrating to an ISO 13485:2016 Compliant Document Control System ISO 13485:2016 - Medical Device Quality Management Systems 6
E Document Control MS Access Database Document Control Systems, Procedures, Forms and Templates 46
S Looking for Document Control Templates Document Control Systems, Procedures, Forms and Templates 1
S Document Control Guidelines in Engineering Projects - Excel sheets with VBA coding Document Control Systems, Procedures, Forms and Templates 3
E Challenges in document control, revisional control, and change control Document Control Systems, Procedures, Forms and Templates 8
tony s Performance Indicators for Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
M Document Control Management - External documents flowed down from customers Document Control Systems, Procedures, Forms and Templates 2
T Document Control of FMEAs and Control Plans FMEA and Control Plans 5
